3-Way Porch Light - Fiberglass RV
Old 02-20-2009, 08:16 PM   #1
peterh's Avatar
One of the things we didn't like about the way Scamp did things is our porch light can only be operated by an outside switch. It would be nice, we thought, to set the light up so it can be turned on and off from either an inside switch or an outside switch.
To accomplish that I needed two "SPDT" (single pole, dual throw) switches, one of which had to be a match for the existing switch in the porch light housing. After browsing online for a few hours I found some (they came in a lot of six, so I have a few extras if anyone wants one). The interior switch was easier to find: it's a standard Radio Shack switch. The other supply I needed was a few feet of 4-conductor, stranded, 18-gauge alarm system wire (Home Depot).
The wiring diagrams look like this:
Here are pics of the exterior porch light. (Sorry about the ugly caulk . . . Still have to get that off one day.) The replacement switch is somewhat deeper than the original, so I had to bend the leads from the back of the switch forward toward the lens of the light to prevent them from short-circuiting to the aluminum backer plate of the light housing. The wires have all been soldered into place on the switches.
And the inside switch located on the side of the cabinet next to the door. It's the bottom switch.
Old 02-20-2009, 10:59 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
PLEASE SIR, May I have one (switch)
....for which I'll GLADLY repay you for on Tuesday (or at Taidnapam in June, LOL!!!)???
Old 02-20-2009, 11:39 PM   #3
Roy in TO's Avatar
May I have one as well?
PM sent.
Old 02-21-2009, 05:29 AM   #4
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Technically, aren't two SPDT switches required? The current switch is SPST and it needs to be replaced as well.
Oh wait, I get it. You've found a switch that fits the hole in the outside light fixture. Another SPDT switch of any convenient form factor is needed for the inside switch.
I've had good luck with nick-knacky type electronics supplies with Mouser.com. Searching for "SPDT rocker" finds 647 of 'em!
Also,
Old 02-21-2009, 06:31 AM   #5
Me, me, me PLEASE. I've had a porch light sitting in a box for ever so long. I too didn't want to put it on the trailer until I had the solution for two switches.
You are a peach Peter! I'll see you and Lynn at one of the gatherings this spring/summer. I'll have cash in hand!
Old 02-21-2009, 09:39 AM   #6
Greg A's Avatar
Trailer: 2015 Escape 19
PET PEEVE: Porch lights that are left on at night.
Just had another one do this next to us at Cottonwood last week. Ruined the stars and ambience of the beautiful night.
Hope once everyone gets their switches installed you use them to TURN OFF THE PORCH LIGHT once you're inside....
OK, my rant is over....
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Greg A is online now   Reply With Quote
Old 02-21-2009, 10:02 AM   #7
I 100% agree with you Greg. I think a lighted switch (inside) would be best. Green when on, no color when off (so it doesn't bother sleepers) at night, or maybe a dim red for off?
Old 02-21-2009, 02:20 PM   #8
peterh's Avatar
I agree with you on that one, Greg, and since our porch light with the LEDs installed is even brighter than it was with a standard bulb it's even more important to make sure the light is off.
I considered installing a rocker switch with an LED that illuminates when the light is on, but that would have required yet another conductor wire to come back from the light, and I had already used all four conductors in the alarm wiring binder and didn't want to run another conductor back. Besides that the switch is right next to the door, it's pretty easy to look out the window to see if the light is on.
Old 02-21-2009, 03:01 PM   #9
Roy in TO's Avatar
During the day you would have to stick your head out to see for sure.
I'm wondering if you could connect a single 12V LED indicator into the red positive line feeding the center terminal of the switch inside?
Old 02-21-2009, 07:15 PM   #10
peterh's Avatar
I wired it up the way shown in my diagram because I needed both the 12v+ and 12v- leads for the amps/volts meter.
You could wire it up like this to power an indicator light, too.
Old 02-21-2009, 11:54 PM   #11
Roy in TO's Avatar
That is not quite what I was thinking. I don't have anything to draw nice diagrams like yours so bear with me:
You 1st set of diagrams shows:
[+ve]--red--[switch1]==yellowgreen==[switch2]--red--[light]--[-ve]
I am suggesting:
[+ve]--red--[LEDindicator]--[switch1]==yellowgreen==[switch2]--red--[light]--[-ve]
If I am thinking right, the LED indicator will only light up if both switches are in the right position to allow the electricity to flow. I hope you understand what I am trying to say.
So in your last diagram, the red wire would go into the indicator light, then back into the switch, with out connecting directly to the black wire.
Edit to add:
I just noticed you also changed the wiring at the second switch in your second diagram, my thoughts were that it would be wired like in your first diagram.
Old 02-22-2009, 12:08 AM   #12
Roy in TO's Avatar
If my elecTRICKical lingo is right, I am suggesting the LED indicator be wired in series where you have it wired in parallel in the second diagram???
Old 02-22-2009, 12:32 AM   #13
peterh's Avatar
Yes, my second diagram shows the indicator light wired "in parallel" witht eh porch light.
Per your suggestion you could wire an incandescent indicator light "in series" with the porch as long as both the indicator light and the porch light were incandescent bulbs. The problem with this set up is with both bulbs feeding off of the same 12v feed, they'd both be dimmer than if you wired them "in parallel."
If you used LEDs in series somewhere you'd have to do a little electrical engineering to get the right amount of current to pass through the LEDs to get them to light correctly and not burn out. LEDs are very picky about voltage and current, so it's not at all practical to wire an LED indicator light in series with the porch light.
Old 02-22-2009, 12:40 AM   #14
Roy in TO's Avatar
Ooops,
Does that mean I'm going to have troubles when I try to rewire my trailer with LED's and use the switches I bought that have the little LED indicators built into the buttons?
lighting, lights, porch light
What do you think of this as a porch light? Donna D. Care and Feeding of Molded Fiberglass Trailers 18 09-21-2010 07:50 PM
Solar porch light Mike Taylor Modifications, Alterations and Updates 21 08-28-2010 12:48 AM
Porch Light Kevin K General Chat 15 08-11-2008 01:59 PM
Added a Porch Light Jayson Wall Modifications, Alterations and Updates 6 07-11-2007 07:42 AM
Porch Light Legacy Posts Problem Solving | Owners Helping Owners 8 06-10-2003 10:21 AM
