1973 Compact Jr - Page 4 - Fiberglass RV
Old 07-22-2009, 07:27 PM   #43
Rick Brown's Avatar
Trailer: Compact Jr
That is great to hear. Elaine, Lucy (our Dog, but don't let her know that) and I have a great time in our Jr. We just relax and enjoying the time away from the busy world.
Rick Brown is offline   Reply With Quote
Old 07-25-2009, 12:42 PM   #44
francene's Avatar
Trailer: 13 ft Compact II
Glad to hear you are already enjoying your trailer!I don't know where a O ring is on a propane tank, but I will definitely check the system on my CII before use.
The propane tank that came with my trailer looks old, some rust but not too bad. The fridge and stove worked fine before dissasembly; I expect they'll be the same upon reassembly. I considered replacing the tank for a 'modern' one, but there's gas in the older one. What does this 'certification' mean?
You seem to know much more about propane tanks than me. All I know is about the new ones that you can exchange for filled ones, and in CA there was a regulation that the tank had to have the newer valve type or it couldn't be refilled. Well in WA I think there are similar laws.
Fran
francene is offline   Reply With Quote
Old 07-25-2009, 05:45 PM   #45
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
... I considered replacing the tank for a 'modern' one, but there's gas in the older one. ...
use up gas in old one (if it all seems safe) then trade old one in at one of those trade it propane places. Yes they take the old ones and give you a new one.
They take the old as a way to cycle them out of use and get them disposed of safetly. Don't know if this was a regulation built into the start of the rent tank industry or if the companies just allowed it with mindset that it will open more doors for them finacially as a business (hope the last one) but either way.... its a good way to help keep us all safe by slowly removing old and getting unsafe tanks from trailer parks, back yards etc. etc.
Coach George Jessup is offline   Reply With Quote
Old 07-25-2009, 11:12 PM   #46
Trailer: 1973 Compact Jr
Propane tanks manufactured since September 30, 1998 are required to have an Overfill Protection Device (OPD). Since 2002 only tanks with an OPD can be refilled.
A simple way of determining whether the tank has an OPD is by looking at the handwheel on the valve -- it is triangular on tanks with an OPD, and is not on earlier tanks.
This site has a pretty good explanation: http://www.pioneerrentalsinc.com/opd.htm
As a separate issue, tanks must be recertified every 12 years. The date code is stamped on the tank and is a 4-digit code in the form of mmyy -- for instance 0298 is February 1998. Note that this tank's certification will expire in February of 2010. I mention this because one guy wanted to sell me a tank with this date code! I like to hang on to my tanks and get them refilled because it's cheaper than doing an exchange, and also I know the condition of the valve and POL seat.
To find the datecode position yourself so the valve is facing you -- the date code is on the top of the left valve guard. Here's a picture with an arrow pointing to the datacode area:
Ain't trailers fun? I didn't know this stuff until a few weeks ago when I started looking at the condition of my propane system.
Dana T is offline   Reply With Quote
Old 07-25-2009, 11:22 PM   #47
Glad to hear you are already enjoying your trailer!I don't know where a O ring is on a propane tank...
Fran, the O-ring isn't on the tank, but on my old and out-of-date POL nipple on my equally old regulator. I plan to replace both soon, but for that dinner my only choice was to find an O-ring because there is no store in this town that has the proper two-stage regulators.
The newer tanks have a compliant seat built into them and the POL nipple is just a brass fitting with no O-ring. When you get a new tank take a good look at the "rubber" seat in the valve and make sure it looks good with no slices or cracking. Also feel it and make sure it still has some "give" to it so it can conform to the face of the nipple.
As for "enjoying our trailer" I have a story to tell -- it'll show up in the next several days.
How are you faring with yours?
Old 07-25-2009, 11:35 PM   #48
Unseemly Seams
Here are some pictures of the vertical seams in my Compact Jr. I'm trying to figure out if it's merely a case of the seam tape popping off, or are the seams actually pulling apart. I don't know how tidy Hunter was about filling in the voids when they joined the halves together.
Above the back door:
Above the front window:
Below the front window:
So what do you think? Are the halves pulling apart, or is this normal?
Thanks!
Old 07-26-2009, 08:51 AM   #49
Trailer: 1972 Compact Jr
Dana, this looks exactly like what I discovered when I pulled off the remains of duck tape covering my seams. I mixed up fiberglass resin and filled in the cracks, let it cure, sanded it and I am ready to paint. Since others commented in like fashion when I made the inquiry during the winter, I assume this was a time saving measure on Hunter Industries part. No cracks or deficiencies on the inside
Kent I is offline   Reply With Quote
Old 07-26-2009, 10:25 PM   #50
Hi Kent, thank you for the info. I'll peer under the vinyl quilting at the seams and see if things seem to be OK on the inside.
