1979 Scamp 16' Project - Page 7 - Fiberglass RV
Old 05-21-2013, 09:38 PM   #85
Trailer: 1979 Scamp 16- side bath
Virginia
Today I went from not understanding how to thread or operate our sewing machine (it's been in the attic the entire time).... to making 3 blackout shades/panels for our Scamps 3 14" square windows. Besides sewing on some buttons, and hemming a few pairs of pant legs 3-4 years ago I haven't really sewed anything since middle school HomeEc class.
Nevertheless I am very pleased with the shades so far. I used red outdoor fabric (olefin fibers) and RonLoc blackout lining. They attach to the top of the window with Velcro. Hook side is self adhesive onto the aluminum frames, the loop side is sewed onto the back of the fabric- you can buy it a mixed pack like this, it's called "DECOR". At the bottom of the shade is a small pocket with a wooden 1/2" dowel rod. The dowel rod helps to roll up the fabric evenly. They are also notched on the side to accommodate the window cranks so that the shade can fit perfectly flush with window frames to block out all light. I will add a few spots of strategically placed Velcro on the bottom to really keep them closed up tight.
I will make the shades for the remaining windows in a similar fashion, but may modify the design a little bit on a few of the others so that I can just raise the blackout lining under the red fabric to let in some light, while still retaining complete privacy. Or I might just create a method to lower just the top of the shades a few inches for similar results. I have many ideas on how to do both of these things, as well as methods for keeping the rolled up shades in place-- I just need to experiment with them a bit and make up my mind.
The folded/cut white paper is a demonstration of how I created the notch for the crank hands posts. I used a backstitch around the pimento of the notch to hold back the fold parts, and then followed it up with an edge-loop-stitch (not sure if that's the proper term) that goes around the edge of the opening. I followed that up with some Fray Check and paid special attention to the inside corners- as they cannot be hemmed properly using this method.
Ryan P R is offline   Reply With Quote
Old 05-22-2013, 06:56 PM   #86
Great job Ryan!
I'm envious. I don't sew.. or should say I won't sew. The last time I used a machine I ran over my thumb with the pressure foot and literally stitched my thumb. Sigh.
Old 05-22-2013, 08:04 PM   #87
GMike A's Avatar
Nice job as usual. I have 19 older Singer Model 501 and 503A machines that I am restoring. Last model that Singer made with Metal parts. These are work horses and an awesome machine with double needles and lots of stitch patterns for its era.
Another one of my many projects. Lots of men sew.!!!
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 05-22-2013, 08:58 PM   #88
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
Mike-my mother had one of those machines! My wife fell in love with it, so I had to find one for her. My granddaughter now uses it.(Of course my mother's was regeared to commercial speed-scared everyone away from using it).
Dennis
Dennis Clinton is offline   Reply With Quote
Old 05-22-2013, 11:26 PM   #89
Beautiful work on the drawers. Do the slides come in lengths that just happen to work well or did you have to build up or modify something? They look so perfectly mounted.
GrregP is offline   Reply With Quote
Old 05-23-2013, 03:41 AM   #90
Rpryor3's Avatar
Trailer: 1970 Trails West Campster
Yes but when men sew its called "Automotive Upholstery".
Rpryor3 is offline   Reply With Quote
Old 05-23-2013, 06:51 AM   #91
Virginia
But upholstery to me means taking it to an entirely new level of difficulty.
I was just sewing-- no need to call me a seamstress though!
The full extension slides are a really nice luxury. They are very smooth operating and stay shut on their own. They come in many lengths and if if you get he proper size your drawer will extend completely out of the cabinet-- which is if course the biggest advantage of them.
Much nicer than the slides in my home that only open 2/3 of the way. The full ext. slides are also easy to mount in the Scamp, as you can buy a rear bracket (adjustable) for $3 that allows you to mount them to the rear wall as opposed to a non-existing side structure. The only downside to them in they cost $16-$20 each plus the back brackets.
I got some more work done on my shades yesterday-- I'll show photos later.
Old 06-05-2013, 06:56 PM   #92
Virginia
I installed a lighted license ate holder from vintagetrailersupply. It's the the old Airstream style, it looks nice. I sprayed it with some clear to keep it from rusting.
