13' Scamp-Fiberglass filler - Fiberglass RV
Old 02-11-2013, 07:28 AM   #1
Ric
Trailer: Scamp 13'
In trying to install our license plate and license plate frame I couldn't fit my fat fingers behind the holder to secure the nut when tightening..finally I decided to remove the plate holder/tailight assembly which I discovered is only attached by four very small cheesy little self tapping screws directly into the fiberglass...no big deal here but...anyway, upon reinstallation I note one of the screws is stripped from its hole...the assembly is secure but for the sake of perfection, does anyone recommend some filler to apply so I can re thread the screw securely or would you recommend a slightly larger screw?
thanks.. I'm a rookie here btw
ps...not too impressed with any fasteners firectly into the glass...
Ric is offline   Reply With Quote
Old 02-11-2013, 08:27 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'd fill a little hole like that with two part epoxy, let it cure , then re-drill it.
Example:
Amazon.com: Loctite 1366072 0.47-Ounce Plastic Syringe Epoxy 1 Minute Instant Mix Adhesive: Home Improvement
The better way to do it is to enlarge the holes, install a plastic insert into the fiberglass, then put the screw into the insert. You can buy these at a auto store in the trim area.
Example:
http://www.amazon.com/Dorman-49258-L...e+bolt+inserts
leak at filler tube on freshwater tank Doghaus Problem Solving | Owners Helping Owners 22 11-03-2012 05:20 PM
Flush Mount Water Filler Deb & Chuck Commercial Posts and Products 3 05-25-2012 05:31 PM
Water filler and cord access Gary Z Care and Feeding of Molded Fiberglass Trailers 3 03-30-2009 12:50 PM
Bed, tire cover & filler shirley munson Classified Archives 18 06-01-2006 01:57 PM
propane bottle filler Legacy Posts Care and Feeding of Molded Fiberglass Trailers 20 02-07-2003 05:01 PM
