1974 Boler Restore - Penticton BC - Fiberglass RV
Old 10-14-2012, 11:28 AM   #1
Bcboler's Avatar
Trailer: 1979 Bigfoot
So I was given a free 1974 boler in very rough shape. I have never done any work like this before and look forward to the challenges and rewards ahead. Please offer any suggestions and tips you can. I'll start with a few pics as to where I'm at now. Hauled it from the woods, cleaned it up, frame is now off, appliances are stripped out, and half of insulation is off (po sprayed thick foam insulation everywhere - inside and out that all must go). Frame being fabricated next week, and I picked up a 30 yard roll of high grade marine vinyl to skin the walls with. Now to figure out what to insulate with...quite the debate on that one. I'll need super 90 glue to attach whatever goes up as we hit close to 40 Celsius a lot of the summer in the okanagan valley and don't want it to delaminate.
Let the games begin!!'
Bcboler is offline   Reply With Quote
Old 10-14-2012, 11:48 AM   #2
Carol H's Avatar
Ira, that is a find!!! That should keep you busy for most of the winter ;-)
If you havent already found it Boleramma.org is a great place to start when in need of help or advise as to what best to use on the Bolers.
Old 10-14-2012, 11:53 AM   #3
Bcboler's Avatar
Also, this guy showed up in the mail this week. $12 shipped to Canada!
Old 10-14-2012, 02:47 PM   #4
Carol H's Avatar
Thats it your hooked! :-))
You will have to come down to the coast at the end of June next year and show off your work at the BC Glass Eggs Fiberglass trailer meet in Mission.
Old 10-14-2012, 04:42 PM   #5
Rick Mooyman's Avatar
Trailer: 1971 Boler
Looks like you got as much to do to your Boler i do with my new project. I am going to use Reflectix insulation from Home Depot, but not sure what to use over it yet as the finish for the interior. I dont like the Scamp rat fur and Ensolite is way too expensive. Good luck with you project I will be watching waht you do as you go along.
Rick
Rick Mooyman is offline   Reply With Quote
Old 10-14-2012, 05:39 PM   #6
Carol H's Avatar
Trillium in the US sells a wall covering & t mouldings that would work. You could also contact Trillium in Calgary as they may have some of the same as well.
Old 10-14-2012, 09:37 PM   #7
Bcboler's Avatar
I picked up some ecofoam from Home Depot today after seeing it in action on a YouTube video by KevinHenry61. Site says its non longer available there, but I happened to find four 6x9' rolls left so I bought them all. I plan on gluing the foam to the Fibreglass and high grade marine vinyl to skin it. I'm very nervous to do this job but look forward to the challenge. I picked up some of the lepage Eco friendly contact cement to hold everything. I can't seem to find the temperature rating on it, I really need to find something that will withstand temps over 40 Celsius. Can't seem to find anyone that sells 3M Super 90 around here, that I know will do higher temps. If anyone has any tips to applying the vinyl and deal with the seams, I'm all ears.
Old 10-14-2012, 11:33 PM   #8
Bcboler's Avatar
This is the Eco friendly water based contact cement I'll be using to glue my Eco foam and high grade marine vinyl combination to the boler walls and ceiling:
http://dashboard.lepageproducts.com/...9813bb8bfa.pdf
It has a high operation temperature of 70C, so if you live in a hot climate like I do, it's something you have to consider as Super 77 spray from 3M will break down around the mid 30's Celsius. Water based so no fumes, easily clean up with water, 3x coverage of solvent based cements, and requires no clamping. Ran some tests tonight, so far it works like a charm!
Old 10-14-2012, 11:44 PM   #9
Bcboler's Avatar
Here is a pic of the products I'll be insulating the boler with:
Ecofoam (flooring underlay) from home depot then high grade marine vinyl glued with Lepage eco contact cement.
Won't add too much thickness, be better than the old gross ensolite/spray foam combo the po had in there, easy to wipe down, and nice and neutral from a design viewpoint.
