12-30-2015, 05:56 AM
#161
Trailer: Prime Time
Thanks, for the quick response, will do. Happy New Year
12-30-2015, 10:35 AM
#162
For any fiberglass repair with fiberglass (and JB Weld is just an epoxy putty, I believe), the one preparation is to abrade the existing fiberglass so the repair is being applied to freshly-exposed fiberglass. Ideally the fiberglass is rubbed down with sandpaper to give a 'fresh' surface but inside a small hole that won't be possible - but just getting a sharp point in the hole and wiggling it around will cut up the existing surface to give a better bond. I have a sharp-pointed bradawl that does this well but frankly even a sharpened nail (as in hammer-and-nail, not as in finger-nail!) will do some good.
The bond of epoxy to polyester is so good that I'm sure many people have got away with no surface preparation, but that's not ideal. If repairing polyester with polyester putty (eg, bondo) or polyester resin/fiberglass, the surface preparation becomes important.
01-27-2016, 09:45 PM
#163
Trailer: Fleetwood Jamboree Rallye 29 foot
Bookmarking
Nothing to add... Just want to Bookmark this for future knowledge... Now, move on there's nothing to see here... LOL
Dennis
01-29-2016, 09:34 AM
#164
You Can Repair Fiberglass
Hi Dennis,
You can subscribe to threads without having to post anything. The app has a subscribe option and the browser version has a subscribe option under thread tools.
Ken
Ken
03-02-2016, 07:22 AM
#165
Trailer: 1988 Bigfoot Fiver
Kentucky
Best ambient temperature to repair fiberglass
All this waiting around for the "right weather" to effect repairs is driving me crazy. I suspect, but haven't checked, that there is an ideal temperature within which to make fiberglass repairs. What is the best ambient temperature in which to work and how long does it take for a small patched hole to cure? We have more than a few holes to patch and I want to get them filled as soon as possible. Thanks to all who reply here. This information has become one of the most invaluable to our reno project.
"All that is gold does not glitter,
not all those who wander are lost..." J.R.R. Tolkien
03-02-2016, 07:23 AM
#166
Kentucky
All JB Weld created equal?
Originally Posted by D White
Look at this as a good thing. You have your first of many blemishes that you will get using something. The JB Weld idea is a permanent, cheap anyone can do idea that will not be covered. For you, just put some latex caulk or any exterior repair type putty and scrape flush with a razor blade so you don't disturb any more finished area than necessary. Let dry and cover with your sticker....then...forgetabboutit...camp the hell out of the unit and have fun...may the forest be with you...Fiberglass Dave
Dave, I have stocked JB Weld as part of my tool kit for some time now but I'm wondering if there is a different kind of JB that you'd recommend for fiberglass repair, or is it all the same standard patch material?
03-02-2016, 10:16 AM
#167
Trailer: Home Built
I don't recommend JB Weld...It is just cheap and available and works for a small hole. Lots of things work, I'm just about fix it and forget it and go camping. As far as temperature, read your instructions and follow those to the letter and you should be fine. You can also put a heat lamp on the repair to help with cure. Fiberglass does not like moisture so be sure everything is dry. Give it a try and if it doesn't work the way you wanted, grind it out and do it over. You can't really screw it up so go for it!!! Fiberglass Dave
03-03-2016, 07:24 AM
#168
Kentucky
D: Thanks for clearing that up. Would you worry about glass mat to patch a small screw hole or just mix up the resin and plug the hole? b
03-07-2016, 07:46 AM
#169
Kentucky
I stopped by Advanced Auto parts this weekend and found that they stock a product from Bondo called Bondo Glass and is described as a short strand resin for small holes and includes a tube of hardener. I didn't buy it because I don't believe our temperatures are going to cooperate for patching yet, but I just checked the weather and I may be wrong. Could be on my way back there for a can/jar and get on with the patching.
03-21-2016, 11:16 AM
#170
Deep South
Dave,
I have a question...I have done some extensive fiberglass repairs since last summer using your methods in this thread to patch the original 3 way fridge opening and various smaller openings on the body and roof. Also glassed in new plywood floors to the body. I used Bondo resin, mat cloth and bondo filler. The fiberglass part I got down okay, but getting the filler perfectly smooth is where I have problems. I painted last summer but you can see some dips or low areas or high areas in places that I want to go back over to get that "fender smooth" look. I have difficulty getting consistent results with the bondo filler, dries to quickly or too slow depending on temperature even when following directions...sanding gums up sanding discs fast if it doesn't dry properly or is not dry enough even after a day or so, and using too much of a resin layer is more difficult to sand down than the filler. Are there any tricks of the trade to get the right mixture down consistently regardless of temperature? What about the bondo glass, or hair filler products good for this finishing work? I really want as close to museum quality smooth body finish as I can get as a DIYer. Also, last year I used tractor supply gray primer and then tractor supply gloss white, but I thinned the white down 50% with paint thinner to obtain a finer mist in my spray gun in hopes of getting a smoother finish and laydown. Would that much thinner cause a loss of gloss and would a clear coat help this? I want a high gloss finish so I bought a couple quarts of Rustoleum Marine Topside Paint for Wood and Fiberglass to try. Thanks Dave, really enjoy this thread, never would have done all this with out this one...
