15 to 30 amp cord - Fiberglass RV
Old 03-27-2013, 09:21 PM   #1
Trailer: Bigfoot 1981 Trailer
15 to 30 amp cord
On my 1981 Bigfoot, I have installed a pd4045 converter but just left the 15 amp cord in place. Now would like to put in a 30 amp cord. I don't think there will be a major problem at the converter so assume the new wires will go in the same slots as the old wires....correct?
There is a problem on the outside, as the slot for the cord is only large enough for the 15 amp male plug and not big enough for the 30 amp cord. I think that I would need to enlarge the opening and put in a new oversize box. Any hints on proceeding with this? Thanks Jim
Old 03-27-2013, 09:44 PM   #2
FTTRV's Avatar
Trailer: tp
Why not put in a detachable power cord. I did it to my 21ft Bigfoot. My Bigfoot the wire went in around the water heater and I thought sometime the wire could snag a valve or pipe when pulling it out. Now the mice can not get in the trailer.
Chuck
Old 03-27-2013, 10:21 PM   #3
David Tilston's Avatar
Mostly correct. The device that it terminates on has to have a 30 amp capacity as well. You will at least need a new fuse, or breaker.
Old 03-28-2013, 04:56 AM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
It appears that this converter has a 30 amp capacity.
The AC Distribution Panel is r ated for 120 VAC at 30 AMPS.
Progressive Dynamics Inteli-Power PD4045 Series Converter 45 AMP
I'd also suggest putting in a detachable cord. You need to add a plug fixture on the side.
Park Power 301ELRV 30 Amp 125V Standard RV Inlet : Amazon.com : Automotive
30 Amp Flanged Inlet with LED - Furrion Llc F30INS-PS - Electrical Hatches & Outlets - Camping World
Old 03-28-2013, 07:08 AM   #5
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
An even cheaper option.
Hubbell 30 Amp 125V Marine Shore RV Power Cord Twist Lock Inlet HBL303NM | eBay
And then for the female end. This is the correct plug even though they have it labeled as an L6 (250 v) it is in fact an L5 (125v) and clicks right in. L6 and L5 have different shaped tongs. I've informed them they thanked me but still haven't changed their ad.
30 Amps 125V NEMA L6 30R Twist Lock 3 Wire Electrical Receptacle YGA024F | eBay
Old 03-28-2013, 08:33 AM   #6
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Either way, a new RV cordset or the marine-style detachable outlet, I suggest 10 ga wire all the way to the converter.
Old 03-29-2013, 06:51 PM   #7
Problem Solved. I bought a new, very inexpensive 30 amp electrical cord door (which had to be widened just slightly) and just disconnected the 15 amp cord from the converter, replaced it with a 30 amp cord and now have 30 amp service. A very simple and inexpensive project. I should have done this when installing the new converter, but now have ample power to run heavier load appliances.
Scamp Extension Cord fusedlight Problem Solving | Owners Helping Owners 4 09-24-2012 03:56 PM
30 Amp Extendtion cord? How long do you use? iplumb Problem Solving | Owners Helping Owners 24 06-27-2011 05:15 AM
15 Amp power cord question.... Doug Mager Problem Solving | Owners Helping Owners 5 06-19-2011 01:50 PM
30 amp Power Cord francene Problem Solving | Owners Helping Owners 13 01-31-2010 06:50 AM
Extension Cord Donna D. Problem Solving | Owners Helping Owners 10 06-02-2009 03:52 AM
