08-02-2014, 08:48 PM
Trailer: Burro 13'. 1982
Montana
Add solar?
For someone with not a lot of carpenter, etc. skills, how hard is it to add solar to a 13' Burro? Thanks...happy camping.
08-02-2014, 09:05 PM
Louisiana
It's not difficult, but the first thing you need to do is determine what your daily amp usage is projected to be. Once you know that you can begin to determine the type, size and quantity of panels you will need, the type of charge controller, and the batter(y/ies) you need, and how much you want to spend. Also, are the places you camp most shaded or prone to overcast skies?
Go here for a decent start. The 12volt Side of Life (Part 1)
This will give you a good understanding of the dc system in your trailer. Part 2 gives you a good foundation for determining your needs.
Clif
08-02-2014, 09:16 PM
Linda,
Portable panels need no installation, and have some advantages over mounted ones. Just clip them to your battery. Solar is a must have item for boon dockers.
Russ
08-02-2014, 09:47 PM
Trailer: 1984 13' Scamp named "Ramblin Rose"
Installation is not difficult, but I second the suggestion to consider your energy needs. Once you have that figure, most of what you need to figure out has to do with storage (batteries).
I would never suggest hooking any panel straight up to your battery - a charge controller, even a cheap one is important.
Solar was the first modification I made to my camper, along with installing a 12v fridge that is easily powered by my system. It has been by far the simplest mod I've done.
08-02-2014, 10:53 PM
Connecticut
But not your best mod Sarah. Love the graphics on your camper!
08-02-2014, 10:56 PM
Connecticut
It is fairly easy. Anything you add for solar will be a help and ensure your battery lasts a long time. Warning! Free Power is very addictive. You may want to plan in advance for adding more. Generally one 100 watt panel will be all you need for three season camping.
You will need:
1. Solar Panel and mounting method
2. Charge controller to prevent over charging.
3. Wire to connect to the batteries and possibly connectors of some sort
08-03-2014, 07:31 AM
North Florida
I AM a Carpenter, and I am still starting out slowly on this solar thing. I have bought a couple of panels and a good (MPPT) controller. My plan is to use them as a portable system for a while and get things sorted out and then mount a couple of panels permanently on the Scamp. I think I will always keep at least one, maybe two, panels for portable use in case the trailer ends up parked in the shade or really poorly oriented.
One note here that my research indicates is missing and really poorly discussed about solar is fusing. I bought a “system” from a company and even though their installation diagram shows fuses none were provided with the kit and the company in fact does not even sell any. When I emailed to ask their recommendations they did indicate a style of fuse and told me they were available on Amazon or Ebay! I thought that was beyond lame. To sum, I suspect there are a whole lot of solar installations out there either poorly or not fused at all.
08-04-2014, 11:16 AM
Mike N Laurie-let me know how that system works out for you-I'm definitely interested in investing in something like that. I'm struggling with finding quiet campsites with electric and am thinking solar is the way to go. Anyone use Goalzero products?
08-04-2014, 12:33 PM
Trailer: Scamp 13'
What I understand the size of the panels and the quality of the charge controller makes a lot difference. The panels that have the charge controllers glued to them need to be close to the battery as the charge controller needs to be within 5' of the battery. Watch YouTube this is the charge controller www.PortableSolarPower.biz uses on his 150 watt portable suitcases. I ordered one today Ryan said it should ship in a week to 10 days. I will let you know how it works.
08-04-2014, 12:57 PM
Trailer: Scamp 13'
Night Sailor is the person to talk to. I believe he is boon docking or off grid and his array consists of 900 watts of panels and has 400AH of batteries...
08-06-2014, 05:05 PM
Louisiana
This retailer video interesting in that; 1. He compares the MPPT controller he sells to a shunt type on-off controller rather than the more common PWM controller. 2. He uses a DC power supply rather than actual solar cells for his demonstration.
Shunt controllers are old technology.
MPPT as advertized can deliver up to 30% more energy to the batteries. However, all my reading indicates they are most effective when the PV panels are cool, and/or in low light conditions. The panels they are normally paired with, mono and polycrystaline cells, loose efficiency in high heat or low light or shaded conditions.
I think the jury is still our on MPPT controllers given the additional cost. On the positive side, my understanding is that under normal conditions the MPPTs are actually functioning in PWM mode. The cost/benefit to me is still in question.
Not trying to poke sticks....just my two cents.
My experimenting and study continues. For all of us the goal is a balanced system.
Clif
08-06-2014, 06:50 PM
Trailer: 2010 Scamp 16
Those suitcase systems are really nice but people have done just fine with a controller wired to the battery and a panel stashed in the camper for travel and propped against all manner of stands from PVC plumbing pipe to fabricated from metal or wood.
I recall a member Carol had hers stowed with a couple of hooks and bungee cord to hold in place against the outside of a closet or bathroom.
Nice to have lots of surplus solar capacity but I think starting with what Clif said is smart, how much power will the things I'm going to use pull out of the battery in a day. That tells you how much solar panel you need to put that much power back. If you want to (or can afford to) provide a cushion above what you need that is good but shopping without knowing actual need you can waste money under purchasing or over purchasing.
08-06-2014, 08:04 PM
Trailer: Escape 21 - Felicity
Place I would start with is choosing roof mount or not (suitcase style.) If roof mount, what size panel will fit that meets my power needs and how to mount and wire it? The rest (controls, battery wiring, etc) all depend on which way you go with the first decison.
Charlie Y
08-07-2014, 12:01 AM
Connecticut
Close. I have. 630 Watts of panels and 400 AH of batteries. I didh I had another 300 watts of panels, I would grid tie it to the house and reduce our energy needs.
08-07-2014, 12:05 AM
Connecticut
Charlie Y
That's good advice. Will you be in the shade or not? Some people do both. My preference is fixed and extra panels to make up for losses due to fake mounting. Other people prefer movable panels angled directly at the sun to maximize efficiency and reduce cost.
08-07-2014, 12:31 AM
Trailer: Currently Shopping
The key to keeping the panels running well is spacing them off the roof. The more air you can get under them the better they preform.
08-07-2014, 06:12 AM
Trailer: Scamp 13'
Night Sailor is this you or kinda what your BigFoot looks like?
I just ordered my first 150 watts and now I'm looking for
another 100 watts. You said they are addiciting, your right!
08-07-2014, 10:25 AM
That is why I think it starts with what size panel(s) are required to meet an individuals power needs and type of camping.
That leads to an answer to portable or fixed or both as being a good solution. How to implement the solution and equipment I agree is last choice.
If you must have 50 amp/hr a day to support a 12 volt fridge, CPAP machine or furnace for colder weather camping that requirement might well lead one to decide they need big mounted panel and portable one to supplement it.
If your like me with no AC and always looking to park in the shade but with minimal power requirements small portable would seem the better choice. Furnace has no blower and other than two lights all I'm doing is charging camera, phone, kindle and laptop.
On the other hand in a 13 ft. Scamp how large a portable panel I could easily find a place to store would become an issue if my power requirements were greater. I start running a vent fan at night and that could change things to where an amorphous roof mount and small portable or 100 watt or more suitcase would be the option to implement.
Do a lot of your camping in the desert southwest or great plains roof mount off the surface of the roof might be just the ticket. Could even make the roof a little cooler. Bonus.
I guess I'm saying if you don't know how big the panel(s) will need to be it's hard to arrive at where to put them.
08-07-2014, 06:09 PM
Connecticut
Mine are flat mounted facing up. Their are not noticeable at first glance at the camper. They cover about 35% of the roof area.
