1982 Boler remodel, rebuild, restore - Page 7 - Fiberglass RV
Old 06-09-2015, 03:22 PM   #85
Raff's Avatar
I just got my new axle today. I ordered it from a local trailer place that takes the measurements I provided and has the axle made to order. Rated for 2000-25000lbs has Flexride adjustable arms and Dexter brakes. Looks pretty good. $360 taxes in. I put it under trailer to check the fit and it's great except the mounting brackets are 1/2" shorter than the originals. As a result the axle tube hits the frame before the bolts are snug. Tomorrow I'll pick up some bar stock, drill a few holes and sandwich it between the axle and frame.
I noticed the pics disappeared from my previous post. Not sure how that happened. Anyway the interior painting and laminate floor installation is almost done. I'll post a few photos when complete.
Name:	ImageUploadedByFiberglass RV1433884923.815627.jpg
Raff is offline   Reply With Quote
Old 06-09-2015, 03:42 PM   #86
Ian G.'s Avatar
Also be aware the Flexi Ride axle arms are 1.5" shorter than the original Dexter (4.5" vs 6"). What this means is if you mount the axle in the same location the wheels will be offset 1.5" from the center of the wheel well opening.
Also make sure the brakes are on the correct side, if you are installing as a leading arm configuration the brakes are probably installed by the manufacturer as trailing arm, you need to swap brake backing plate assemblies side to side so the rotation for the magnet and arm are correct.
Old 06-09-2015, 03:45 PM   #87
Raff's Avatar
Thanks Ian. I'll look into that before final installation.
Old 06-13-2015, 03:44 PM   #88
Raff's Avatar
Got the axle installed today. I solved the mounting problem by getting a couple of pieces of solid aluminum 1 inch thick, drilling some holes and sandwiching it between the frame and the axle mounting pad. It worked perfectly and the axle was bolted in with no issues. Ian, the trailing arms were a bit shorter than the original but it still looks ok. Now I think the trailer sits too high. In the attached pic it's still sitting on some wood blocks so is haven't yet decided if I'll pull off the trailing arms and change the angle. With the old collapsed axle the trailer was close to scraping the pavement on numerous occasions, that's not going to happen now. Changing the angle of the trailing arms looks easy so I'll see how it looks when its attached to my TV. Ignore the outside of the trailer. It hasn't seen soap since last fall. A thorough sanding and a roll and tip paint job are on my list.
Name:	ImageUploadedByFiberglass RV1434231797.947566.jpg
Old 06-13-2015, 03:51 PM   #89
Raff's Avatar
Also finished up most of the interior painting and the installation of the laminate floor. Thought I'd post a few progress pics. I still have to do some final touch ups. I'm missing a handle or two. My wife is going to be making new curtains the interior needs a good cleaning and the mattress put back in.
Name:	ImageUploadedByFiberglass RV1434232060.726498.jpg
Name:	ImageUploadedByFiberglass RV1434232087.191512.jpg
Name:	ImageUploadedByFiberglass RV1434232116.424329.jpg
Name:	ImageUploadedByFiberglass RV1434232171.859156.jpg
Name:	ImageUploadedByFiberglass RV1434232195.678636.jpg
Name:	ImageUploadedByFiberglass RV1434232221.611731.jpg
Name:	ImageUploadedByFiberglass RV1434232251.547622.jpg
Old 06-13-2015, 05:32 PM   #90
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Dang! This looks great! Superior job!
D Davis is offline   Reply With Quote
Old 06-14-2015, 01:16 PM   #91
Raff's Avatar
Thanks for the compliment. Definitely couldn't have done it without liberally borrowing from all the great threads here.
Old 06-14-2015, 01:55 PM   #92
Trailer: 2010 Escape 17B
Love the colours, very classy.
kootenaigirl is online now   Reply With Quote
Old 06-14-2015, 02:36 PM   #93
Jay H's Avatar
Trailer: Boler 1300
that looks Great Martin!
Jay H is offline   Reply With Quote
Old 06-14-2015, 03:30 PM   #94
Raff's Avatar
Thank you both. My wife picked the colours. I just agree and it all works out. 😊
Old 07-07-2015, 09:57 AM   #95
Raff's Avatar
I pulled the trailing arms off the new axle this morning in an effort to lower the ride height a bit. Turned out to be a simple job. 20 minutes per side. One bolt, a little persuasion with a hammer and the arm was off. I used the marks punched on the spindle to make my adjustment. It's about 1 1/2 inches lower. I would recommend the adjustable trailing arm axle to anyone doing a swap. I haven't towed with it yet but so can't comment on that.
Name:	ImageUploadedByFiberglass RV1436284572.382569.jpg
Name:	ImageUploadedByFiberglass RV1436284612.927501.jpg
Name:	ImageUploadedByFiberglass RV1436284628.102030.jpg
Old 09-12-2015, 09:54 AM   #96
Raff's Avatar
While I didn't get to do all of the jobs that I had planned to this summer I did manage to finish painting the interior, add some Umbra coat hooks, install the vinyl flooring and fill and sand the rivet holes in the body. The gel coat is faded and chalky and could really use a paint job but that will have to wait. Instead I gave the whole trailer a wet sanding with 600, 1000 and 1500 grit sandpaper and then washed and waxed it. It looks pretty presentable now both on and out. My wife got the interior sorted out and sewed up all new curtains. We leave next week for a two week trip. We're making a straight shot for the Florida Keys staying at Long Key State Park, Boyds in Key West and Anastasia State Park in St Augustine. I'll do a thread on the trip for anyone who might be interested.
Name:	ImageUploadedByFiberglass RV1442073143.278078.jpg
Name:	ImageUploadedByFiberglass RV1442073178.211326.jpg
Name:	ImageUploadedByFiberglass RV1442073219.532522.jpg
Old 09-12-2015, 01:34 PM   #97
D Davis's Avatar
Virginia
Martin, of cource we are interested in your trip. Have a wonderful time and be safe. Your camper is marvelous! (I envy all your cabinet storage.)
Old 09-12-2015, 02:25 PM   #98
Trailer: 2005 Scamp 16
Looks great! Look forward to details of your trip! Enjoy!
emij is offline   Reply With Quote
boler
1982 Fiber Stream Rebuild Victor Benz Modifications, Alterations and Updates 18 07-02-2015 01:55 AM
BC | 1974 boler 13' restore project for sale$3500 Bcboler Classified Archives 0 04-20-2013 09:07 AM
1974 Boler Restore - Penticton BC Bcboler Modifications, Alterations and Updates 21 11-04-2012 02:03 PM
Restore boler 78 Yvon Chayer Modifications, Alterations and Updates 36 04-22-2012 09:28 PM
Our 1973 Eco - with recent retro restore Mark and Peg P. Modifications, Alterations and Updates 4 07-14-2008 06:17 PM
