https://youtu.be/YT0acWMObOE
Five years ago I tackled this issue and do use my wheel-well as a condensation trap and cold air sump, which drains water out the bottom of the wheel well.
I lined the entire wheel well with heavy
weight plastic (large contractor's bag) and added a drain at the lowest point. It created both a surface to adhere the bag material to and structural contouring by using Great Stuff foam. It is very stick and hardens quickly.
First, I sprayed the Great Stuff on the wheel-well and the closet walls surrounding the wheel well.
Second,I filled in the bottom of the wheel-well with a slope leading to a vent I use for draining.
Third, I pressed the heavy gauge plastic down onto the tacky foam, molding it as I created a water tight basin. The Great Stuff not only acted as the adhering agent but also as a sealant and structure.
I had poured gallons of water into my wheel-well to test it before closing it in under the air conditioner. No leaks! This lets the air conditioner drain wherever it may. No matter where it drips, its going out the same place.
