Add BAL jacks to my scamp 13 - Fiberglass RV
Old 11-09-2014, 04:30 PM   #1
John Linck's Avatar
Madison, Wisconsin
[ATTACH]Click image for larger version
ID:	78498[/ATTACH]I added BAL low-pro jacks to my Scamp today. Really nice addition and will make campground set up and leveling much faster and easier. I wanted the adjusting screws to face the rear of the Scamp and that meant the jacks are about 12 inches further aft than I first expected (had to clear the gray water valve). Still they are a foot forward than the flip down factory struts. I have no welding skills so I used a treated 2 x 10 screwed to the frame to provide a broad flat mounting surface. One drawback of this is the jacks are 1 inches lower and extend further back than conventional mounting. I don't think I would recommend my method had I not already lifted the Scamp 3 inches. This lift gave me plenty of ground clearance to allow my unconventional orientation.
Reason for facing the jacks rearward. My Scamp lives in my narrow garage when not on the road and that is the main reason for facing the screws rearward. I could not reach one side otherwise. I considered reversing one jack and having a 4 foot extension on my adjusting tool and adjusting both from one side, but that seemed cumbersome. If you mount the regular crossways orientation I don't see ground clearance being a problem on an unlifted Scamp.
Also I'm looking forward to having a few more pounds on the rear since the Scamp has been a bit tongue heavy since leaving Backus.
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Bal Leveler: Does It Also Require the Purchase of Bal Tire Chock? CampyTime Towing, Hitching, Axles and Running Gear 8 09-15-2014 05:25 AM
Bottle Jacks vs. Scissor Jacks Jane P. Towing, Hitching, Axles and Running Gear 21 02-26-2011 07:17 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
BAL Leveler, Stabilizers and Jacks Greg Conly Care and Feeding of Molded Fiberglass Trailers 29 04-06-2008 09:26 AM
BAL Leveling Scissor Jacks Adrian W Modifications, Alterations and Updates 5 12-30-2006 07:55 PM
