Adding a bath to 16ft Scamp - Fiberglass RV
Old 06-08-2011, 09:07 AM   #1
Trailer: Currently Shopping
Alaska
I have searched and could not find exactly what I needed so I am sorry if this has been gone over.
My neighbor has a 1988 16ft scamp with the side closet but no bath.
1. Is the side closet the same dimensions as the side bath? It looks the same to me but I am not sure.
2. Is it possible to convert the closet to a side bath/shower model?
I am worried mostly about the plumbing underneath such as the black water tank etc. I am not worried about the work. I need a project anyway. Just need to know if this is even possible and the best way to go about it.
Thanks for any help
harms is offline   Reply With Quote
Old 06-08-2011, 11:27 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
See if this helps Adding factory Shower stall to Scamp
Old 06-08-2011, 11:34 AM   #3
I dont know for sure but I would think that it would be a good bet that the side closet is the same as the bathroom without the plumbing. The black water tank on the Scamps with a side bath is all above the trailer floor. The black water tank sits on the bathroom floor and the Sealand toilet is attached directly above it. You would need to put a hole through the floor to install the sewer pipes for dumping the black water tank. The black water dumping pipes on the Scamp are totally seperate from the grey water dumping system and are located directly under the black water tank. Scamp also runs the water for the toilet around the inside outer edge of the trailer which makes it all hidden behind hatches/cabinets making it a little hard to do after the fact - unless you ran the water pipe under the trailer. The scamp parts department has pretty well every thing you would need to install it.
Sealand Black Tank For Toilet
Scamp Trailers Plumbing
1983 13 ft. Scamp - Front Bath JOE DRISSEL Referrals: Molded Fiberglass Trailers 0 06-27-2010 04:02 PM
Wet Bath in Scamp 16' Steve and Rosemary Modifications, Alterations and Updates 9 03-17-2010 11:16 PM
Scamp 5er Bath dimensions Betty L. Problem Solving | Owners Helping Owners 2 11-02-2008 08:14 AM
16' Casita/Scamp/Burro without bath! Lee Morton Wanted: Molded Fiberglass Travel Trailers 2 05-28-2008 09:35 PM
Bath Remodel - 19' Scamp Richard W Plumbing | Systems and Fixtures 5 03-22-2008 07:26 PM
