As some of you may know by reading older threads there are different bathroom facilities that changed over the years. My 86
Casita has the above board Mansfield/ Sealand holding tank and china toilet. For some unknown reason and for the life of me I cant figure out is that the waste valve is mounted under the trailer and butted up against the frame. To worsen the matter is that the waste pipe is threaded up into the holding tank. Its like they mounted everything on the camper and then put it onto the frame last because I dont know how you can do otherwise to get the tank or valve off.
Im not sure if this can be converted to an under frame BT storage or not as there isnt much depth for frame to ground.
Does anyone know or has anyone modified the down pipe extension so that the valve clears the frame and if so what did you do? Perhaps there is a valve pipe right angle combo that I have not seen which would fill the bill?
Thanks again and hope this made sense?
Mike
