6 Volt Battery Conversion on my Trillium - Page 2 - Fiberglass RV
Old 06-26-2016, 06:56 AM   #15
Trailer: 2001 Scamp 16 ft, 2004 Jeep Grand Cherokee
How did you attach the battery boxes to the frame? I am also changing to 2 6 volt batteries to my Scamp, but not sure how to make sure the boxes are secure.
dvrcdlady is offline   Reply With Quote
Old 06-26-2016, 07:13 AM   #16
Trailer: 2014 Escape 21
Virginia
I just inst. 2 6v batteries to my S-16. I used this box. Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)
I made a frame to hold the box out of 1.5 angle to set the box in. I then set the box frame on the frame rails. Then ran long bolts down to the orig. battery support bars in case I did not want to keep the dual 6 volt batteries.
I plan to extend legs up from the battery box frame to put a platform on top for a generator or bike racks. I will weld the box frame it to the trailer frame if I do that.
Eddie
Old 06-26-2016, 08:20 AM   #17
Clayton's Avatar
Trailer: 1975 Trillium
Hi Linda, I drilled a hole in each of the four corners of the battery boxes. I then matched up the holes in the boxes with the angle iron on drilled through it. I used 1/4 stainless bolts with large washers on top and lock washers with nylock nuts on the bottom. It is super secure.
Clayton is offline   Reply With Quote
Old 06-26-2016, 09:15 AM   #18
Larry C Hanson's Avatar
Box Mount
Hi,
When mounting a box for the group 27 battery
on my Trillium I decided to use aluminum angle
to make a simple frame for the box to sit it.
Not being a welder I find aluminum much easier
to work with than steel angle. The corners of the
frame are bolted together and the whole thing is
bolted to the old stock steel angle mounting that
the old group 24 battery box was bolted to. The
strap secures things well. Hope this helps someone?
Larry H
battery, trillium
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Engel MR40F 12 Volt Refrigerator 12 Volt Freezer Mike-N-Laurie Misc: Buy | Sell | Trade 1 04-26-2016 08:05 AM
Mobicool propane, 12 volt, 120 volt cooler Nelmes Parts: Buy | Sell | Trade 0 06-10-2014 01:36 PM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
Powering a 12 volt fridge and battery ecasey Care and Feeding of Molded Fiberglass Trailers 42 12-07-2007 03:55 PM
