1974 boler restoration (start to finish) - Page 4 - Fiberglass RV
Old 10-21-2012, 01:15 PM   #61
ok everyone im back again i did some more work on the cabinets
i did mess up the counter (when i glued the one opening shut and finished it off i neglected to wate till the urethane glue was completely dry and had some large bobbles. so i got to re-sand fix and than paint again graaaaa.)
ok so i also placed the cabinets inside the boler to do a test fit and i couldn't help to take a bunch of pictures
i do need to fix so fit issues due to the flooring but its easy enough
Siris is offline   Reply With Quote
Old 10-21-2012, 01:34 PM   #62
I love that color, I see so many possibilities for decorating....
Old 10-22-2012, 10:48 PM   #63
Harlequin's Avatar
Trailer: 1991 Scamp 13'
Virginia
so if the other one was mario, is this gunna be a luigi? the green is perfect.
Harlequin is offline   Reply With Quote
Old 10-22-2012, 11:05 PM   #64
No luigi is not my hero
Mario is still going to be on it
But yoshi is the theme
Old 10-23-2012, 12:52 PM   #65
Harlequin's Avatar
Virginia
oooh, neat! good color for that, too I have a nephew that loooooooooves yoshi.
Old 10-23-2012, 03:48 PM   #66
ya a lot of kids now mario and yoshi
that's what makes this so fun
driving down the road and hearing kids say look look its mario
its just fun
my boy thinks its pretty cool to
Old 10-25-2012, 08:01 AM   #67
my brother is an electrician and he told me to get this led lighting
its like a rope light but its flat waterproof and extremely easy to use
so i ended up ordering 5 m of the stuff for only $10
i tried it and i fell in love
its a great accent lighting choice
so here is a few pictures of it
(i also ordered bright white that im going to use in my house for under my cupboards) and also the closet in the boler
i also paint the edging that the floor does not cover black and made myself two edging peaces that i painted black to go down at the bottem of the closet and the step up to the table
Old 10-28-2012, 04:51 PM   #68
Trailer: 75 boler
Saskatchewan
your attaching the upper cabinets and lower cubboard with urathane glue right. but excatly how are you you doing that it looks like in the recent pics that you never removed the ensolite. Im considering doing this as well but don't exacly know the procedure.
sheephills is offline   Reply With Quote
Old 10-29-2012, 08:11 AM   #69
Originally Posted by sheephills View Post
your attaching the upper cabinets and lower cupboard with urathane glue right. but excatly how are you you doing that it looks like in the recent pics that you never removed the ensolite. Im considering doing this as well but don't exacly know the procedure.
the upper and the closet i have decided not to urethane and the only reason y is that i may have to paint the cabinets again if i sell this one. its a lot easier to take them out scuff them up and than spray them if there not glued in (im using bolts with snap caps for a clean look)
but the answer to you question.
to urethane the panels on it is a must to use a two part urethane otherwise the strength is just not there. first outline on both sides on the ensolite where the panel is going ''i suggest using a dry erase marker''.
then cut out the ensolite in about a 1 cm width inside both the lines (that way when the cabinet is on you wont see any glue and it still looks finished). than sand the 1 cm grove with any grit of sandpaper lower than 320, as well as the peace your gluing. i use a 1.5 min glue so i don't have to stand there long but that means you have to be quick. (there is 4-5 different dry times of the glue you can get)
apply glue, stick, hold and your done
the glue can be painted and its sand able
you can use it to fill small holes, cracks,
even glue other parts onto the boler
proform glue is what i use pf7773
and the glue gun is 807n
hope this helps
Old 10-29-2012, 10:05 PM   #70
Trailer: 75 boler
Saskatchewan
The step by step instruction you left sure helps thanks a whole bunch. project looks good. also was wondering do i have to remove the frame from the boler to replace the floor.
Old 11-06-2012, 11:20 PM   #71
Luis's Avatar
Trailer: Boler 1300 79'
new project here
Hi all. Newbie restorer here.
Also from Alberta, will be looking for advise and tips.
cheers.
"an ambitious Man"
Luis
Luis is offline   Reply With Quote
Old 11-07-2012, 05:18 AM   #72
Trailer: Boler American
led lights
Can you share with us, where did you purchase these led lights?
JEAN-L is offline   Reply With Quote
Old 11-13-2012, 09:06 AM   #73
Trailer: 1974 13 ft Boler
windows
if anyone wants the old windows or roof vent or even the icebox
i would like to sell them just make me any offer it will help with funding the new boler
here is a picture of the other boler i was working on till i found this one. i would sell this for cheep to if you want to come get it
it is moble and has all the cabinets the windows are broken but i now where there is a few not being used lol.
not the one with the mario that's the other on i did i just wanted to put a picture of it up lol
Did you ever sell those windows?
thanks
Jeff
67hardtop is offline   Reply With Quote
Old 12-02-2012, 08:05 PM   #74
Pascal's Avatar
Trailer: 1975 Boler 1300
windows are out ((damn rivets)this boler is going to be rivet free).
side windows are now cut to the new size
roof vent is also cut to the right size but now i need to build a frame to lift the new fan so the molding on the inside does not stick out.
took out some more garbage and worked in the insolite a little(needs alot of work).
Nice project. Can you tell me the side window sizes? I want to replace the ones in my 75 Boler and I think that they should be 20" x 26" but I'm concerned with interference with the closet.
Pascal is offline   Reply With Quote
boler
BC | 1974 13 f Boler for restoration $2500 jaybratt Classified Archives 5 10-26-2012 05:23 PM
Compleat boler restoration a to z Siris Modifications, Alterations and Updates 20 02-03-2012 10:42 PM
Boler Restoration Kevin Dunno Modifications, Alterations and Updates 2 06-21-2009 04:42 PM
1974 Winnebago Restoration Glenn S General Chat 7 05-04-2008 09:18 PM
Heres the start of the restoration Legacy Posts Modifications, Alterations and Updates 6 02-21-2003 02:24 PM
