Acorns driving me "nuts" - Fiberglass RV
Old 03-08-2015, 04:20 PM   #1
Pineapple Man's Avatar
Trailer: Scamp 13'
Ohio
The acorn nuts on my Scamp door are rusty, so I bought SS replacements.
The ones one the door side came off easily, but the ones one the body side just keep spinning ! No access from the inside (looked for bolt heads).
Scamp sells the hinges, so they must come off.
Any idea how to get the nuts off the body side of the door hinge ?
PineappleMan
Pineapple Man is offline   Reply With Quote
Old 03-08-2015, 05:48 PM   #2
papa-t's Avatar
Glade Valley, North Carolina
I'm not sure what year yours is. Mine is 2002 19'. I replaced mine and there are Phillip's screw heads on the inside. Might have to pull back the rat fur but mine are easily seen from the inside.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 03-09-2015, 05:32 AM   #3
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I can't speak for Scamps but on the Casita the acorn nuts are not screwed on the end of the rivet. When the rivet is set, the end expands into the threads of the acorn nut (the aluminum deforming into the threads). On a Casita, if drilling the rivet didn't cause the acorn nut to fall off (usually with the end of the rivet still stuck in it) I would use a small pry bar to pop the acorn nut off.
Without adult supervision...
Also,
Old 03-09-2015, 06:04 AM   #4
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
I would be surprised if the door hinges were mounted by means of rivets. Nuts and bolts allow for adjustments, rivets are a one shot deal. If you cannot access the bolt heads from inside, you may have to split the nuts. Even a hack saw might work. Hold them from spinning with a pair of vise grips.
Old 03-09-2015, 06:08 AM   #5
Paul O.'s Avatar
Steve, I like the sig line!
PS. I had to look it up, by the way...
Old 03-09-2015, 09:04 AM   #6
bullfrogeh's Avatar
Cool
I too enjoyed the sig line ! - appropriate for the rivet/acorn problem.
bullfrogeh is offline   Reply With Quote
Old 03-09-2015, 09:18 AM   #7
Steve L.'s Avatar
I read the OP's orginal post more carefully and realized I totally missed the point about the question being about DOOR acorn nut. In which case, ignore my previous post.
Just remember, if the women don't find you handsome, they should at least find you handy.
Also,
Old 03-09-2015, 11:15 AM   #8
Thom Rowland's Avatar
You are a "Red Green Show" fan I see.
Thom Rowland is offline   Reply With Quote
vin
Rivets, Acorn nuts, Rivnuts etc. Dan B Care and Feeding of Molded Fiberglass Trailers 45 11-22-2016 08:21 AM
Speed Nuts Mike Bromley Care and Feeding of Molded Fiberglass Trailers 5 04-30-2010 08:15 PM
Scamp Acorn Nuts Parker Buckley Problem Solving | Owners Helping Owners 8 10-14-2009 08:08 PM
Nuts - Bolts % Other HDW Darwin Maring Problem Solving | Owners Helping Owners 1 05-09-2007 06:03 PM
Rivets and Acorn Nuts Steve L. Modifications, Alterations and Updates 6 11-16-2005 09:36 PM
