yikes - discovered big hole to the outdoors - Fiberglass RV
Old 03-27-2016, 07:48 AM   #1
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
I recently had the silverware drawer out to install a shelf bracket to the right of the stove. The refrigerator has spun fiberglass insulation packed around the sides but with the vibration of travel (our scamp has only about 5000 miles on it thus far) the fiberglass has settled and I was astonished to see bright daylight streaming into the interior. Although a thin fiberglass panel was glued to seal the top edge of the refrigerator from the exterior, there was nothing on the right (as you face the fridge) side. Although it opens into the exterior vent compartment and no critter can get through the vent panels (though I have a few times left the panel off after igniting the fridge propane) it is an inviting entry for insects.
I'll figure out a way to install something to solve it (though access will be tricky) but curious if anyone else encountered this problem? I'm not sure if is an error in the manufacturing or just the way Scamp does it. This is a 2014 13' with front couch/bunk.
WDavidG is offline   Reply With Quote
Old 03-27-2016, 08:50 AM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Picture would be good.
Charlie Y
Old 03-27-2016, 11:39 AM   #3
Trailer: 2016 -13' Scamp
Massachusetts
Following this thread.
herons is offline   Reply With Quote
Old 03-27-2016, 01:10 PM   #4
Vermont
Charlie,
Here are a few. Two from inside looking through the silverware drawer opening; one looking in from the exterior refrigerator vent opening. You can see only the top part of the total gap - it is a couple inches wide by the full height of the fridge. The wood block in the photo is the backing for brackets I added on the cabinet exterior - not an original scamp piece.
Old 03-27-2016, 01:12 PM   #5
Vermont
oops - here they areClick image for larger version
Name:	int close.JPG
Old 03-27-2016, 01:19 PM   #6
Vermont
Not sure why the first and last were rotated 90 degrees. The originals are correct. I've had this happen before.
Old 03-27-2016, 01:36 PM   #7
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
If it is the small fridge, as is ours, which I replaced last summer.
It is supposed to have the back of the fridge completely sealed off from the interior of the Scamp. Ours, (a 2000 16 ft DLX) has sheet aluminum screwed to the top and right side of the fridge, and to the framing above and beside.
And all sealed with metal duct tape.
For access, I had to remove the stove and also work through the cupboard below.
WC
Old 03-27-2016, 03:23 PM   #8
Vermont
WC
Thanks Wayne. Yes, we have the small fridge. Sounds right that it should be sealed all around. Ours is sealed on left and top, but not on the right. I think I'll call Scamp and get their advice although I guess it's just a matter of cutting a piece of sheet aluminum, wiggling it in place and trying to get it fastened and sealed. Not trivial I suspect given the difficult access.
New trailer for Senior citizens who like the GREAT outdoors. Kevin K General Chat 5 08-18-2011 10:28 PM
Cut the bumper for a hitch? Yikes! Melanie Towing, Hitching, Axles and Running Gear 9 07-02-2011 04:48 AM
Scamp - 5 foot sewer hose - yikes! Karalyn Modifications, Alterations and Updates 11 11-05-2010 11:13 AM
cook top outdoors Joseph and Melanie Castine Problem Solving | Owners Helping Owners 16 08-10-2008 06:02 AM
Newbie trying to take first outing, discovered big problem. Benita Murphy Problem Solving | Owners Helping Owners 4 07-11-2008 09:38 AM
