7 pin connector protective cover at campsite - Fiberglass RV
Old 05-28-2014, 11:13 AM   #1
John Linck's Avatar
Madison, Wisconsin
I wanted to keep my trailer's 7 pin connector dry and clean while camping. First I tried a baggie, but wanted something a bit easier and effective. I needed to buy an new plug anyway as you can see the inner conductors in the pictures where the cable jacket pulled away from the plug. So I just bought a set of male and female parts for about a dollar more. I cleaned out the guts of the socket and attached it to the bottom of my tongue mounted storage box. Now the plug stays off the ground and mostly dry. I admit its a bit crude. Hopefully it will serve. Now to rewire the plug, hopefully while camped on a lakeshore or such. Just have to remember to switch sockets for departure.
Cheers all, Best Summer, john
John Linck is offline   Reply With Quote
Old 05-28-2014, 11:16 AM   #2
David Tilston's Avatar
Good idea.
Old 05-28-2014, 11:58 AM   #3
Trailer: Helite
Coat the contacts (M & FM) with dielectric grease. It will keep the contacts from corroding.
Art VanDelay is offline   Reply With Quote
Old 05-28-2014, 12:04 PM   #4
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I found a gadget on Camping Worlds close-out table a few years back. Others have asked about it but I can't find it anywhere anymore. Your solution is pretty tidy as well.
Old 05-29-2014, 05:19 AM   #5
Steve L.'s Avatar
FWIW, just in terms of closing the loop, I finally found the gadget I use: Plug Guard. About $10 and still available here and there on the web. I've used mine for about 5 years without issue. It has a spring loaded cover that grabs and holds the male plug like the fitting the tow vehicle has.
Old 05-29-2014, 07:59 AM   #6
John Linck's Avatar
Madison, Wisconsin
Thanks Steve for finding it. Much more elegant than my contraption. My next trailer will have one. ;-)
Cheers, john
Old 05-29-2014, 08:08 AM   #7
Trailer: Casita 17 ft DLX SD
They make a molded plastic holder . It holds the 7 pin connector in a vertical position with the contact openings facing down . The 7 pin connector just slides into the holder . Cost is under $4 . It attaches to the trailer frame with 2 SS screws which are provided
Old 05-29-2014, 08:13 AM   #8
Raz
Raz's Avatar
Vermont
Joy A. came up with this using PVC pipe. She clamped hers. I bolted mine.
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Towing, Hitching, Axles and Running Gear 5 04-20-2008 02:11 PM
Yellow wire on 7 pin connector ? Mikeny Towing, Hitching, Axles and Running Gear 2 04-13-2008 01:22 PM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
Yellow wire on 7 pin connector ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
