12 Volts provider for testing - Fiberglass RV
Old 06-04-2003, 04:53 PM   #1
Hi!
Here is a little tool that I made to have access to electricity from my battery for testing with 12 volts, while inside my trailer.
I made it with a 1141 (burn) bulb and 2 test wires. After removing the glass and wiring, inside the brass part of the bulb, I soldered the test wires and fill it with hot glue. The grey plastic thing is a piece of 3/8 plumbing speedway that I put for extra grip. But, after testing, it is not needed.
To respect the color code of my trailer the white wire is soldered to the brass part, the negative (and ground), and the black one is soldered to the middle contact, the positive.
Now, I can use any lamp inside the trailer and replace the bulb with this to get easy and switched access to 12 volts.
I did not put a fuse, but of course, one could consider that.
<img src=http://www.fiberglassrv.com/board/uploads/3ede78734f28eAdaptElect.jpg/>
Old 06-05-2003, 04:36 AM   #2
Hi
Thats a neat idea.I like that.:wave
Old 06-05-2003, 09:52 PM   #3
If you have a cigarette plug for power in your trailer, making temp power back through that would be easy as well. Wouldn't even need solder. The power plugs usually have a fuse in them.
Rich
Managing 12 VOLTS D Tharp Care and Feeding of Molded Fiberglass Trailers 1 09-14-2009 09:49 AM
Installing a digital Amps/Volts Meter peterh Modifications, Alterations and Updates 21 09-10-2009 03:37 PM
converting 12 Volts to AC with a Used UPS ? Marty Smiltneek Modifications, Alterations and Updates 3 07-17-2009 02:38 PM
Problems with Refrigerator on 120 volts John Blair Problem Solving | Owners Helping Owners 14 05-07-2007 02:55 PM
JUST TESTING Karalyn General Chat 13 11-28-2005 10:59 PM
