78 Surfside Re-build - Page 4 - Fiberglass RV
Old 07-04-2013, 07:20 PM   #43
Cathi's Avatar
POBox 1267, Denison, Texas
That yellow is so nice but the interior work is even more impressive. Good work!
Old 07-06-2013, 06:34 PM   #44
jrocmagoo's Avatar
Trailer: 1978 Tripple E Surfside
re-doing the out side is next years project, going pure white with dark blue center stripe (along the body moulding) well thats the plan so far
jrocmagoo is offline   Reply With Quote
Old 07-13-2013, 09:46 PM   #45
jrocmagoo's Avatar
Well more progress,electrical is done (kinda as the truck plug has issues) batteies hooked up and charging,new propane regulator,counters and tables are covered just need to run my router and find some edge trim.also re covered the front window rock guard
Old 07-14-2013, 08:51 PM   #46
jrocmagoo's Avatar
Counter top is done, tables are covered, just need to find an egde of some sort , thinking metal U trim? Or something
Old 08-02-2013, 01:39 AM   #47
jrocmagoo's Avatar
Took it for a drag, got the lino, plumbing done, almost there
Old 08-02-2013, 12:42 PM   #48
jrocmagoo's Avatar
Old 08-04-2013, 12:45 PM   #49
jrocmagoo's Avatar
More
Old 08-04-2013, 07:35 PM   #50
jrocmagoo's Avatar
Old 08-04-2013, 08:35 PM   #51
carlkeigley's Avatar
NE Oklahoma
I like the blue and black contrast.
Old 08-05-2013, 09:35 AM   #52
Trailer: Triple E
Looks like those are new water connections that bolt up perfectly with what factory-installed. I've looked for some online, but have been unable to find them.
Would you mind sharing where you picked them up?
kellyben is offline   Reply With Quote
Old 08-10-2013, 08:32 PM   #53
jrocmagoo's Avatar
The city connection is new, the drain however was"custom" i used a tank fill hatch and screwed in the center of the old set up, Add silicon and presto! Also found regular sink water lines fit bury i needed one 1/2 adaptor on the bottom end
Old 08-14-2013, 10:31 AM   #54
jrocmagoo's Avatar
First test run, all is well, fridge is not very good on propane, only holds at about 10-15c
Old 01-19-2014, 09:53 PM   #55
Trailer: 1977 Triple e surf side
I have a couple of questions... But first I'd like to say that it looks fantastic! Great job!
Where did you get the polycarbonate for the rock guard? I've been looking to replace mine but haven't been happy with what I've found.
And second, in the original set up did yours have a front bunk? If so how was the hardware set up? The previous owner of my surf side hard mounted the bunk and I would like to get it back to original.
FarmerTanTerror is offline   Reply With Quote
Old 01-21-2014, 05:39 AM   #56
Jeremy hasn't been around for a while Last Activity: 11-18-2013 12:31 AM Hopefully he'll be back and see your questions.
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Snow build-up on fiberglass roofs General Chat 5 02-14-2014 05:43 PM
The "Silkstone" build Ian S. General Chat 13 07-02-2008 11:52 AM
Microwave build in and laminate floor Karen K. Modifications, Alterations and Updates 9 01-20-2008 02:42 PM
What would you build? Legacy Posts General Chat 11 06-01-2003 02:01 AM
