Hi Kala,
Yes I've replaced loose rivets in same location in my
Scamp. You simply drill out the old rivets from the outside of the trailer (mine were 3/16" drill bit for same size rivet) and get the proper diameter and length rivet and reinstall new with a hand rivet gun. I don't know if bikers use outside plastic washers and snap caps like scamps? Others here will.
The interior of my
Scamp uses threaded acorn nuts that catch the rivet inside as it's squishing down and spreading out over inner
fiberglass.
A good source for rivets I've used is McMaster Carr. Pro-Dec is good source for snap caps and plastic washers. If your biker has acorn nuts inside, someone has to be inside holding the nut over the rivet while person outside uses rivet gun so acorn nut cinches up to it.
A new rivet and you'll be good as new. They can loosen with road vibration. But relatively easy to replace. Other
boler owners here should be able to help you with rivet length and diameter questions.
Best wishes,
Wendy
Sent from my VS985 4G using
Fiberglass RV mobile app