Old 07-26-2009, 10:44 PM   #51
After our shopping trip last weekend it was time to tidy up the trailer and put our new dishes, flatware, cooking utensils, and etc. away. This is the way the trailer looked before I started tidying:
[attachment=26535:
p1060284.jpg]
I began having problems with my vision -- I just couldn't see putting our stuff in those awful drawers. Drawer liner could hide the Gorilla Glue drips from previous repairs, but the real problem was that the backs were particle board, which at some time had become soaked and now was so soft that cardboard would be an improvement. One consequence of the structural unsoundness of the particle board was that each time a drawer was pulled out, it left a dusting of particle board particles on the contents of the drawer below.
OK, I'll build new drawers, and, while I'm at it, use side-mounted drawer slides so I can get rid of the horizontal stick between the drawers, thus making the bottom one much deeper -- great for pots!
But another problem was the particle board "supporting" the countertop had also turned to mush and there was a huge gap between the swaybacked countertop and the sink on one side, and the cooktop on the other. Any liquid that got on the countertop immediately dripped into the top drawer. I had better replace the countertop too.
Old 07-26-2009, 11:05 PM   #52
I knew the back support for the countertop had dropped down because the bottom of the frame had rotted. My initial plan was to shore it up so it would be good enough for this season. These photos shows the amount of subsidence:
The countertop is attached to the bottom of the fiberglass cooking hood with a bunch of nails and screws to keep the joint tight and inflexible. This makes it possible to caulk the joint, for otherwise with the hood bouncing around as the trailer is traveling down the road the caulk joint would tear. So I needed to remove the hood too so I could attach it properly to the new countertop.
The new countertop turned out to be easy and cheap. I found a local Formica shop that had an old butcherblock pattern countertop on 3/4" plywood that they had removed from a laundromat and would cut to my pattern for $40. Not only that, it would be ready the next day. Done!! And here it is:
I wish everything went so well...
Old 07-26-2009, 11:05 PM   #53
Dana thanks for recording the changes you are making, we are facing similar issues. I have considered side mounted drawer rails as you have but I was wondering how you addressed getting the drawers to stay closed. The people I talked to suggested the center mount rail, with plastic fitting, allow some flexibility to allow the drawer to be lift up out of the recess that keeps the drawer from sliding on an even plane. How did you address this? I also have the particle board backs to the drawers but it is the pine sides that are wearing. I am exploring adding insulation which you already have.
Old 07-26-2009, 11:12 PM   #54
The cooking hood had been riveted to the trailer top in seven places. Six of the rivets drilled out easily, but the one nearest the door couldn't be drilled out from the inside. Because I could reach both ends of the skirt bolt centered over the door, I started there and worked my way around to the offending rivet. Who says it takes two to work on the poptop skirt? Well, yes, it did take two in our case: me doing the bolts and my wife taking the pictures.
Old 07-26-2009, 11:40 PM   #55
Our plan is to mainly dry camp, aka boondocking, so 110V service will not likely be available. I really didn't like the look of the 110V power cord, and I didn't like how it was implemented -- I would prefer a socket on the trailer to the permanently attached cord.
My wife and I had discussed how we wanted the trailer set up, and the result was that lighting would be 12V, cooking and refrigeration would be by propane, and if we had 110V available we would like an easy way of bringing it into the trailer for running our battery chargers for the cameras, phones, and whatnot. Thus the 110V light over the streetside bunk and the outlet under the table were superfluous.
I also wasn't too keen on depending on a 36 yearold circuit breaker, especially after seeing how the 12V to 110V inverter had been repaired by stuffing aluminum foil into the fuse holder.
So I took it all out: power cord, breaker, light, and outlet. The really startling thing was that when I opened the junction box and pulled on the wire crimp on the neutral (white) lines, it pulled right off! Great -- just what we need, a bad connection on the neutral line. And it had been that way ever since the trailer was built.
Our plan is to carry a standard extension cord, and when 110V is available run it through the grommet in the floor that the original power cable went through. The rest of the time the grommet will be plugged with a sink stopper or something.
Sure tidies up things when that 100V cable is gone:
Old 07-26-2009, 11:45 PM   #56
The next item was the heater. I needed to recaulk the seat around the vent, but everything was frozen in place. I managed to pry the inner vent out far enough that I could slip a 2x4 about 20" long into the angled hood of the vent, and use that to rotate the inner vent back and forth and break loose all the mud wasp nests and rust. The picture shows the largest of the 5 paper wasp nests...
1973 Compact II by Hunter Darrel Smith Modifications, Alterations and Updates 84 10-02-2015 01:25 PM
1973 Compact II For Sale $1,100 Ed Harris Referrals: Molded Fiberglass Trailers 1 06-12-2010 05:32 PM
1973 Compact JR EBAY Robin G Referrals: Molded Fiberglass Trailers 6 06-12-2010 12:42 PM
Oh the joy and disappointment of a 1973 Compact II CherylT General Chat 4 09-28-2009 04:46 AM
1973 Compact Jr. 13'-New Price Blossom S. Classified Archives 4 06-28-2006 11:34 AM
