AC Closet Instal - Fiberglass RV
Old 10-03-2016, 02:01 PM   #1
Trailer: Scamp 16
Iowa
AC Closet Instal
Here's an ac mod that I did on my scamp 16. I didn't want a rooftop unit and wanted to keep it simple.
Uglywrench is offline   Reply With Quote
Old 10-03-2016, 03:05 PM   #2
Trailer: Escape 5.0 TA
That is an exceptionally nice installation. Very nice fiberglass work! Have you tried it out in really hot weather?
starbrightsteve is offline   Reply With Quote
Old 10-03-2016, 03:53 PM   #3
Trailer: Trails West
Door gasket? Can't tell from the photo if there is one or not.
Old 10-03-2016, 08:02 PM   #4
Markz's Avatar
Where do you pull the cold air in from and what do you do about draining the water?
Beautiful work on the fiberglassing!
Markz is offline   Reply With Quote
Old 10-03-2016, 11:01 PM   #5
There is a little hole in the fiberglass just below the door, you have to look close to spot it.
Old 10-03-2016, 11:57 PM   #6
Trailer: Scamp 16
Iowa
Thanks for the nice words! The cold air intake is on the roof behind the awning. It took a a pretty big rooftop rv refrigerator vent cover but it's barely noticeable. Rather than sacrificing roof strength by cutting a large hole in the roof for the vent, I drilled a 5, 3" holes evenly spaced then modified the plastic cover for the curve of the roof. I fiberglassed the cabinet to the outer shell to make it completely water tight so I didn't put a gasket on the exhaust door. I did build a fiberglass lip around the door, just no gasket. Not yet anyway. I'm not really sure if I need one.
Old 10-04-2016, 12:07 AM   #7
Trailer: Scamp 16
Iowa
8800btu. I've used it in the 100's and it keeps it at 70 easily. Walmart off the rack window unit. $100. West Stem epoxy and fiberglass cloth $125. Cold air vent cover and misc hardware $50.
scamp, gravel shield, instal Kenny Strong Problem Solving | Owners Helping Owners 14 05-25-2012 12:06 PM
Help on instal of Fantastic Fan in 13' Boler Pat C Problem Solving | Owners Helping Owners 6 05-21-2008 11:06 PM
Scamp 13' Closet Jackie Modifications, Alterations and Updates 5 12-01-2005 07:32 PM
Closet Renovation Legacy Posts Modifications, Alterations and Updates 8 06-18-2003 03:14 PM
Closet removal? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 12 05-19-2003 05:51 PM
