1978 Boler Complete Restoration / Rebuild - Page 15 - Fiberglass RV
Old 06-09-2014, 10:35 AM   #197
I screwed hardboard on the outside matching the profile to give it shape. Then added either bondo or gelcoat (bondo is not the best for this as in bigger patches it can crack after a while). Then I added a layer of fiberglass on the inside. Let it dry, then another and so on. I didn't use a form on the inside, as the fiberglass took the shape of the outer mold.
Nelmes is offline   Reply With Quote
Old 06-09-2014, 10:46 AM   #198
slavandheather's Avatar
Trailer: 1978 Boler
Sounds good, thanks.
1978 Boler - work in progress...
slavandheather is offline   Reply With Quote
Old 06-10-2014, 09:32 AM   #199
A little rain and wind yesterday wasn't enough to give me confidence, so I pulled out the hose. The product fixed it. It was a leak that only appeared with heavy storms.
Old 06-10-2014, 12:03 PM   #200
Trailer: 1978 Boler
I think I missed you mentioning where this leak was. Was it around the front window?
Old 06-10-2014, 01:42 PM   #201
The front window and seal where new last year, but when the shop went to install they "upgraded" to marguard, a much more flexible and scratch resistant material, the only problem is on the freeway the wind blew it out of the seal (downside to flexible). I managed to get it back in, and now travel with a rock guard on the window. I have since noticed that during storms the front window leaks. With everything appearing to be good I have had trouble finding the issue and changing the front window seems like an expensive solution as it is still new.
Old 06-12-2014, 10:30 PM   #202
Trailer: 1978 Boler
1st Window
Started fitting the 1st window that needed FG work. As messy as it looked before, it looks quite decent now. And after some sanding and body filler I think it will be quite nice.
Here you have the modified cut-out followed by window sitting in it:
Will get to work on the opposite window and kitchen window next....
Old 06-24-2014, 05:14 PM   #203
Trailer: 1978 Boler
Side Windows
After a bit of a mess with the first side window, I decided to use scrap FG for most of the work on the opposite side window and the kitchen window. Still did the smaller corners with fresh FG, but in hindsight should have just used scrap pieces for those too. Anyways, here are some pics of the kitchen window.
First, securely screwed in the scrap piece followed by basting with FG on the inside:
Next, traced out the size and cut out the new opening. Turned out pretty good and fits well after some fine-tuning:
With the bigger side window I first secured the long scrap piece before basting from the inside. The corners were done from scratch:
Once everything was well cured, I again traced out the outline of the window and made the cuts. Fits pretty good.
There is more fine tuning to be done and of course the external body filler will be needed once I'm ready for that step.
I think I'll tackle that busted upper rear corner of our Boler, at least from the inside for starters.
Old 06-24-2014, 05:21 PM   #204
Luis's Avatar
Trailer: Boler 1300 79'
Nice! ill forward pics of my windows over the long weekend!
Luis is offline   Reply With Quote
Old 06-24-2014, 05:22 PM   #205
D White's Avatar
Trailer: Trails West Campster, CampStar, Uhaul, Fiberstream
You need to ditch and put 2 layers of fiberglass on the outside too, or it will show and possibly crack....fiberglass Dave
D White is offline   Reply With Quote
Old 06-24-2014, 05:44 PM   #206
GMike A's Avatar
Nice work Slav. Listen to Dave the FB man. Looking GREAT
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 06-24-2014, 07:27 PM   #207
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Good job Slav. Just a note for anyone needing scrap FG pieces. I picked up 12 window cut outs from a shell maker for free. Done many mods with them on the dune buggy.
Old 06-24-2014, 09:43 PM   #208
Trailer: 1978 Boler
Thanks everyone for the good words! I guess it will be more work, but will take Dave's advice. Don't want all this and upcoming hard work to bite me.
Slav
Old 08-21-2014, 09:47 AM   #209
Trailer: 1978 Boler
Belly Band is Off
Finally got a day I could put some more hard work into the Boler. First, wanted to get that belly band taken off and see how things looked underneath. It will need to be restored and shined up for sure. I plan to use stainless screws (anyone know if stainless and aluminum will react unfavorably?) instead of rivets. Not sure yet if only drilled into the top or all the way thru. Guess it would be cleaner to not drill thru the bottom of the band.
As expected, under the band could almost make a guy cry. Filthy and kind of rotten in places. This one is on the driver side of the rig:
And this one to the right of the door. You can really see how gross and frayed things look:
What I'd like to do with this is clean it up as good as possible (any suggestions? acetone? water? soap?) and put a bead of something into the gap just to seal it up from future gunk buildup. I was thinking of some liquid rubber, if there is such a thing. Or there is that tar in a tube for roofing. Or would silicone be good enough? Doesn't need to be pretty, just functional.
Thanks for any tips!
Old 08-21-2014, 11:27 AM   #210
Chris73's Avatar
Trailer: Minit
My trailer is very similar to a Boler. I was curious as to how the frame project came out. Did you remove the rust and repaint? I found a crack in my frame (1973 trailer), so I'm juggling different ideas: fix/strengthen or have a whole new frame made. Not sure yet. It looked pretty easy to separate the body from the frame on yours. I don't think mine would be quite as easy. What is the floor? Fiberglass? Mine is a thick, plywood floor, attached to the body via bolts, rivets, and fiberglass overlay. Interesting design. =P Thanks!
Chris
Portland, OR
Chris73 is offline   Reply With Quote
boler
The 1972 Boler Rebuild bomni Modifications, Alterations and Updates 9 10-12-2013 10:13 PM
1978 Trillium 4500 restoration ... freddo411 Modifications, Alterations and Updates 64 10-10-2013 04:58 PM
Newbie rebuild 74 Boler -13 Firesurfer30 Hi, I am.... 1 06-13-2012 06:43 PM
1974 Boler Rebuild KyleRuppel Modifications, Alterations and Updates 33 06-04-2012 09:17 AM
Complete Newbies - Just got our 75 13 Foot Boler TODAY!!!! MelFrank Hi, I am.... 4 05-20-2011 07:26 PM
