1974 Amerigo FG-16 "Alice" Gut & Re-Build - Page 4 - Fiberglass RV
Old 10-19-2015, 07:48 PM   #43
Trailer: Amerigo FG-16
You see, now you are at the fun part, You can do anything you want! :-)
I carefully removed all of the factory panels so that I could use them for templates. I found some raised paneling at Menards. It is medium shade of brown but with the texture should look good. I was considering that headliner stuff but it was too spendy and I thought it would be hard to keep clean. I have a bunch of pre-finished maple boards that I plan to use for the cabinetry. I don't know why you would have to paint plywood, If you like the wood look, you could get plywood with a wood veneer and just poly it...However you envision your camper...
Mr.Stu is offline   Reply With Quote
Old 10-19-2015, 07:52 PM   #44
P.S. I use those channels for floor support. I cut and fit wood support pieces then ran stainless screws through the flooring to secure them to the underside of the new floor.
Old 10-20-2015, 06:08 AM   #45
Kai in Seattle's Avatar
Hi,
You're right, the fun part is coming up. Paul has looked over all your photos and read all your posts numerous times; you've been so helpful and inspiring step by step! Thanks, he got all the old ply out (and much of that "smell" went with it) and has new coming (three sheets); first he needs to clean up the fiber floor and fill a number of odd holes before he covers the area with new ply.
Do you think we should leave any "weep holes" or "water channels" below the new ply, or would that just be asking for trouble?
Old 10-20-2015, 05:38 PM   #46
Definitely keep the weep holes!!!!!! If you get water in there under the floor and it cannot escape or get air to dry out, all your work will rot away and that would be sad :-(
Old 11-09-2015, 01:41 PM   #47
Seems like forever since you updated your work...anything going on there? Seems Paul works for two hours, then tries to clean up the garage for four hours...like most projects, he takes out so many tools and supplies it gets heaped to the point of paralysis! So far, we discovered another area of rot, the old battery box inside with a big hole in the fiberglass wheel well next to it. That's pulled out, too, and now the smell has diminished enough my face doesn't feel like it's burning when I peek inside. Hoping one of the recommended mold-products/odor killers will help out when we get a little further on.
Old 11-09-2015, 07:28 PM   #48
The work continues, although at a slower rate...
It has been getting colder here and dark before I get home so I have only been doing work on the weekends when I have time.
I did just finish installing all of the LED running and brake lights and have begun the internal wiring. I have already gone through 160' of low voltage wire and ran out...have to get another spool!
With the new paint job and new exterior lighting, it's starting to look cool .
I also installed a brake light bar that flashes when you hit the brakes. If someone rear ends me insurance won't cover it because it is so old, which would really bum me out after all the work and $ I have put into this thing. I will post some pics when I get a chance.
My battery box was the only wood that was not rotted out in mine. The FO had his battery in front of the wheel well for some reason. I plan to put that box to work. I am trying to run as much of my wiring between the walls and the false ceiling as I can.
It is definitely more fun installing new stuff than to pull out the old rotted nastiness!
Have fun!
Old 11-09-2015, 08:23 PM   #49
Exterior lighting and wiring pics
Old 11-09-2015, 10:48 PM   #50
Oh, yes. What color(s) is it painted? Can't quite tell.
Lights look so good!
Old 11-12-2015, 07:56 AM   #51
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
doing a great job. love it all keep it up
MRClaus is offline   Reply With Quote
Old 12-18-2015, 08:06 PM   #52
Trailer: Shopping
Keep it up there is one for sale here for 2500 that need minor work. I am afraid to take the leap since its so old now.
limp1144 is offline   Reply With Quote
Old 06-12-2016, 06:22 PM   #53
2016-Finally Back at it!
Boy, it is a lot more fun putting in new stuff than the gut was. Now that old man winter is a memory and the weather is more agreeable I am finally back to my re-build.
I started off with putting in the internal wiring with Desk pass-through grommets for the wiring access holes. Next, I tackled putting in new gas lines and hooking up the e-brakes to my new harness. I installed semi-truck grade wiring connections between the trailer and the tow vehicle.
Today I began the flooring. In the rear half of the trailer, I first installed a breathable underlayment with some nice vinyl plank flooring that I picked up.
I used a pneumatic porter cable stapler along the four edges to hold it all together. And that is where I am at so far....
Old 06-12-2016, 06:28 PM   #54
More pics of "Alice"
Here are the rest of the pics from my latest progress. I wish I had more time than the weekends!
Old 06-12-2016, 06:31 PM   #55
color
I painted the camper bright white...I used marine deck paint via a compressed air driven paint gun. Sorry it took so long to reply.
Old 06-13-2016, 11:02 AM   #56
MR> STU! There you are! Mr.Claus! HI!
That's some fine-looking work you're doing! I'm so glad you're able to get back at it, and I so commiserate about having only weekends to do it.
We've had a long string of plusses, and today Paul hooked up and towed PEANUT down to his old job to show her off at this stage, which is new tires, repacked wheel bearings, brakes good, electricity all in, galley "done," closet done, front closet/loo ("The Putin") done...the two back bed bins are done except for the tops, which he'll do in the next couple of days. THEN the front settee area, the rest of the reverse-stained (pickled) thin plywood wall panels (surprisingly simple) and we're finished except for the hundred tiny minor things, like putting a screw here or a tie-back there.
GRANTED, we have no water lines or propane. Neither of us could face adding water other than some bottles for immediate consumption. I never wanted propane anyway.
We sat out in it last night for two hours, just smiling and admiring and patting ourselves on the back, boy are our arms sore!
Then today he got three-dozen assorted doughnuts to start thanking the guys at his old job, and rolled off before I was even dressed, so I didn't get to see him go.
Oh, well! He's done the lion's share of the physical work, though I have carried
my own weight in planning, sourcing, complaining and correcting, some of my strong suits.
GUYS! Good to see you here again!
BEST!
Oh-- PEANUT: the inner configuration where it's wider at both ends and narrows in the middle between the (once-fridge) closet and galley... AND -- it's a SHELL with TWO NUTS in it.
Family members voted for PEANUT, and I couldn't disagree.
Will post photos when Paul gets them developed, apparently around the 12th of Never.
Semper ubi sub ubi.
amerigo
electrical gut-out and upgrades Charley Modifications, Alterations and Updates 0 10-19-2011 07:35 AM
Considering buying a 1977 Trillium 1300 - has anyone done a gut rehab? Kyle F. Problem Solving | Owners Helping Owners 7 07-27-2011 05:47 PM
Alice Lake Provincial Park, British Columbia Brian Van Snell Camping, Campout Reports 2 05-13-2010 09:05 AM
The "Silkstone" build Ian S. General Chat 13 07-02-2008 11:52 AM
