The cool cat heat pump is not listed in any RV parts book. I saw the cool cat A/C in tab campers. I called Holman motors in cincinnati ohio and talked to Cecilia and she found it in a parts catalog and ordered it for me. It was pretty pricey, but well worth it. The rat fur is fairly easy to work with, and very easy to hide the seams. Scap just cuts small slivers of the fur to cover over the seams, but I just butted my seams and brushed them out. Some were hidden better than others, but I got better as I went. The flooring is just engineered hardwood flooring that I purchased from Home Depot, the color was Mahogony. I can't really remember the brand, but it was NOT the cheap stuff, it was the 3/8 thick wood, not the presswood back. If I recall correctly, it was around $95.00 a box and I used 3 boxs. I had plenty left over, but I wanted long pieces and the case comes with assorted lengths. The hardwood floor adds strength to the floor when interlocked, so I wanted to span the main traffic areas in one piece and not use 4-5 pieces to make the span.
Sorry for the delay in responding to you questions, if you need anything, feel free to ask.
