A new home for our Trillium - Page 2 - Fiberglass RV
Old 12-30-2015, 06:27 PM   #15
Roy in TO's Avatar
Originally Posted by Phil 4500 View Post
Looks nice and secure. Did you have to have the brickworks modified to fit tne new garage door?
Thanks Phil,
The brickwork was the easy part, it is brick veneer (non supporting).
We set up the warehouse racking 13" from the front wall and used that to form a temporary roof support. The existing wooden header and supporting structures were removed from the inside. We then cut a slot in the mortar a foot higher and moved the existing angle iron lentil up. The bricks were then removed and a few spare pieces were used to fix up the sides of the opening.
The header was replaced with engineered wood beams at the appropriate height. The roof support was then moved back to the new header. The 13" space was to allow for the 12x12 box of the roll up door.
Door Installation - ENVIROroll Products
I've got a couple of minor things to do in order to finish this phase of the project.
Next year is another story. During the construction we found the rear wall was in danger of collapsing so we installed a new main beam there as an interim measure. That fix is going to need replacement of retaining walls and underpinning the rear garage foundation. We are contemplating a rear door in the garage which would allow a trailer access to the rear yard.
That is going to require some thinking though ... there is a 3/4 story drop to ground level in the rear. I foresee some exploratory digging, engineers and committee of adjustment before we can even think of getting a building permit. Our proximity to the river which is part of a designated flood control area puts a good chunk of our rear yard under Toronto's notorious Tree and Ravine By-Law. Going through the approval process will take months and cost almost as much as the work itself. A small lottery win would go a long way!
Old 12-30-2015, 08:02 PM   #16
Roy in TO's Avatar
David hasn't been around since 2 December. I sent him a PM a few days ago. No reply yet. Perhaps he's off on one of his adventures and we're in for a good story. Raz
You got me a bit worried there. David and almost a month of no FGRV just don't usually go hand in hand. So I called him. We had a great chat, all is well and we should be seeing more of him again in the new year.
Old 12-31-2015, 05:30 AM   #17
Raz
Raz's Avatar
Vermont
Good news. Raz
Old 01-03-2016, 10:57 AM   #18
Trailer: 1977 Trillium 4500
Nova Scotia
Looks good tucked away Roy...I'm jealous...lol!
Roy S is offline   Reply With Quote
Old 01-05-2016, 08:55 AM   #19
David Tilston's Avatar
No story, just took a month off. Next time I will check in more regularly. It was sure nice to get to know my family again.
It sure must be nice to have a heated space for you Trillium.
trillium
Our New Scamp is Home Dan Jones General Chat 15 03-16-2012 06:46 PM
Our New Escape is HOME!!! Doug & Anna-Marie P General Chat 13 03-16-2009 12:53 AM
Home from our Maiden Voyage! Deb in MN General Chat 6 06-06-2006 09:41 AM
We towed our egg home! Deb in MN General Chat 7 04-05-2006 05:51 PM
