You Can Repair Fiberglass - Page 7 - Fiberglass RV
Old 01-18-2015, 10:20 AM   #85
If you are only filling screw holes, all that work isn't necessary, especially using fiberglass mat. There are fiberglass repair putty's that will do the trick and a hand held countersink tool should do 90% of the prep. BUT, you will never get that smooth glossy finish when done. That's the original Gel-Coat and it's gone. There are some gel coat repair materials out there, but so far I haven't seen anything that will match 35+ year old ge-coat to make repairs look invisible. Why don't you post a pic of the repair area and someone will suggest an alternative repair.
BTW: That's what so many of us paint fiberglass after repairs.
Old 01-19-2015, 08:07 PM   #86
Trailer: 1978 Boler 13'
Here are the pictures of the many tiny holes.
-1st pic shows some of the piano hinge holes,
-2nd pic shows some holes left from a previous light fixture
-3rd pic shows a hole, 3 inches in diameter
Suggestions on how to fix these are greatly appreciated!
lorenleigh is offline   Reply With Quote
Old 01-19-2015, 08:38 PM   #87
Trailer: Bigfoot 19'
have a look at marine tex it is tintable and is very strong. I have esed it it several different applications and it works really well.
Marine Tex, epoxy resin, adhesives, silicone grease, engine treatment, cleaner, repair, bond, fill, seal, fiberglass, aluminum, plastics, Starboard, wood
evenweight is offline   Reply With Quote
Old 01-19-2015, 09:10 PM   #88
Thanks, it certainly looks easy to use for the tiny holes.
Old 01-19-2015, 09:54 PM   #89
What "I" would do.
Any repair you do will take a lot of work to cover and make match. Soooo, I would just put those little imperfections to good use.
I would get some of the small rivet caps and bases from Scamp (They are used all over the outside of Scamps to cover pop-rivets and use small screws mount the bases and then cover each hole with a cap.
As to the larger hole: As it is right by the entry door, I might find a round flush fitting light fixture with a LED inside to use as an entry and/or night light, with a switch near the door and another by the bed. There are some round lights that fit flat to the surface with a textured milk-glass surface that would look nice.
OR
I would simply cover it with a round disk, such as you you buy to put on a wall where a door knob has damaged the wall.
OR
You could use a 3" or 4" round louvered battery vent, as used on the outside of RV's, and it would look "right" as well.
Sorta like "Repurposing" the holes for less than about $10 in parts and 30 minutes work......
Old 01-19-2015, 10:48 PM   #90
Great suggestions Bob. It would be very nice to not have to get into fiberglass work. I like the idea of putting a light in the larger hole by the door.
Old 01-19-2015, 11:30 PM   #91
Heres a link to a light I put in a tent-trailer I referbished for my son: P1010660_zpsa25c9240.jpg Photo by advocateone | Photobucket
Old 01-20-2015, 10:55 AM   #92
Timber Wolf's Avatar
North Florida
What I have done on the interior of the Scamp when I can access the "back" of the holes is mount a piece of trim wood scrwed from the back. I have a large selection of prefinished Oak from a major trim project years ago that comes in handy for bits and pieces like this. I like the light idea there by the door. Nothing too bright, just a little anti-trip illumination.
Old 01-20-2015, 12:39 PM   #93
Yeah I like that light too.
Old 01-20-2015, 01:44 PM   #94
D White's Avatar
Trailer: Trails West Campster, CampStar, Uhaul, Fiberstream
I like the light idea and pop rivets in the screw holes...Dave
D White is offline   Reply With Quote
Old 01-20-2015, 03:32 PM   #95
David Tilston's Avatar
On this trailer, the owner seemed to use pop rivets as rhinestones.
AB (Canada) - 1975 - Trillium 1300 - $5600
Old 01-25-2015, 03:43 PM   #96
Trailer: 82' Scamp 13
So this seems like a good place to ask this question. The last owners cut a hole out in the back for the air conditioner. We are putting the air up in the front, so want to close this in. There is a piece of fg that they got from somewhere that they used to cover the hole when traveling. (See photos) it seems to match the curvature very nicely. We would like to use that piece for the repair but what is the best way to do this? What is the best way to join the two pieces together? Will this even work? Should we go about this a different way? So much to learn with our little project!
Thanks!
Cindy Click image for larger version
Name:	ImageUploadedByFiberglass RV1422225708.099551.jpg
ID:	79931Click image for larger version
Name:	ImageUploadedByFiberglass RV1422225720.734093.jpg
ID:	79932Click image for larger version
Name:	ImageUploadedByFiberglass RV1422225735.723053.jpg
Just realized I held the cover up upside down. :-/
Sent from my phone using Fiberglass RV
Cmtravels is offline   Reply With Quote
Old 01-25-2015, 04:02 PM   #97
Trailer: 2014 Escape 21
Virginia
Cindi
You might consider putting a hatch (If you can find one to fit.) in the hole and you can have a outside storage area if you build a box between the seats. But you can't put your spare back there.
Eddie
Old 01-25-2015, 04:13 PM   #98
Gotta say, you are in for a major project and a repaint of the entire trailer if you want the old hole to "disappear". As my philosophy on this kind of repair is set out in post #89 above, I won't repeat it here.
What I would do if this were my problem:
1. Take advantage of the hole and get a baggage compartment door and frame
that will take up the same space. Even if you don't use it, it will look like it belongs there, but you will find uses for it, like sticking that 12' totem pole you bought at a yard sale inside to take it home.
2. Get a fiberglass cloth and resin repair kit (such as a Bondo Kit) at a local auto supply store, carefully cut the patch to fit and using the kit, seal the patch into place from the inside only using resin and cloth strips per the instructions. Then find an appropriate size refrigerator vent panel, slightly larger than the repaired area and install that over the patch, thus eliminating the need to have a perfect looking repair and repainting.
Short of having the skill sets of a talented boat or RV fiberglass expert, that big a repair will not just not disappear, and you will still have a painting job ahead.
Good Luck
Fiberglass repair D White Problem Solving | Owners Helping Owners 31 06-13-2012 07:15 PM
Fiberglass Repair Lisa H. Care and Feeding of Molded Fiberglass Trailers 3 07-29-2008 11:38 PM
Fiberglass Repair nrsmd Modifications, Alterations and Updates 7 12-18-2005 05:33 PM
Fiberglass Repair Legacy Posts Problem Solving | Owners Helping Owners 10 03-07-2003 09:59 AM
fiberglass repair Legacy Posts Care and Feeding of Molded Fiberglass Trailers 29 01-22-2003 09:18 AM
