78 Surfside Re-build - Fiberglass RV
Old 01-03-2013, 05:23 PM   #1
jrocmagoo's Avatar
Trailer: 1978 Tripple E Surfside
hello everyone! ive been stalking the site for a while now looking at purchasing a boler as a project and as luck would have it christmas morning a not too shiney but solid 1978 triple e surfside sitting in my driveway! so i figured it was time to sign up! it needs some tlc but overall its in good shape minus a fridge (if anyone is looking to sell one that would be cool!). i will be posting up pics as i start ripping it apart for a rebuild, way to many ideas in my head , also have to work on a tow rig as it may be pushing it hooking onto my Focus in the mountains (altho it would look good cause there both yellow!)
many good threads and ideas on here for repairs and upgrades, thanks for the insight!
jrocmagoo is offline   Reply With Quote
Old 01-03-2013, 05:43 PM   #2
Robin G's Avatar
Trailer: 2007 Casita
Congratulations! Do post pic's of your re-hab. They are always great for future members for inspiration. And the rest of us, enjoy seeing your progress. Summer's not far away, so don't get to, into ripping it apart. You wanna camp a little...... Again, Congrats!
Old 01-03-2013, 05:43 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by jrocmagoo View Post
...... minus a fridge (if anyone is looking to sell one that would be cool!)..........!
Welcome. We look forward to following your progress. Post lots of pictures!
This may help you in finding a fridge:
Tips for Buying a Used Gas Refrigerator
Old 01-03-2013, 06:24 PM   #4
Pam Garlow's Avatar
Trailer: U-Haul 1985
Welcome, and I hear you about the Focus. That's what I owned when I bought my UHaul camper! I now tow with a Ford Escape. The focus was only rated for towing 1000lbs. Keep us in the loop as you refubish!
Old 01-03-2013, 06:39 PM   #5
to FiberglassRV... we're glad you're here
If you got a trailer on Christmas morning, it sounds like Santa knew you were good last year
Just IMHO a suggestion. You can read and devour all kinds of ideas, but it's all about you and your needs. I'd suggest NOT tearing into the trailer, but consider using it for a couple of trips. You'd be surprised at the things that may not need to be done and other items that will. But, you won't know that until you use it. Other's needs and wants are truly not your needs and wants. It does need to be safe to go down the road and clean, because your dirt is cleaner than their dirt.
Old 01-04-2013, 08:13 AM   #6
Manitoba
Words of wisdom.
Old 01-04-2013, 04:07 PM   #7
jrocmagoo's Avatar
thanks for the tips, a big cleaning is for sure the first on the list, then tires and the fridge and just go from there, i do hope to use it this summer so i cant go to crazy but i would like to check the frame and make sure its not going to fall in half
Old 01-04-2013, 05:57 PM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hey!
Another Surfside!
Cool...
There's another new member here with a Surfside who's looking for pics of the door hinges- are yours the original, and if so can you post some pics?
Thanks...
Francesca
Old 01-05-2013, 08:32 AM   #9
alan in alberta's Avatar
Trailer: 2006 Escape 17 B Raven and a Pearl
hi and welcome
our surfside has been a great trailer so far ( lots of work though)
you may want to upgrade the tug a lttle though
we pull with a 3.0 litre ranger and some of the hills slow us down quite a bit
i cant imagine the coquillhalla with a focus......lol
alan in alberta is offline   Reply With Quote
Old 01-05-2013, 04:03 PM   #10
jrocmagoo's Avatar
heres a few quick pics and one of my door hinges, they look pretty stock?
Old 01-05-2013, 04:31 PM   #11
Hey- thanks, Jeremy
They sure look stock to me!
I'll bet those are refrigeration hinges of some kind. Lots of mfr's used that type of thing for fg trailer doors...different styles, of course. It would be worthwhile looking at some of those places. I'd bet that there's a maker name or at least a model number on the backside of the hinge.
Here's a close-but-no-cigar hinge from McMaster-Carr (note the "swoop" to the door surface):
One thing per replacement, though:
That type of hinge often comes in different offsets, so one would have to know what the right one is. I know Trillium door hinges are very specific in that department, and since the Surfside is so much a product of that design I think it likely that the door in this case would have such an offset, too.
Francesca
Old 01-05-2013, 04:51 PM   #12
jrocmagoo's Avatar
i may just put in new pins and screws as the hinge itself is solid but the holes in the glass wore out. does anyone know if there scewed into wood behind that fiberglass or just into one layer of the glass? the raised section looks like it would be reinforced?
Old 01-05-2013, 05:03 PM   #13
If those are woodscrews and not nutted bolts:
They wouldn't hold for any length of time in the skin- there should be reinforcing, probably wood, under the glass on the door itself. It's likely to be a little rotten under there...if so:
My advice is to clean out, enlarge a bit, fill with epoxy or hardwood doweling and redrill for new screws.
On the trailer body the hinges might be attached with throughbolts....if so it would show on the inside.
Francesca
Old 01-05-2013, 08:12 PM   #14
Marinab's Avatar
Trailer: 1978 Biggar / 2007 Toyota Tundra V8 2wd
My Surfside had wood inside the door. I had new hinges put on mine to try and correct some of the sagging of the door.
Marinab is offline   Reply With Quote
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Snow build-up on fiberglass roofs General Chat 5 02-14-2014 05:43 PM
The "Silkstone" build Ian S. General Chat 13 07-02-2008 11:52 AM
Microwave build in and laminate floor Karen K. Modifications, Alterations and Updates 9 01-20-2008 02:42 PM
What would you build? Legacy Posts General Chat 11 06-01-2003 02:01 AM
