78 Boler - Page 2 - Fiberglass RV
Old 06-13-2009, 09:35 PM   #15
Roy in TO's Avatar
It looks great.Congratulations.
Agreed, please keep posting more as you go along.
Old 07-22-2009, 09:34 AM   #16
Trailer: 1978 Boler 17 ft
Hi Again Gang, well 99--? finished, a few more pics posted.
I have installed a AC unit on the floor strange you might say, I cut a hole in the floor and outside wall, picked up a large aluminum pan intalled the AC in it, a wood metal lined vent through the hole, it works well, though probably need a small circulating fan mounted somewere. Oh! installed a a small return air vent cage in the floor vent to keep the criters out, I allways say if you don't try it you dont know if it will work.
I have looked at a few postings of differant ideas of mounting, but though I would try this.
All the Best Dave
[attachment=26322:
P1010004.JPG]
David Duxbury is offline   Reply With Quote
Old 07-22-2009, 10:24 PM   #17
Trailer: 79 Boler 17 ft
[Dave, I am reeeeally curious how that AC unit is going to work for you. How big a hole did you put in the floor? And also the outside wall you said?
You better have some pretty good circulation going to make it work. Very creative Idea however. I was wondering were to put a small unit.
Looking forward on a report back from you on this one.
Regards
Kevin.
KevinDR is offline   Reply With Quote
Old 07-23-2009, 05:09 AM   #18
james kent's Avatar
Trailer: Boler 1984
Dave I'm curious, Isn't your jack stand supossed to go UNDER the bumper?
Old 07-23-2009, 06:28 AM   #19
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Dave... All that hard work and sweating the details, looks like it's finally coming together for you!!! Nice trailer!!!
Old 07-23-2009, 08:56 AM   #20
Good Day People. thanks for the replys, (and yes to James) the stands have been shortened as the ones that are available are too long to go under the Boler, just aluminum angle and pop rivets, no real weight, forgot to state that.
Madeleine my wife and I are going to Mosport Grand Prix near Bowmanville off the 401Hwy at the end of August we allways park behing the GO-Cart track gate 2 might so if there are any race nuts going might see you there.
All the Best Dave
Old 07-23-2009, 09:38 AM   #21
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
<span style="font-size:12pt;line-height:100%">Very Nice Trailer.</span>
Old 07-23-2009, 02:03 PM   #22
Kevin here are some pics on the AC venting, I just used a Fridge vent for the intake on the side of the boler, underneath a small return air vent with the fins pointing backwards, its mounted just behind the floor brace at the front, to provid protection from water etc.
One could install a cover if needed. Dave
[attachment=26386:
P1010006.JPG]
Old 07-23-2009, 03:26 PM   #23
Don N's Avatar
Trailer: 1989 Bigfoot 17'
Madeleine my wife and I are going to Mosport Grand Prix near Bowmanville off the 401Hwy at the end of August we always park behind the GO-Cart track gate 2 might so if there are any race nuts going might see you there.
All the Best Dave
Which race is that Dave? They had the one race in June? We will be going to the Zippo Grand Prix in Watkins Glen on the Sept4th weekend. That is always a real good time.
Don N is offline   Reply With Quote
Old 07-23-2009, 10:48 PM   #24
Very cool Dave.
Permission to steal your design?....but first really want to find out from you how well it works.
I like the small and understated range vent. With the deflector you put, I can see that the A/C fan itself does the air movement.
Terribly curious on how well it chills the whole trailer. (Home Depot is selling 5000 btu units for $100 bucks)
Kevin.
Old 07-24-2009, 08:48 AM   #25
Hi Kevin. Yeh its one of those 5000 BTU units from Canadian Tire, same price.
It works well, a small circulating fan mounted somewere should do the trick.
As I say if you dont try it you dont know, its not like I was cutting into a expensive new trailer.
I thought a finer screens on the vents to keep the yellow jackets out
Dave.
Old 07-24-2009, 11:10 PM   #26
Dave.
Yah, throw in some window screen/mosquito screen behind each of the vents should do the trick. So the small vent on the side permits enough intake air to prevent the unit from overheating? And the whole trailer gets cool? Does the unit continually run, or does it cycle on and off? Since it is on the floor, does the unit push enough cool air up higher as well? I am being cautious before I cut a hole in the side. Mind you, the hole is relatively small. How is the noise factor? Do you use it to chill the place down prior to sleep? Is it tolerable to run while you are sleeping?
What I like about the whole concept is that if it breaks down and you abandon it, you can simply pull it out, put the cabinet door over top the hole and away to you.
By the way, Nice panelling job on the interior.
Kevin.
Old 07-25-2009, 09:01 AM   #27
Kevin, the unit is not loud, but the ciculating fan will be a must because of it being on the floor.
I have not really tested it for a long time yet, as you know weather has not been up to par for southern Ont this year.
One could try a unit place it on the floor in a tray and see how it works, along with a fan ???
Dave.
Old 07-26-2009, 01:46 PM   #28
Raymond Brodeur's Avatar
Trailer: Trillium 4500 1978 / 2016 Ford Escape
Dave.
David
Could you not install an upward deflector over the cool air output ? Like something of that kind :
Raymond Brodeur is offline   Reply With Quote
boler
MY 2008 BOLER BLOG, Camping trips using THE TANK: 74 Boler 1300...Pics Jayson Wall Camping, Campout Reports 1 01-18-2009 10:49 PM
