08-07-2014, 06:44 PM
#21
Trailer: Escape 21 - Felicity
I like the way Escape mounts their panels; aluminum square tubing is fabricated with a standoff and then epoxied to the roof for mounting the panels. No holes are drilled through the fiberglass.
08-07-2014, 07:34 PM
#22
Originally Posted by tractors1
Place I would start with is choosing roof mount or not (suitcase style.) If roof mount, what size panel will fit that meets my power needs and how to mount and wire it? The rest (controls, battery wiring, etc) all depend on which way you go with the first decison.
Charlie Y
There are pluses and minuses for both. The roof mount is great if you're going to do most your camping in the sunny south west. Otherwise you're looking for sunny places to camp rather than shady places to camp.
The portable ones require a bit more attention at camp as you chase the sun with them. However chasing the sun means faster charging times.
As the what's needed there two major ways to get the proper amount of power. One is to increase the battery capacity size and solar panel size to more than needed. The other is to reduce your consumption and thereby reduce the weight needed in batteries and solar panels along with cost of both.
Now here's my story. The first thing I did was change all the lights to LED lights. (not the running or tail lights since they don't run off the house battery). In my little Scamp if I turn all the lights on I draw about the same amount of current as one incandescent light. The only thing that requires battery power other than lights is fan in furnace. I charge the small 80 amp hour group 24 house battery about once every 3 or 4 days if I need the furnace in the mornings or every couple weeks if I don't use the furnace. The solar panel is 65 Watts, about 4.2 amp charging current in full sun. We've been up to 90 days off the grid, no electricity. It works well for us.
08-07-2014, 09:28 PM
#23
Connecticut
I knew I wanted the ability to handle many loads. For example ham radio, inverter, CPAP, TV/entertainment system, and the typical fans and lights.
If you view your camper as a home or 2nd home and plan to spend s a lot of time in it, the costs for solar and other upgrades quickly pay for themselves. In my case, boondocking paid for the panels and other hardware already. I lived in min
My rationales was buy two 105 watt panels, and see how they work out. Then with my military discount, I thought, why not splurge and start with four panels. These worked fantastic, and by measuring amp hours produced I determined that I could fully recharge my batteries on a bright overcast day with two more panel. Living in the Northeast, you can imagine how that appealed to me. Even on dark overcast days and in rain I was producing small amounts of power.
Next I discovered how much I could produce in power on a sunny day when the batteries were deeply discharged and realized the depth of my battery bank helped tremendously.
I read how winter time campers tilted their panels to catch the maximum amount of sun-- an extra. 30%. Why should I felt my panels to get that sort of game. I chose to add two more panels, increasing my charging by 50%.
08-07-2014, 09:45 PM
#24
Conrad,
For you, you probably made close to the right decision. Maybe a bit over kill but if it works for that's great. The Original Poster (OP) has a 13' Burro and didn't mention anything about full timing in it. More than likely he's a week ender. Therefore his needs are a whole different than a full timer. It always to remember who you primary audience is and ask the original question. Not all campers or camping situations are made equal.
08-08-2014, 05:43 AM
#25
Trailer: Scamp 13'
One other thought. In Florida and a good part of the Southeast most of the trees that we park under are pine trees. The pine trees shed the lower branches, some are heavy enough to pierce an aluminum roof. With that in mind I have decided on the portable suitcase panels as the falling branches may shatter the glass on the panels. Last year I parked a Nomad for 6 months on the St Johns River. I bought the camper new after 6 months under the pines the roof looked like it went through a hail storm it was covered with branches. Some of the impressions looked deep enough to pierce the roof.
08-08-2014, 06:56 PM
#26
Trailer: 1990 13 ft Casita DLX #6
08-08-2014, 07:27 PM
#27
Trailer: Currently Shopping
If you're going to spend several days off the grid with a trailer that's mostly electric charging and battery capacity can add up quickly. The other thing that can add up fast is weight and if you're trying to stay lite that can be a real issue. Framed solar panels weigh near 25lbs each. With the new flat panels that may change a lot.
08-08-2014, 07:37 PM
#28
Trailer: 1984 13' Scamp named "Ramblin Rose"
The flexible panels are only about 3lbs (it had a shipping weight of 6.4lbs, and at least half of that is the double layer corrugated box it ships in)... that's part of why I went with the one I got, plus it was easily mounted with 3M VHB tape (and it's VERY secure), so no extra holes
08-08-2014, 07:47 PM
#29
In addition you can attach them to nets and with a little bit of work aim them for max performance. The only downside is the price per watt is much more and the normal framed ones.