03-21-2016, 02:53 PM
#171
Trailer: Home Built
Originally Posted by Johnny M
Dave,
Congrats to you for doing your own repairs. That is exactly why I wrote this thread. Now for finishing. If you are having problems with your filler, Bondo brand is the bottom of the barrel. I would recommend you try something from Evercoat like Rage gold and go at it again carefully following the directions. High and low spots come from not using a block to sand with. You must use a block always on every grit from the coarsest shaping grit to the finest smoothing grit or you will have high and low spots. AS YOU BEGIN TO DO THIS OVER, REMEMBER TO REMOVE ALL PAINT. NEVER PUT REPAIR FILLERS OVER PAINT. I commend you for trying to do it better because that is exactly what everyone does. Our motto here is IF YOU AINT HAPPY WITH IT, YOU QUIT TOO SOON. The cool thing with fiberglass is, you can redo it easily and cheaply until you get the result you are looking for. Paint is another ballgame but also easily doable. However, it sounds like you didn't follow the directions on reduction. If you don't follow the directions, you will never get the desired result. I would chalk it up to experience and try it again. Keep at it and you will succeed. You can do it. Then and during all this, get out and camp the heck out of your unit. May the forest be with you.
Fiberglass Dave
03-29-2016, 08:39 PM
#172
Utah
Help! I think I screwed up!
Hello Dave (and others here ), I've been following your how-to instructions and have been feeling pretty confident in the work I've been doing. I've glassed in nearly every hole in the shell of my '87 16-footer since I'm moving things around and putting interior tabs in place for all the cabinets to mount to. I spent the day stripping the carpet glue from the inside shell using KleanStrip Adhesive remover and scraping like crazy. My son popped his head in when I was just about finished and asked if I had checked to make sure the stripper wouldn't hurt the fiberglass - I hadn't.
The can didn't say anything about fiberglass so I called the manufacturer. They said it WAS NOT ok to use on fiberglass and that I should immediately wash it off with warm soapy water. I asked if there was something I should be using to neutralize it, but they said to just use the soap and water.
Have I really blown it?? Should I paint over the whole interior with some resin or something just in case? I scrubbed it three times with soapy warm water (dish soap).
Help!
04-02-2016, 06:39 PM
#173
Trailer: Home Built
You learned a valuable lesson here, so call it going to college. Continue on, you should be fine this time, or you would be asking me about what to do with the DAMAGE. Nothing happens without action. Congrats on taking action and trying something new. Fiberglass Dave
04-02-2016, 06:58 PM
#174
Utah
Thanks Dave! Lesson learned
05-04-2016, 09:35 PM
#175
Deep South
Dave,
I have another issue regarding my door...the door had water leak into it through the window to the point that all the wood inside the 2 layers of fiberglass had turned to mush so there was nothing left to keep its shape...so I got rid of the mush, removed the window and glassed over it, then I made a metal frame for the door. The first was hand bent 1" square tubing using a jig until it matched the shape of the door opening, welded the pieces together, checked fit again, epoxied it to door...it was off corner to corner enough that I was not happy, so I re-did it only this time I used conduit - much easier to work with although not a strong, but once epoxied to the door I was surprised at how strong it is...now my door fits perfectly.
So now my issue is finishing the inside of the door around the conduit, I am filling the void with 1" styrofoam sheet insulation cut to fit. Right now I have a piece of utility plastic panel screwed to the conduit but it doesn't look very good. I thought about wetting out some fiberglass on a flat surface then glass or epoxy that to the conduit frame and wanted to know your thoughts on that. Secondly I wanted to know your thoughts of using any of the following products for finishing around the conduit frame: Bondo Professional Gold Filler, Bondo-Glass (fiberglass reinforced filler), Bondo All Purpose Filler, Bondo Fiberglass Resin Jelly and Bondo Body Filler.
