10-09-2002, 10:12 PM
Added Generater Box
I thought I would share a modification I made to my Casita. The Casita came with two propane tanks. The weight of each full propane tank is about 48 lbs.
I chose a Honda eu2000i generator because of the weight 49 lbs and the noise level is very low.
My new box...
<img src=http://www.fiberglassrv.com/board/uploads/3da4fe3901cdahonda-box.jpg/>
10-09-2002, 10:14 PM
Open lid
Open Lid
<img src=http://www.fiberglassrv.com/board/uploads/3da4fe8ad5e9bopen-box-side.jpg/>
Inside
Inside the box...
<img src=http://www.fiberglassrv.com/board/uploads/3da4febad72c9open-box.jpg/>
10-09-2002, 10:16 PM
Curb side
Note the little hole for the exhaust...
<img src=http://www.fiberglassrv.com/board/uploads/3da4fefdd67d6exhaust.jpg/>
10-09-2002, 10:18 PM
front door
If you look close you can see the little front door to access the pull rope to start the generator.
Also, there is a 12 volt fan in the bottom to keep the air circulating and thus keep the air cool in side. It only runs when the generator is running.
10-10-2002, 06:16 AM
Beautiful box
Nice job Michael,
Really a nice piece of work. Just keep Charles away and make sure its locked.....
10-11-2002, 09:18 AM
Neat set-up
A generator really does seem a good idea to me, and yours looks like it was made for our little trailers.
Can you run a three-way fridge from this? ... and all the electrical lights, microwave, etc. from it? As you can see, I'm new to all this. I'd like to think I could just switch my system to AC and run it from a generator such as yours here.
10-11-2002, 09:48 AM
yes
Floy,
Yes, you can run anything from the generator. One word of caution. You can only run one of the big ticket items at a time; like microwave, heater, airconditioner. To use the microwave, we turn the airconditioner off for the 3 or 4 minutes we are using the microwave. We put refrigerator on propane when we need to use the generator.
I hope this helps.
10-11-2002, 09:50 AM
Embarassed...
Now I'm embarassed for posting the pictures of my Watt Box in another thread :red
Nice box, Michael. Did you fabricate it, or buy it?
It looks like diamond plate aluminum, but where did you get the corner molding and what is it? Are the corners welded?
10-11-2002, 09:55 AM
I made it
The sides are made from 1/16th inch aluminum diamond plate. The frame is made from 1 inch steal angle iron. I welded the frame up and then smoothed and filed with bondo to make it look good. I painted the frame with marine boat paint and used stainless steel faseners to put it together. The piano hingers are also stainless.
There is no bottom so that propane cannot get trapped inside and it will run cooler. I think that is about it.
10-11-2002, 02:26 PM
Thanks Michael
01-03-2003, 11:22 AM
I was wondering
Michael, the more I look at this great generater box, I keep wondering if I could make something like that out of exterior grade plywood and paint it. I know that it won't be as sturdy or durable as the metal but wonder if it would hold up 'well enough.' I'm thinking of making one that will house both propanes and have a little tool storage in the front. Either that, or build a small one and move the battery in front of the propanes.
If properly primed/painted and I use angle iron on the corners, do you think it would hold up?
01-03-2003, 11:30 AM
Orginally posted by Suz
Sure. I made a camp stove that way and it has lasted over ten years and still looks good. The main reason I used aluminum is that it doesn’t rust and I thought it would look good.
The aluminum diamond plate is as easy to work with as plywood, just a lot more expensive.
Good luck on your project.*:)
01-03-2003, 11:41 AM
Box
Suz,
I got to see the Mike Box on Boxing Day and let me tell you, it is a work of art.
You might consider a thatched box. I'll bet Dena would send you some palmetto fronds. Add a tropical touch. :laugh
| Thread Tools |
| Display Modes |
No events scheduled in the next 365 days.