08-08-2014, 09:33 PM
#30
Trailer: Burro 13'. 1982
Montana
Hi...it's me...the original poster. (Female btw)..... I posted a picture of my electrical set up and it turns out I've got a 6 V marine battery and something from Cabelas that charges the battery when connected to power. So......do I need to change out the battery to a 12V? I need another thing ......converter? So with that set up, I'm looking for solar that will let me keep my 3 way frig on wo using propane. I don't use the stove and use battery latterns at night. I've decided on portable because my unit is tiny and we got a lot of hail this year....don't want to mess with installing on the roof. So, 100 wattage(?) and how do I attach it to the battery or whatever that second thing is? Met hanks for all of the info......I was overwhelmed.....but it was interesting!
08-08-2014, 09:44 PM
#31
The battery you posted in the other thread looks like a normal group 24 12V battery, unless there was something else you didn't show?
You may not be able to easily run your 3 way fridge on 12V/solar. It will depend on your fridge's actual power demands - and you'll need to know that before you can really start to plan out a solar system or battery bank. I don't mean that to discourage you, but if your fridge needs 50 amp hours a day to run, you'll need at least two 100W panels and more than one battery.
I am running my super-efficient 12V only Engel fridge off one 100W panel and a single group 24 battery currently, but the battery is more of a temporary solution than anything else... it's working fine and I could conceivably run it for about two days with "no" sun, but I would like to have more buffer than that if we happen to camp in a shady location. Dual 6V AGM batteries are in my future so I have more reserve battery power and I can put them under the dinette bench without worrying about venting them. My single 100W panel is fine for my power needs, but it might not be for someone else's.
Also, because someone PM'd me and asked, my fridge only averages about 22-24 amp hours a day. All of the LED lights in my camper only draw .8amps an hour if I turn them all on at once (just one on uses slightly over .1amp an hour), and if I left them on all day/night they would use nearly as much as my fridge... that's how efficient the fridge is
08-11-2014, 06:24 PM
#32
Connecticut
Originally Posted by The Minimalist
<snip>
I think the jury is still our on MPPT controllers given the additional cost. On the positive side, my understanding is that under normal conditions the MPPTs are actually functioning in PWM mode. The cost/benefit to me is still in question.
My understanding is the MPPT controller are more effective and make sense in a daily cycling where you want every Amp Hour of energy out of your panels.
But if you don't use a lot of power and it is easy to recharge--as in long summer days, or for boat or campers that are only used once a week, the lower cost controllers work fine.
For the last few weeks, my batteries have hardly been discharged unless I leave on the inverter 24/7. There is so much sun right now, my batteries don't cycle hardly at all. Many people would find the less expensive controllers adequate in this situation.
It would be interesting to do a side by side test and find out for sure.
08-11-2014, 06:25 PM
#33
Connecticut
Which Engel do you have?
08-11-2014, 06:50 PM
#34
The SB70.
08-11-2014, 08:14 PM
#35
Trailer: Scamp 13'
Here's the wattage usage for an Engel MR040F-01 plugged into 120v. I was told by the Rep that they are more efficient at 12v and use up to 10 watts less at 12v. The start up is 49 watts, running watts for the first 20 minutes is 44 watts after 20 minutes it kicked down to 5 watts. I put a thermometer in after 20 minutes the temp was 30 degrees inside. All I have is a 120v watt meter if I find a 12v I will post more pictures later. My 3way on gas runs about 1 month on a 20lb tank and hopefully I will be able to run the Engel in freezer mode on my 150 watt panel and a group 31 AGM 12v battery indefinitely.
Not to bad considering a 5000btu ac pulls about 500 watts!
08-15-2014, 05:28 PM
#36
Trailer: Scamp 13'
Night Sailor a question for you. My portable 150 watt suitcase should be in next week. I willl have it hooked up to a group size 31 AGM Deka battery. My question is is their a device that I can purchase that shows the incoming amps ond the outgoing that is be used from the battery? Also any recomendations for a pure sine wave invertor to power small electronics using about 50 watts? My Engel fridge draws around 40 watts on 12v, charge controller is 10 amp MPPT... Thanks for the reply....
08-15-2014, 06:22 PM
#37
SW Florida
Which small electronics could need pure sine wave??? Everything should run fine with a cheap invertor from ebay or walmart.
Sergey
08-15-2014, 11:09 PM
#38
Trailer: Scamp 13'
I was under the impression that the pure sine wave inverter was not only more efficient but also a cleaner power source. All I will be powering with 120v will be
a LED TV. I will be running 1 only battery so efficiency will be important.
08-15-2014, 11:49 PM
#39
Methinks, you'd have to watch a lot of TV.
Why not just get a TV that runs on 12V, and comes with a 12V cord?
08-16-2014, 06:01 AM
#40
Trailer: Scamp 13'
I dont watch a lot but it is nice to have to watch the news. I wasn't aware
of so many 12v TV's on the market. I will look at that but I did a quick google
and didn't see any name brands like Samsung or Sony. I will keep looking.