My thought here is 2 parts, one is I want a nice smooth finished and contoured look (original factory look) but also I don't want to add weight unnecessarily to the door and the filler seems to me to add more weight that using resin or am I mistaken?
I don't have any pictures of the door showing the conduit, just the ones shown here before I used the conduit frame...I will try to get some tomorrow if that helps
05-05-2016, 06:08 AM
#176
Trailer: Trails West
Don't forget to pick up a tube of spot filler putty. It is used for leveling the very small imperfections. Great stuff for achieving that glass smooth surface you are craving.
Before I started stripping I used a fiber stripping wheel in my drill motor to remove as much of the dried flaky contact cement as I could with that mechanical means. One of these guys... http://www.amazon.com/3M-9099DCNA-La.../dp/B00004Z4DV
After that initial step I ended up using acetone, letting it soak in for a while and only working in cool temperatures in the very early morning or late evenings to slow down the evaporation. I also used a very stiff, heavy fibers, plastic bristle brush to help scrub it off the surface. It is likely to be called a "rough surface" brush, you can find them in the hardware store, sometimes near the paint department.
For some people this will be a first time DIY project working with acetone so I am giving this warning since it is a very important one to avoid the potential for an explosion from concentrated fumes when working in a small area.
You probably do realize you should only attempt to clean one small area at a time with all the windows and doors open as a build up of acetone fumes is very dangerous. Take frequent breaks to let the fumes dissipate rather doing longer work sessions.
Since it is frustratingly tedious work doing a small area is about all one wants to handle before taking a break from it and frequent breaks are important so don't feel guilty about not getting enough done at one time. I had to phase that stripping job in with other projects just to be able to get through it with my sanity intact. Just break it up into small segments and feel good about achieving them as a goal. It will eventually get you there.
05-05-2016, 07:36 AM
#177
Trailer: Home Built
Dave,
Wow...I love this...What happened to the old fiberglass? I have never seen fiberglass so mushy that it is unusable...do we want to use the old interior skin and then work it back to perfection? Or are you wanting to build a new interior skin?
05-05-2016, 10:39 AM
#178
Deep South
Dave,
The wood filler inside the door was what turned to mush, the fiberglass outer and inner layers were okay but the inner layer was very very thin and was difficult to remove. I cut it off in smaller pieces at a time with an angle grinder rather than 1 large piece but it still broke up. The thought did not occur to me to save it to reuse it as I had initially planned to put new wood in the door and re-glass it completely. After the fact, I decided to fill the door with sytrofoam to reduce the weight which I felt would also help to prevent the door from trying to flatten back out along with the use of the metal frame. The conduit makes the rise of the inner door about twice that of what it originally was, so that is why I ran into difficulty on the refinishing work. Here are some pictures I took this morning of the edges around were I epoxied the conduit to the door. After I epoxied it to the door I went over the conduit and door with strips of fiberglass matte to further reinforce it and then put some filler around the outer edge sanded it to smooth it out. I ran out of the standard Bondo filler so I stopped there for the time being. I then painted over it before a camping trip last fall for a temporary fix, but as you can see it is still pretty rough (nothing pretty about it lol)...
So like I said I thought about laying out some matte, wetting it out, let it dry then apply that in place of the plastic currently screwed to the conduit, and glass it in around the sides. If I do that do I need anything in the middle of the void to attach the fiberglass to or will it be fine just glassed to the conduit frame? Then are any of the fillers I mentioned in the previous post better suited for finishing around the conduit edges where it meets the door?
05-05-2016, 07:06 PM
#179
Trailer: Home Built
Dave,
Here's what I would do. I would wax up or tape wax paper or somehow protect the front of the door and lay up 3 layers of glass following all safety and manufacturer's directions. You will then have a perfect bent sheet to affix to the inside ( the back of the newly laid up piece will become the front of the interior side). Easy, professional and you can do it yourself with professional results and it will give you a lot of structural strength along with looking good. May the forest be with you...Fiberglass Dave
05-05-2016, 07:34 PM
#180
Deep South
That is a great idea! Ingeniues that is why I love this forum! One more question. So would you cut it to fit the conduit frame and glass it to the conduit and if so how would you clean up the edges, more glass then filler?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Fiberglass repair
D White |
31 |
06-13-2012 07:15 PM |
Fiberglass Repair
Lisa H. |
3 |
07-29-2008 11:38 PM |
Fiberglass Repair
nrsmd |
7 |
12-18-2005 06:33 PM |
Fiberglass Repair
Legacy Posts |
10 |
03-07-2003 10:59 AM |
fiberglass repair
Legacy Posts |
29 |
01-22-2003 10:18 AM |