The most efficient Fan 12v I could find was mentioned ONLY ONCE on this entire forum, I'm sure glad the one person posted about it though. I bought it and love it so far. It is a Caframo Ultimate ( model 757 or 747). It only draws 0.40 amps on high and 0.28 amps on low. Compared to a standard store bought generic 12v cig lighter fan that pulls 0.8amps. Plus it is smaller than I thought it would and moves more air than I expected it to. The fan head can pivot and it can also rotate 360 degrees on the base, it is very versatile. This fan really kicks some serious butt! The overall quality seems much better than a typical 12v fan.
My only complaint is that there is a bit more vibration than I would like. When you hold it in your hand and run it you can feel it "wobbling" a bit. It doesn't make any noise as a result. ... Until you mount on a cabinet. Mounted on my sturdy wood cabinet it causes some low resonant sounds on the high setting because of the wobble, again the sound does not come from the fan itself but is caused by the fan making the cabinet resonate. This does not happen on the low setting, and in fact the low setting will move plenty of air for most purposes. I do plan in pulling the blade off ( it's a somewhat soft rubber blade) and balancing with an RC tire/prop balancer.
Instead of a conventional fire extinguisher I put in an aerosol can of Tundra. It is an all purpose extinguisher that is supposed to spray for 32 seconds as opposed to the 8 seconds for a "normal" small RV sized one. Since they are only $20 or so for a 2 pack I might test one of them these days just to increase my confidence in its abilities.
These "Tundra" cans do not come with a mount, but they about the same diameter as a regular spray can. I mounted mine with some cool doohickey that my father-in-laws, coworkers dad invented and patented. It's great for hanging cans of spray paint, WD40 etc.
I also put in my paper towel holder.
Take note of the shades I made-- they are fashioned so they can be partially opened like a roman shade, only with velcro and no strings.
Old 06-05-2013, 09:31 PM   #93
GMike A's Avatar
Pretty nice Ryan. Would like to know more about the holder. I have seen videos of the Tundra and it puts a regular extinguisher to shame.
Looks like you are reaching for a white butterfly there.
Mike
K5NAN
"Miss Adventures"
Old 06-05-2013, 09:41 PM   #94
Virginia
Mike-
I do not think the holder is on the market, I'll check on that for you. I'm not sure if it ever really got off the ground so to speak.
Here is a close up of it... I just zoomed in on an existing photo. I'll take a better photo of it when I get a chance.
It's really just a C shaped piece of flexible plastic that is screwed to a wall. It will hold cans very snugly (spray paint, WD40 etc), I'm confident it would hold them on a gravel forest road without even letting them slip down within the bracket. It's a really cool idea.
However, the Tundra cans are a tiny bit larger than the standard cans, I haven't measured but perhaps 1/32"-1/16" larger in diameter. So the bracket will hold it snugly and won't let it come out, but the Tundra can will slide down within the bracket. I put a few layers of electrical tape on the can keep it from dropping to low onto the countertop.
Old 06-24-2013, 11:00 AM   #95
project
Real Men use "Thread Injectors"
Darrin S is offline   Reply With Quote
Old 06-24-2013, 11:08 AM   #96
GMike A's Avatar
Does that make your Thread go faster like Nitro?
Mike
K5NAN
"Miss Adventures"
Old 06-25-2013, 08:20 AM   #97
injector
No, on my hammock forum they say men do not use sewing machines, they use Thread injectors!
Old 06-25-2013, 10:05 AM   #98
GMike A's Avatar
Whew that one flew over my head the first time but I got it now. My grandpa was a shoemaker and upholsterer back in the 40s so I should have caught that. He could sew better than a lot of women. (no offense ladies).
Mike
K5NAN
"Miss Adventures"
1979 Boler Project trailer kevin61 Modifications, Alterations and Updates 71 09-15-2013 08:29 PM
New Project - 76' Scamp David Morgan Modifications, Alterations and Updates 32 08-04-2011 11:56 PM
New Scamp owner & New member. 1992 Scamp 16 project LanM Hi, I am.... 16 01-31-2011 08:05 PM
82 Scamp 16' (Project) Kevin K Referrals: Molded Fiberglass Trailers 0 04-23-2010 02:14 PM
'76 Scamp project Legacy Posts Problem Solving | Owners Helping Owners 29 03-11-2003 11:34 PM
