Adding a Brake Flange - Page 2 - Fiberglass RV
Old 01-25-2013, 06:42 AM   #15
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Brian B-P View Post
That makes sense, but UCF builds their Flexiride "rubber torsion" suspension arms with the brake mounting flange integrally cast as part of the arm... there are design choices here so assumptions are dangerous.
See UCF's Flexiride 3500 axle leaflet for an illustration.
Clearly, this is correct for the Flexiride. As the arms are replaceable, one could add new arms with flanges to avoid replacing the whole axle assembly, though it appears that the flanges may be standard.
Excellent info, Tom. : The normally informative Dexter Axle site doesn't clearly show a flange-equipped Torflex that I could find.
This means that a flange could be added to the spindle, but readily available flanges for adding to beam axles will still have the wrong size hole to fit the spindle (unless a Torflex spindle in our sizes has a huge diameter). Also, these axles come with regular and long spindles, so length should be checked for enough room to add the flange in the right position.
I looked at the Scamp owners manual (an excellent piece of work by the way). They show grease seal inner diameters of 1.5" and 1.719". As the brake flange sits on the next larger diameter, the ID of the brake flange needs to be bigger, but I was unable to find the diameter of this portion of the spindle. The readily available flanges I found had inner diameters of 1.64",1.69",1.75" and 2.27".
This would be an easy part to fabricate (a 1/4" plate with 5 holes) but it would be nice if the parts were available off the shelf. Surely they are mass produced to meet the OEM demand.
If anyone has a Dexter axle and could measure the diameter of the spindle where the brake flange attaches, it would be nice to add it to this discussion for future reference.
Old 01-25-2013, 08:21 AM   #16
Brian B-P's Avatar
Good stuff :
Yes, Dexter must have them; unfortunately that doesn't mean they are added by anyone ex-factory, or that they are available at retail. Cross your fingers...
Yes! Real information is good.
This helpful person could also check the length of the spindle.
Old 01-25-2013, 08:33 AM   #17
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I pulled this sketch off Goggle images to show where the flange welding location is relative to the rubber. I've done a fair amount of oxy-acetelyne and arc welding. I would be confident that I could arc weld the flange onto the spindle without heating up the rubber components.
If you have different experience, that's fine.
I've put them on. A spindle shouldn't be heated that much anyway, so I wouldn't worry about the rubber, myself. I just stitch weld it with long breaks in between.
Old 01-25-2013, 12:22 PM   #18
Trailer:
The brake flanges would seem to be a lot further from the rubber than the axle mounting brackets and a lot of those have been welded to frames for a lot of years.
Old 01-27-2013, 10:04 AM   #19
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Snow finally melted and I crawled under the Vt, after looking at it I agree there is a lot of mass to absorb the heat before it gets to the rubber. so I herby refute my previous comment.
michael j.
mmeyer is online now   Reply With Quote
Old 01-27-2013, 02:30 PM   #20
Thomas G.'s Avatar
michael j.
Thanks for the follow up , Michael.
Brake Flange??? Make My Day... Richard Hayes Towing, Hitching, Axles and Running Gear 11 10-15-2012 03:13 PM
Trillium 4500 City Water Flange Laurie Problem Solving | Owners Helping Owners 3 07-04-2012 01:13 AM
1977 13' Boler - flange for brakes always on axle or not? Melanie Problem Solving | Owners Helping Owners 11 07-03-2011 08:54 PM
Brake mounting flange? koehlerk Towing, Hitching, Axles and Running Gear 5 05-25-2011 09:20 PM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
