1974 Boler Resto. Oops, I did it again... - Page 11 - Fiberglass RV
Old 02-03-2013, 02:16 PM   #141
Robert Johans's Avatar
Trailer: Nest Caravans
Some close-ups...
Old 02-03-2013, 02:21 PM   #142
Couple more...
Old 02-03-2013, 03:00 PM   #143
slavandheather's Avatar
Trailer: 1978 Boler
Robert,
Absolutely fantastic work! Thanks for sharing this entire project!
Slav
slavandheather is offline   Reply With Quote
Old 02-03-2013, 07:23 PM   #144
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Absolutely gorgeous! Masterful!
D Davis is offline   Reply With Quote
Old 02-03-2013, 09:33 PM   #145
Trailer: 17 boler
Hi Robert
amazing job, i had a question about the paint.
Did you put the slick sand primer right on the fiberglass or did you have to use anything first? also which type of paint did you use after the slick sand primer?
thanks
Andrew
andrew78 is offline   Reply With Quote
Old 02-04-2013, 06:18 PM   #146
Thanks, everybody...
Andrew, I have my trailers painted by professional auto body men, so I don't know all the exact details. However, yes, the Slicksand (awesome product!) is applied directly to the carefully prepped (i.e. sanded and cleaned) fiberglass.
The lacquer paint on top is "Diamont Arctic White;" the bottom, "Diamont Bamboo Pearl" to match my wife's car. The bottom is also coated with "Raptor" tintable truckbed liner to protect against road debris.
Old 02-04-2013, 06:20 PM   #147
A quick shout out and tip o' the hat to fellow forum member Norm (Honda03842) for his recent help.
Old 02-04-2013, 06:28 PM   #148
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Robert, thanks much for the detailed posts.
Makes them much easier to copy!!! Lol
Detail and craftsmanship second to none.
Fred
FRED SMAILES is offline   Reply With Quote
Old 02-04-2013, 06:45 PM   #149
Trailer: 1979 Scamp 16- side bath
Virginia
Robert-
Can you show us a photo of how you setup the rooster latch inside of your doors and how their position relates to the "finger holes". I really like the look of that setup-- and of course the idea that doors won't open on rough roads.
Thx
Ryan P R is offline   Reply With Quote
Old 02-05-2013, 01:56 PM   #150
Trailer: 1978 Boler
High Density RV Seal / Hulliner
Robert,
Could you share what high density RV rubber/seal you are using between the frame and body on your project? Is it the foamy stuff that is used to eliminate drafts in house windows (such as made by M-D Building Products) or something else entirely? I'd like to use something like that on my Boler to eliminate body damage that was caused by the original frame.
Having a hard time finding anything that would not compress totally flat. I am wondering if the kind of seal used under truck canopies would work, such as this one here.
On another note, I got samples of Scamp's wall covering and three colors of the much mentioned Hulliner (Hull Liner, Headliner). We really like the Hulliner in light gray, as seen here, but I can't find it under $19 per yard, which is kind of steep compared to Scamp's offering. Have you been able to find it cheaper somewhere?
Appreciate your help always.
Slav
Old 02-09-2013, 03:02 PM   #151
Sorry, Ryan, no photos of the rooster catches. But I can tell you that that they are centered with the finger holes, about an inch to one side or the other. Poke a finger in, then curl to open the rooster, and pull! Simple. BTW, if a drawer or cabinet is oriented to my left side, I use my left hand. Therefore, the rooster is on the right of the hole. When oriented to the right, I move the rooster to the left of the hole.
Slav,Yes, I used the same foam seal as for camper shells.
For Hulliner, try PerfectFit.
5593/154092/Marine-Carpet-and-Hulliner/Hulliner-and-Headliner-72.html
Old 02-09-2013, 03:40 PM   #152
Trailer: 1978 Boler
Robert, thanks for the help!
Old 02-15-2013, 10:24 AM   #153
Trailer: 1976 Scamp 13 ft
Wisconsin
Hi Robert,
I have truly enjoyed reading and viewing this post. It has me wanting to do a complete rebuild myself. Just one question, where did you put the battery?
Thanks,
Daniel
1976 Scamp 13'
2001 Ford Expedition (Overkill!)
Daniel H is offline   Reply With Quote
Old 02-15-2013, 11:24 AM   #154
Take a look at these...
boler
new boler owner resto Siris Modifications, Alterations and Updates 72 08-18-2014 05:23 PM
73 Boler interior resto Burke R. Modifications, Alterations and Updates 41 03-24-2014 08:54 AM
AB | old boler resto project for sale $1000 Siris Classified Archives 3 08-16-2012 04:48 PM
Shower in 1974 Boler Resto David Konduc Modifications, Alterations and Updates 8 02-04-2012 02:15 PM
Our 75 Boler resto also Debbie H Modifications, Alterations and Updates 5 03-24-2008 01:41 PM
