20 foot Scamp - Fiberglass RV
Old 12-19-2007, 06:13 AM   #1
Lyndon Laney's Avatar
Trailer: 1996 19 ft Scamp 19 ft 5th Wheel ('TOGETHERNEST' SLEEPS 8
My first winter project has been to extend my frame and ad a trunk for chairs ect.
Lyndon Laney is offline   Reply With Quote
Old 12-19-2007, 06:47 AM   #2
Joe Z's Avatar
New River AZ
Nice Clean Job.......... Looks like it came with the trailer....... Did you have to beef up the bumper to the frame?____
a nice pic of that underneath would be nice if possible..
Have a Great Holiday
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 12-19-2007, 08:05 AM   #3
Joe
My frame extension
Old 12-19-2007, 01:48 PM   #4
Greg A's Avatar
Trailer: 2015 Escape 19
Gorgeous work Lyndon.
What do you think the weight limit would be that you could carry back there?
Did you add anything addl to the tongue to balance?
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 12-19-2007, 01:59 PM   #5
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
So what did you use for the box? Is it fiberglass?
Old 12-19-2007, 03:29 PM   #6
Joe Z's Avatar
New River AZ
Extended the Frame.............. Nice idea. I didn't even think of that route. that will beef it up real nice for you and the fifth wheel (gooseneck) setup you have is a plus and makes for a nice lookin rig. Got to hand it to you! Nice setup
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 12-19-2007, 04:05 PM   #7
The top and door are Fiberglass and the bottom and sides are 1/8 thick foam PVC with a skin of 24 gauge alum fastened to a frame made of 1/4 x 3 inch alum the whole unit weighs around 20 pounds I sure hope I don't get kicked off this board for not using all fiberglass. I will post pictures of project they are on another computer now.
Old 12-19-2007, 04:11 PM   #8
The weight on my 5er toung is around 500 pounds, so no problem there this in for chairs and the like. i have also added adjustable spring shocks to bring my tired old axel back to its new height so I think extra weight will not be a problem.
Old 12-19-2007, 04:23 PM   #9
I will now atempt to add pictures of the framework and skin
Old 12-19-2007, 04:43 PM   #10
Trailer: Fiber Stream
Talking
I don't think you have to worry.
The finish looks to blend in very well with the rest of the trailer.
Old 12-19-2007, 07:17 PM   #11
(clipped) ...I sure hope I don't get kicked off this board for not using all fiberglass. I will post pictures of project they are on another computer now.
Did you see the box I made? It didn't even look Fiberglass.
You did a beatiful job. Thanks for sharing.
Old 12-19-2007, 07:20 PM   #12
So if Iím seeing that correctly, it looks like the Aluminum is the base tray. What is the sides made of that the lights are in and the spare tire are attached to?
Old 12-20-2007, 08:33 AM   #13
Mike The bottom is alum with a carpet material on top of it to soften bouncing stuf while on the road. It has an alum frame as per photo 2 and 2 layers of skin [1] 1/8 foam PVC sheeting and a second layer of 24 gauge 6061 alum [a very rigid type] put on 1/2 of the trunk at a time starting at the body of the scamp and rolling it around as in pic 3 pop riviting as I went. The top is fabricated from fiberglass with a fiberglass door .
Old 12-20-2007, 01:46 PM   #14
Brian B-P's Avatar
Lyndon, thanks for sharing the details of your mod. I do have a couple of questions...
The frame extension method raises (or lowers... which side is forward in the drawing?) the extended portion by over an inch: is the extension entirely beyond where anything was sitting on the frame?
The use of 1" tubing to splice the frame suggests that the stock frame is only 1" wide inside... is that correct and can you tell us the outside width and height of the frame material?
Scamp 1975 13 Foot Kevin K Referrals: Molded Fiberglass Trailers 4 04-08-2010 03:40 PM
Scamp 2005 16 foot Kevin K Classified Archives 3 08-01-2009 08:18 AM
13 FOOT SCAMP Kevin K Classified Archives 0 06-29-2009 07:38 AM
2006 16 foot Scamp gary schoen Classified Archives 2 04-20-2009 06:35 AM
1978 13 foot Scamp Kevin K Classified Archives 1 10-08-2008 11:24 AM
» Virginia Campgrounds
