'98 Scamp - Cat Fur OFF - Panel Up Next - Need Suggestions - Fiberglass RV
Old 03-02-2013, 03:56 PM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
I've been pulling the nasty cat fur from the inside of our '98 16' Scamp:
off the walls. Here's to the left of the bathroom door:
and a close up of the edge:
What we're planning on doing is putting up oak veneer plywood on the front wall. I'm looking for suggestions on attaching the wood. Right now I'm tending towards putting some furring strips on the fiberglass so I can run some wires behind the wall. Or... should I just glue directly to the 'glass? What about the edge. Should I butt up to the strip there or should I fur out far enough to cover that. Suggestions?
I don't suppose I'll get lucky enough that Any Of You would have a template of that curve sitting around. I know how to make one, but if someone already has one I'd do a happy dance and grovel at your feet.
Second note will be about bathroom door.
fusedlight is offline   Reply With Quote
Old 03-02-2013, 04:07 PM   #2
CliveAlive's Avatar
Trailer: Boler American #3104
If you add furring strips it allows for a cavity behind the panel which could harbor other things than wires!
If you know what wires you will need I would run them and use flatwire then fix the veneer straight to the fiberglass.
And I would get the veneer as close to the edge as possible. Then I would use caulk in the thin gap left.
Just my two cents.
I just put up a new varnished ply ceiling in my Boler. I'll get pics up and posted soon.
Old 03-02-2013, 04:30 PM   #3
841K9's Avatar
Trailer: 1976 Scamp 13'
Wisconsin
The OP could use 1/4 inch ply and cut shallow grooves into the back side for the wires.
I would love to see that ceiling.
I love the smell of diesel in the morning.
841K9 is offline   Reply With Quote
Formica backsplash over Scamp rat fur? peterh Problem Solving | Owners Helping Owners 53 10-05-2017 09:38 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
98 Scamp Faux Fur fusedlight Problem Solving | Owners Helping Owners 8 08-19-2012 04:54 PM
Scamp rat fur: help andre robillard Problem Solving | Owners Helping Owners 6 04-29-2007 04:33 PM
RAT FUR..CAT DOESN'T UNDERSTAND Susan Tiller General Chat 12 04-23-2006 10:12 PM
