75 Boler Skylight Replacement - Fiberglass RV
Old 09-15-2013, 12:37 PM   #1
Trailer: '75 Boler
YT
Hello,
We've recently purchased a 1975 Boler and it's in need of a number of upgrades. First up is the skylight - one of the hinge pins has rusted through and there's water getting in when it rains.
I'm hoping the collective wisdom of the forum can help advise in either replacing the skylight with another opener-style skylight (and where's a good source to order them from) or whether to go with a non-opener window (Scamp looks like a good source there). Any advice would be helpful. Rough opening is approximately 30"x15."
Thanks for your time! Apologies if this question has been posted previously - I wasn't able to find it.
James.
JamesYukon is offline   Reply With Quote
Old 09-15-2013, 12:46 PM   #2
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
A pic would be helpful. The original vent would he had a rough opening of 9 1/2" x 9 1/2", so not sure what you have in your roof right now. You sound like you have a sunroof in there?
Originally Posted by JamesYukon View Post
Hello,
James.
Rick Mooyman is offline   Reply With Quote
Old 09-15-2013, 12:50 PM   #3
Hi James, to FiberglassRV, we're glad you're here
Skylight or do you mean a passive vent opening with a lid?
There are lots of kind and helpful people here on the forums. Once we have a better idea exactly what you need, there will be folks stepping up to help you
Old 09-15-2013, 01:48 PM   #4
Trailer: '75 Boler
YT
Hello Rick, Donna,
Sun roof would be the proper term - thanks.
Here are the attached photographs.
James.
Old 09-15-2013, 01:52 PM   #5
Yep it sure is! That's an owner mod, it didn't come from the factory that way. Can you see a manufacturer brand anywhere on the frame? If you can, I'd start there for hinge pins for that particular unit. Now, if you want to change that out to either a power vent or passive vent, there's lots of info here to be had.
Maybe someone on the forums has more info regarding a skylight. The last car I owned that had one like that was in the 1970s and it leaked like a sieve even when brand new!
Old 09-15-2013, 02:03 PM   #6
Manitoba
Ditto Donna I had a few of those in a few cars way back then and have never had a sunroof in a car since. They would never seal right and always got wet inside the car when it rained.
Old 09-15-2013, 02:09 PM   #7
Manitoba
Scamp sells a 18" x 25" Escape Hatch but it would mean filling in some of the opening with fiberglass. Guess the previous owner was not worried about bugs getting in as the sunroof has no screen.
Old 09-15-2013, 05:35 PM   #8
I have no idea what your camping experience expectations may be... BUT, unless you know and expect to replace that skylight with something else (may require fiberglassing)... I'd slather the outside with a caulk to prevent leaks (it wouldn't open). NO SILICONE!
Old 09-15-2013, 05:45 PM   #9
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Hello,
...... one of the hinge pins has rusted through and there's water getting in when it rains...........James.
I'm wondering if there is a possibility of repairing what you have. Perhaps a photo of the rusted out area?
Old 09-19-2013, 10:44 AM   #10
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
I have two sunroofs just like that installed in my 13' Boler. No leaks. Just keep the rubber seal lubricated.
I would start by checking out some auto salvage yards. These sunroofs are aftermarket so you will need to find something from the 80's.
You could also try some auto glass shops. They may be able to supply parts.
Failing that, you should be able to replace the pin.
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 09-19-2013, 12:29 PM   #11
Might want to try the sunroof doctor. maybe they have something for you.
The Sunroof Doctor - Your source for replacement sunroof & t-top parts!
Old 08-19-2014, 10:59 AM   #12
tchaka's Avatar
Trailer: in the market
Hello Rick, Donna,
James.
Hi James, do you know where these pics are from? Would love to know more about this instillation process...
T'chaka
keep the rubber side down.
tchaka is offline   Reply With Quote
Old 08-19-2014, 11:02 AM   #13
tchaka's Avatar
Hi JK boler, I just recently acquired a 73 boler and want to install such a sunroof/moonroof/skylight as may be installed in yours. Would you be willing to share some details on your install and perhaps some photos?
Thanks,
T'chaka
Old 08-19-2014, 01:57 PM   #14
jkmboler's Avatar
Manitoba
Install is fairly simple, just be sure to measure twice and cut once... it would be difficult to make the hole smaller after cutting!
If you purchase a new unit, it will come with a template. In my case I got both from salvage yards and removed them from cars in the yard. I made a template of the hole in the roof of the car with a piece of cardboard and used that for the placement and hole size.
I laid out the roof top with masking tape, positioned the template, marked the location I decided and using a 3/8" drill bit, drilled a hole one corner. I used a jigsaw with a fine pitched blade and cut away.
The frame of the sunroof may have some curvature to it so I laid this on the roof and slid it forward/backwards of the selected install location to find the best fitment.
After cutting the hole, I used Butyl tape to seal the outside frame to the camper roof and screwed the inner frame into place.
I can take some photos of the finished install and I even still have the fiberglass piece I cut out but it may be a day or two before I can post the photos.
My install looks exactly the same as the photos in post #4.
On a side note, I originally planned on putting a bug screen on the sunroof, but it seems that bugs don't hang out on the roof. I have never had a bug problem and the only bugs inside the camper seem to exit via the sunroof, not enter by it.
I use a good quality rubber dressing or hand lotion with lanolin to keep the rubber seal soft and leak free (never use Vaseline). The first sunroof was installed over 15 years ago and has never leaked. The second sunroof went in 3 years ago and is also fine.
1974 Boler 1300
boler, light
Wanted: Skylight JimW Parts: Buy | Sell | Trade 2 07-01-2013 01:08 PM
Possible Skylight?? Cat futrell Modifications, Alterations and Updates 6 09-25-2012 09:52 AM
'81 scamp skylight top jim munson Classified Archives 5 02-25-2008 04:50 PM
Skylight or No Skylight? Ed Calkins Care and Feeding of Molded Fiberglass Trailers 18 08-10-2007 01:06 AM
14 x 17 dome cover for skylight wayne stout Problem Solving | Owners Helping Owners 9 06-26-2006 09:29 AM
