110 volt and 12 volt on the same switch? - Page 4 - Fiberglass RV
Old 04-04-2013, 11:41 AM   #43
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Originally Posted by David Tilston View Post
Raz, DC loads are much more difficult to break. They never cross zero, so the current interrupting capacity must be de-rated for a switch that is designed for AC. As noted by others, there are switches that work for both, but are typically rated lower in a DC service.
And in the same vein, is the effect of getting shocks. (I know, going off track here ) I have had lots of shocks from 120 AC, and though it hurts a bit, it is easy to pull away from as the current alternates past zero. I have had a couple shocks from 130 DC (used as control voltage for equipment in electrical substations), and holy crap does that hurt, it feels like getting hit in your whole arm at one time, and being a constant current, it does not let go as easily.
Anyhoo, back to your normal programming.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-04-2013, 12:23 PM   #44
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by rabbit View Post
It always ceases to amaze me how those who know everything take 3 pages to agree on a single thing.
jack
Hey Mr. Language Person!
Is "always ceases to amaze" what happens at some point after a certain something "never fails to amaze"?
Francesca
Old 04-04-2013, 01:13 PM   #45
David Tilston's Avatar
Francesca
I think it is that sarcasm thing again.
Old 04-04-2013, 01:34 PM   #46
Raz
Raz's Avatar
Vermont
A shocking response
The only way to equate AC and DC is through power dissipation. A 120 VDC source will heat a resistive load to the same temperature as a 120 VAC rms source. While not a resistive load you are close enough and as such will cook to the same temperature with either source applied after an equal amount of time.
As to the disruption of your nervous system caused by each source, I am skeptical that the 8.33 millisecond zero crossing event of the AC source will prove to be advantageous in getting free but will be more that glad to review any data experimentally gathered. Raz
Old 04-04-2013, 01:36 PM   #47
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Hey Schoolmistress, whassup? You arrived a few pages in so you have a right to catch up but I swear it's a blessed relief when some of these stemwinders do finally go completely off topic! It's a switch anyway, har har har.
jack
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Finding 110 volt stranded wire francene Problem Solving | Owners Helping Owners 16 01-03-2010 08:53 PM
110 Volt Wiring Don N Problem Solving | Owners Helping Owners 31 12-09-2008 12:01 AM
12 volt and 110 Legacy Posts Problem Solving | Owners Helping Owners 24 07-04-2003 12:41 PM
12 volt Legacy Posts Electrical | Charging, Systems, Solar and Generators 31 05-23-2003 06:46 AM
