76 Boler Reno/Rework - Page 2 - Fiberglass RV
Old 12-14-2010, 12:21 PM   #21
kgingeri's Avatar
Name: Karl in Elmira ON
Trailer: Boler 1300-76
Originally Posted by monasimpson
kgingeri,
I'm having the interior re-done on a 1990 Casita. Alumalite is the material that is being used to make new cabinet doors. Checkout this website to give you some ideas. aeroparadise.com
Good Luck, Mona
Thanks Mona, but that site doesn't seem to work for me? Can you check it again? I clicked it right from your msg so I know I haven't missed spelled it.
Karl
kgingeri is offline   Reply With Quote
Old 12-14-2010, 02:03 PM   #22
Trailer: Casita 16'
Wisconsin
www.aeroparadisellc.com
Karl
Karl, I hope this works for you. This business is located in Reedsburg, WI.. Their main focus is small, private airplanes....mechanics and interiors. Most of their contact information is on their web site. Eric and Karla Paradis are the owners.
Mona Simpson
monasimpson is offline   Reply With Quote
Old 12-14-2010, 02:45 PM   #23
http://www.aeroparadisellc.com/ like they added LLC to their URL, which stands for Limited Liability Corporation
Old 12-14-2010, 03:30 PM   #24
kgingeri's Avatar
Mona Simpson
Originally Posted by Donna D. View Post
AeroParadise, LLC - Custom Aircraft Interiors and Graphics - Reedsburg, Wisconsin, USA like they added LLC to their URL, which stands for Limited Liability Corporation
Ah - did see that URL but figured it wasn't right!
Thanks Mona and Donna!
I will definitely check it out!!
Old 12-14-2010, 04:31 PM   #25
Trailer: 13' Boler 1977
okay thanks for the pointers
i knew the body wrapped under the actual floor of the trailer, and was planning on setting up some blocks with 2X4's of similar wood underneath to add support, ........but thought you were setting it just on the floor, ......in which case i would as well, .........
but i will support it in someway and walk gingerly while making repairs!!!
thanks
Paul
pbraunton is offline   Reply With Quote
Old 01-23-2011, 10:49 PM   #26
kgingeri's Avatar
A little but significant progress on this Reno. I have a new aluminum frame, axle, wheels and brakes! Sure isn't camping weather here in winter wonderland Ontario Canada - near -20C!!
First mild spell and the body goes on - wha-hoooie!!
Old 01-24-2011, 05:51 AM   #27
Don N's Avatar
Trailer: 1978 Boler 1700
Have you figured out the weight loss with the aluminum frame over the original? Nice job on the frame. You the welder? Like the surge brake as well.
Don N is offline   Reply With Quote
Old 01-24-2011, 08:39 AM   #28
kgingeri's Avatar
No, didn't weight it yet Don, but it is definitely lighter. The axle alone is 95 (shipping specs, with brakes), and I venture to guess the entire frame is not much more. Two of us could lift it and flip it on the bench with ease. I could lift it myself as well. So all and all I'd say it's between 200 and 250, where the original may have been 300-350? I will weight it dry and report back after all renos are done, to let everyone know how well I did.
The welder is Jason, my friend who welds trailers for a living. I do weld, but never aluminum, and I didn't want to experiment on a critical piece like this!
Old 01-29-2011, 02:25 AM   #29
Trailer: Own a PUP and looking for a Boler
Did he TIG it or use a spool gun? (welding nerd here)
brslk is offline   Reply With Quote
Old 01-29-2011, 07:53 PM   #30
kgingeri's Avatar
Hi Brslk, his welder has the spool internal but the feeding mechanism is in the end by the tip. This avoids 'bird-nesting', though he says the take more abuse - being on the floor or hitting it. The frame fits great. got it on the aft. pics coming in a few minutes.
Karl. :v)
Old 01-29-2011, 08:10 PM   #31
kgingeri's Avatar
It fits - whew!
Well it wasn't real mild, but I just had to know!
Here are two pics - rigging to get it on and it all done and covered up again...
Karl
Old 05-13-2011, 07:40 PM   #32
kgingeri's Avatar
Latest pics, tried a previous post and lost my big blurb, so I'll post these and then explain.
Old 05-13-2011, 08:23 PM   #33
kgingeri's Avatar
So it's been a while! I still feels like I'm in demolition mode, but I am doing some building - windows and cabinets.
End of May is coming fast but I want to do a quaulity job not a fast one. All windows and almost all outer rivets are removed. I don't think there was a rivet that didn't leak in this thing!! I am for sure using stainless hardware, with threads coated in silicon, for any thru-body mounting required! The steel pin left inside the rivet also rusts and leaves nice stains :v( To remove rivets, I found that a small wood chisel I could resharpen (just a bit wider then a rivet head) and a hammer, removed the rivet head nicely, then a punch to poke the old rivet thru. This was the least damaging to the fiberglass and the fastest in the long run. Sometime the steel pin part is sticking thru a bit and that makes it tougher. I'll be using a clamp-ring to re-mount the new windows, so no rivets there!
I'll be re-mounting front and back windows with Wedge-tight rubber (from Speanaur, in Canada) and a chrome insert. The other four I am building and will use a clamp-ring affair for mounting. The door window will be slightly larger as will the kitchen.
The third pic shows that there is quite a bit of patching to do on the body, holes from previous appliances etc. Also the skirt has been damaged in a few places, and behind the door hinges. So I've got a sizeable amout of fiberglass patching materials.