Old 10-18-2012, 09:24 AM   #10
Trailer: Boler 1700 '79
Marine Vinyl
Hi, I was wondering where you purchased your vinyl from? Thanks
Crackedegg is offline   Reply With Quote
Old 10-18-2012, 12:04 PM   #11
Gilda's Avatar
Trailer: 2011 Scamp 13'
I'd caution you to beware of black mold (if that is what it is) in your Boler. This can be nasty stuff for your health. Find out what precautions you need to take when breathing black mold.
Gilda is offline   Reply With Quote
Old 10-18-2012, 10:56 PM   #12
Bcboler's Avatar
No black mold in the boler, the black in the photo is just the black backing of the ensolite. It's on their good, while peeling it off, it has left bits. The original adhesive was so strong, you can still smell it fresh as if it was just put on. After almost 40 years, I'm impressed with how it's held up. Too bad it all has to go due to the gross spray foam everywhere. And I mean everywhere.
I got the vinyl locally off the Internet from a guy who started a business and bought an insane amount of it, shut his business down, and is now selling off at cost. I got a 30 yard roll for only $150. If you're in the okanagan valley or Calgary he still has some left. Not sure how much it sells for elsewhere, but I knew $5/yard was way too good to pass up.
Old 10-26-2012, 08:25 PM   #13
Bcboler's Avatar
Some pictures of the newly fabricated frame that will be ready to go in a couple of days. As you can see, about a 100x stronger than the terrible thing that came off. Bottom picture is of course the old one. Just a few more cross pieces to take care of
Old 10-27-2012, 10:52 AM   #14
Nice work! I had my frame inspected for my 1700 and the rv techs said it was good to go but I would rather a new frame as I'm doing a complete reno on the unit.
Old 10-30-2012, 07:57 PM   #15
Bcboler's Avatar
Just got the new frame home this evening. It's pouring rain in the okanagan valley and I'll have to wait a few days until I can get it inside the garage ready for paint then back under the coach. Then the real fun/work begins!!
Here's a few pic I snapped of the old one. Glad I replaced it. The fabricator was a friend of one of our customers and he did the entire fabrication for $1700. Great deal given the material and all his labor.
Old 11-01-2012, 11:10 AM   #16
Bcboler's Avatar
Bigger better boler
Old 11-03-2012, 07:02 AM   #17
Originally Posted by Bcboler View Post
Bigger better boler
Ain't that the truth!!
Old 11-03-2012, 07:19 AM   #18
Borden's Avatar
Name: Borden and Carole
What will the new frame weigh in at as compared to the old?
Looks a lot better
Our postage stamp in heaven.
Old 11-03-2012, 07:33 AM   #19
Borden's Avatar
Some great ideas at this site for frames; even an aluminum frame project at this site posted
Old 11-03-2012, 09:09 AM   #20
Bcboler's Avatar
He said the frame would be aprox 300 lbs, so still very light. I just heard that there is somebody in my area that is fabricating aluminum frames, oh well, this restore is already a bit of a money pit, best to stick with this route. One shop quoted me $1300 plus our %12 tax just for the A frame welded to the chassis, $1700 tax in for this was a bargain. Helps to ask around, a friend of a friend type deal. Awesome that he wasn't just a welder, but makes trailers! He actually takes 5th wheels and converts them to tow trailers. The result, a used trailer you can buy at %30 less compared to travel trailers (in these parts anyway), with an insane amount of storage. Interesting and talented guy. You never know who you'll meet out there. This restoration is giving me a chance to meet some great people so far.
13' 1974 Boler tremmert Problem Solving | Owners Helping Owners 4 07-19-2012 04:03 PM
Restore boler 78 Yvon Chayer Modifications, Alterations and Updates 36 04-22-2012 09:28 PM
13' 1974 Boler Dana T Classified Archives 1 04-27-2009 10:20 PM
1974 boler iaian Care and Feeding of Molded Fiberglass Trailers 14 10-06-2007 07:29 PM
1974 Boler Legacy Posts General Chat 3 08-15-2003 10:37 PM
