Access to fresh water holding tank. - Fiberglass RV
Old 02-04-2013, 01:51 PM   #1
Trailer: Scamp 19ft 5th wheel
Question Access to fresh water holding tank.
We have a 19 ft 2008 Scamp. I have winterized the unit. In the spring when it is time to flush out the RV antifreeze---there is no way to access the inside of the tank---so I can flush out the antifreeze. Can an access be cut into the top if the tank----if so, what should be used?
Thanks for any help: Jerry
Jerry in Colorado is offline   Reply With Quote
Old 02-04-2013, 01:55 PM   #2
Deck plates: WEST MARINE - Screw-in Deck Plate, 8", Smooth, White
Problem solved!
Old 02-04-2013, 03:55 PM   #3
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
If you do decide to go with the ABS cover above, do make sure it's the type of ABS approved for use with potable water. If it is, it will carry the marks described at this link.
Francesca
Old 02-05-2013, 04:54 PM   #4
Mile High Thank You !
Donna & Francesca: Thank you for the information on using a boat deck plate. We do have a West Marine here in Denver. It is great to know how much campers care for each other----- Thanks---- Jerry
Old 02-05-2013, 05:13 PM   #5
Jerry, the advantage of deck plates is you can thoroughly dry and inspect your fresh water tank. No more groddies! Make sure any caulking is for portable water too.
And, once it's dry... you know you don't need to put anti-freeze in it. Right? You can disconnect the fresh water tank and using your pump... pump anti-freeze right from a jug into the plumbing system... by passing the fresh water tank AND the hot water tank (if you have one).
Good luck!
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Can you separate holding tank from water heater? Bryan L. Plumbing | Systems and Fixtures 9 04-13-2009 04:12 PM
can anyone out there tell me how you access the fresh water tank on a verna crowell Problem Solving | Owners Helping Owners 8 09-27-2008 06:03 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
