Yet another propane question... - Fiberglass RV
Old 06-23-2008, 07:09 AM   #1
I've scanned the boards regarding use of rubber hoses vs. copper. Someone made mention of a rubber hose that runs from the regulator to the copper line of the trailer to allow a flexible connection. This is exactly what I need. The previous owner did not treat the copper line as gingerly as it should have been, and there are some questionable bends in the line. Also, switching from the dual tank system to a single tank has moved the regulator quite a bit closer to the copper line.
I was going to cut the end of the copper line where it is good, and install flexible rubber hose. Is this standard practice? Does someone make the rubber hose with one end ready to fit into the regulator?
(P.S.-I'm not opposed to taking this to the RV place if needed, but if there's an easy, safe fix, I'm all for it).
Thanks,
Todd
Todd Sleeman is offline   Reply With Quote
Old 06-23-2008, 07:40 AM   #2
That's exactly the way my Scamp is setup. Rubber from regulator to copper line running along frame.
Any place that sells high-end propane barbecue equipment should be able to help you. I bought mine at a place that sells/installs gas fireplaces for instance.
Old 06-23-2008, 07:45 AM   #3
BobB's Avatar
Hi Todd,
Many states have requirements that the propane systems must be repaired by trained/certified people. Since you have a system that was "messed with" I would recommend that you have it checked out by someone who knows how to check the regulator pressure, detect leaks in the system, and make sure the appliances are functioning correctly. Be safe!
Old 06-23-2008, 09:45 AM   #4
Donna-
Thanks for the confirmation and a source to go to. Is it just the 3/8" male screwed directly into the bottom of the regulator or do you have some sort of adaptor? Also, is the hose just held on to the copper tubing with a hose clamp? I'd like to go in with as much info as I can in regards to what I need.
Bob-
The damage seems isolated to the external copper tubing, but I probably will get the once-over at an RV place. Better safe than sorry.
Thanks again guys,
Todd
Old 06-23-2008, 12:59 PM   #5
No, no hose clamp, but an actual hose fitting, from the copper line to the rubber line, and from the rubber line into the regulator. I haven't a clue what size.... standard I'm thinking.
Old 06-23-2008, 02:04 PM   #6
Thanks so much for the info. A trip to the local RV place is in order, but at least I know what to look for.
Thanks again,
Todd
(now-if I can get the running lights to work to take it to the RV place....)
Old 06-23-2008, 03:25 PM   #7
Orlen Wolf's Avatar
Most of the propane systems in smaller "i.e. FGRV" trailers use 3/8" flare fittings. If that's what you have you need a flare nut for the copper tubing end and an in-line 3/8" to 3/8" flare fitting. You can find the rubber hoses pre-made in many lengths at RV and outdoor places that cater to the BBQ grill crowd. The hoses have a 3/8" flare fitting on both ends. I think the one I bought at Camping World was about3' long and cost about $10. A common brand for the hose is Mr. Heater.
If you don't have a flaring tool you'll have to get one. They cost about $15 to $20 but will last forever.
Don't forget to check for leaks after you complete the job. Also, do not use plumber's tape on the connections. Flare fittings seal by compressing the flared end of the cu tubing between the flare nut and the end of the flare fitting.
Again - don't forget to check for leaks!
Orlen Wolf is offline   Reply With Quote
Old 06-23-2008, 04:33 PM   #8
Pete Dumbleton's Avatar
You should also get a tubing cutter to make clean cuts before flaring (and don't forget to put the hardware on the tube BEFORE flaring...).
http://www.hobbylinc.com/htm/k+s/k+s296.htm
propane
Propane Mod Steve L. Modifications, Alterations and Updates 34 04-22-2010 05:51 AM
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 02:29 PM
Propane Hook-up Question Todd Sleeman Problem Solving | Owners Helping Owners 9 05-24-2008 02:19 AM
Propane hose question Lenna F Problem Solving | Owners Helping Owners 4 07-08-2007 11:15 AM
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