Anyway, hope to be posting more soon and more often!
Karl :v)
Old 05-14-2011, 06:02 PM   #34
Trailer: 1985 16 ft Scamp
Ohio
Hey Karl
I enjoyed reading about the work you are doing. That is a big task and it looks great. I love the aluminum frame.
I am in the process of freshening mine up a bit and I am going to use stainless steel button-head bolts and never seize. That way I can remove the cabinets at a later date with a helper on the outside with an allen wrench to loosen the bolts. My Dad has a bench grinder set up for polishing stainless so it won't take long to make them shine.
Keep us posted with your Boler Project. I can't wait to see it all done.
Michael
BigMike is offline   Reply With Quote
Old 05-15-2011, 11:01 AM   #35
kgingeri's Avatar
Originally Posted by BigMike
Hey Karl
Michael
Thanks for your encouragement Michael! It sure is a pile of work, but I do hope to have it looking like NEW when done - and stay that way for years to come!
I personally see stainless as the only way to go. Your right about being able to remove pieces if need be - good thought. You may want to put a dab of silicon on the threads too - for seal and to sort of act like lock-tite. One problem with hardware vs rivets is likely that a nut-bolt combo can loosen with vibration etc. Just more 2 cents worth.
Karl
Old 05-15-2011, 12:52 PM   #36
DannyH's Avatar
Trailer: 1976 Scamp 13 ft
Looks great Karl. I also put in all stainless bolts around the windows in my rebuild to be able to take things out. Anything that was straight steel was rusted through and tough to take out. I also would suggest sitting in a mockup of your front dinning area. I was planning to put a 12" storage area behind one of the seats and after trying it on for size with my wife and me sitting at the table, realized we would be hitting each others knees. I ended up with a full seat across the front and no storage area, but we are 6 feet tall and a smaller area may work for someone else.
Keep the photo's coming, it's nice to see your work and design ideas.
DannyH is offline   Reply With Quote
Old 05-15-2011, 01:00 PM   #37
DannyH's Avatar
I forgot to mention how I installed the bolts for the windows. I used a stainless steel hex head bolt, whick looks like a rivet, and on the inside used a stainless steel washer and a stainless lock nut with plastic interior. I put a bead of Eternabond on the washer side that was next to the fiberglass and tighened. The Eternabond would sqeeze out to help lock the nut on and give a good waterproof seal. I was still able to take the bolt out when I screwed up once, but the eternabond really held everything tight.
Old 05-15-2011, 08:52 PM   #38
kgingeri's Avatar
Yeah, thanks for the suggestion Danny - re the dinette and Eternabond.
I was concerned about size/room when others here questioned it, so I did exactly that - built a cardboard pattern and mockup (with a thin wood top). It seems like lots of room to me, but we are smaller then most - both under the 5'6" mark. When built, I'll sit and take a picture. The seats will not be deep, 16" and 18", leaving a little over 20" for leg room. We can also sit with knees out if that feels to crammy. The door side will be big enough to hold a potty too.
I gotta say, one of the great things about a forum like this is the encouragement and motivation stimulus it gives
Old 06-29-2011, 10:33 PM   #39
kgingeri's Avatar
Back At It! :)
Soooo.... I took a week of holidays to get this project moving - and it is!
Here are some updates - see attached pics - hopefully they stay in the order I uploaded them. I'll describe them in that order, anyway...
  1. Pic of my dinette prototype (small but functional)
  2. Patching the wall that will be exposed - I used Mono in the seams. A previous owner did this (rather then the sticky tape) and it worked well, so I did the same.
  3. Installed a wheel-jack BUT it needed to be disassembled and cut down about 3.5" as the Boler tongues are quite low
  4. Installed a 14x14" new vent and it will have a fan. Hid wires in vinyl/foam interior layer
  5. Getting the exterior ready to paint. This project is not one for the faint of heart - WOW what a pile of work! Fiberglass patching, bondo, putty lotsa lotsa sanding!!!
  6. Sample of some of the fiberglass patching I had to do. I will not have a furnace. We'll use a micro furnace, as we always stay in hook-up areas
  7. Outside view of patched area primed to be sure it's ready for paint
  8. Interior all ready for paint. I patched ALL - and I do mean ALL - rivet holes. New holes will be made for new cabinets as I build them. And as mentioned, only stainless hardware thru the skin.
  9. Interior was primed with a tinted oil based primer and then I went over it with a decorative stone spray (my wife's idea). I did a small test area initially and it seemed ok, but I'm waiting for it all to dry now (quite cool out today so it's not a speedy process)
  10. a sample (though not great) of primer plus stone spray
So that's it for now. If it's good weather tomorrow (not windy, dry and warm) I'll be painting the exterior - nerve racking a bit. There is way too much potential for 'curtains' (paint runs - for non painters)!
Any who - that's it for now.
Old 06-29-2011, 10:37 PM   #40
kgingeri's Avatar
...ok, my last pic of the interior sample didn't seem to show up... here's another try...
boler
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
Compact Jr. Winter rework session Steve Hilby Modifications, Alterations and Updates 59 03-10-2012 08:35 PM
BOLER RENO - 17' - Not bad for a newbie! Dawn S Modifications, Alterations and Updates 20 09-06-2009 12:50 AM
Boler Reno pics David Konduc Modifications, Alterations and Updates 1 08-20-2009 05:57 PM
Sis' Compact Jr Rework Fall 08 Steve Hilby Modifications, Alterations and Updates 8 11-07-2008 09:12 AM
