Adding a Pop up top to a 13' scamp - Fiberglass RV
Old 03-10-2008, 01:19 PM   #1
Jonathan S.'s Avatar
Trailer: 1976 13 ft Scamp
I'm a 6'3" guy in a Scamp with a 6'1" interior height. I spent 5 years driving a VW Westy and that pop top was a wonderful thing. Where can I purchase an after market poptop add-on for my 1976 13' Scamp. There has got to be one out there somewhere. Anyone done this? Any structural implications? I'd like to go as large as possible.
Jonathan S. is offline   Reply With Quote
Old 03-10-2008, 02:09 PM   #2
I've never seen an aftermarket top made for a Scamp, doesn't mean they don't exisit...I've just never seen one.
However, a Scamp sold on eBay a while back, where someone had cut the raised portion of the roof off, raised it and refiberglassed. Sorta looked like the Havasu but uglier (my opinion) Kinda looked like a box on top. If you really were looking to raise the roof, that's the way I'd do it...only hopefully it would look better! Then add enough strength back into it for A/C, etc.
Check out the Havasu here: Havasu Album
Old 03-10-2008, 02:17 PM   #3
I thought about that approach but am hoping to find something like the poptop on the Samba in the photo below. I'll find something that will work eventually I'm sure. I've got a few ideas cooking. I talked to the guys at Scamp about it and they classified my idea as "crazy". Heh.....good thing I didn't mention my surround sound with ipod connection and flip down flat screen idea.
Old 03-10-2008, 02:20 PM   #4
Well, plenty of poptop molded lightweight fiberglass RVs here! Maybe one of the Compact/Hunter gang can give you some pointers.
Old 03-10-2008, 02:23 PM   #5
Bingo...looked at the photo albums and thats exactly what I'm talking about. Again...thanks!
Old 03-11-2008, 06:03 AM   #6
Steve L.'s Avatar
If you wanted to go deluxe, here's a link to someone who added a pop-top to his van. He was able to buy the whole mechanism complete:
http://www.geocities.com/vwcamper72/Riviera1.html
Here's someone who's selling a the pop top and mechanism. The add was updated in February, so who knows if it's still available. But it shows they're out there.
http://www.thesamba.com/vw/classifie....php?id=532237
My sense from glancing through some of the sites is that the top has to be really fastened down securely. Apparent wind speed from traveling down the road can really grab these suckers. (There was at least one recall on VWs where the tops opened unexpectedly while driving! YOWSER!)
Without adult supervision...
Also,
Old 03-11-2008, 08:08 AM   #7
Quick Jonathan, the Samba one is in New Mexico and the owner won't ship it!
Old 03-11-2008, 08:57 AM   #8
I noticed that, however it is much larger than I need. That one is a full top from a 74-?? westy. I'm looking of a smaller top. I may look at making one from a skylight. Its no huge rush...just a place my mind goes when I am laying in bed in my "pod" and the gears start turning. I'm thinking something in the range of 2'x2' or 3'x3'. Heh...a cheaper solution would be a stool that I could sit on while making coffee or washing the cup.
Old 03-11-2008, 09:11 AM   #9
Administrator
Mary F's Avatar
Now you're cooking with gas!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 03-11-2008, 09:22 AM   #10
Steve L.'s Avatar
Mike Watters put a bit of dome on his PlayPac that's about that size. You can just see a bit of in the photo.
Exterior shot of Mike's PlayPac
Of course it doesn't open but the idea of part of a head peeking just above the roof line sort of makes me laugh.
Of course, you might look a little like a hamster in one of those balls!
Better stick with your idea. Mine are just getting silly.
Also,
Old 03-11-2008, 09:25 AM   #11
See...I like that idea. Especially seeing a head sticking up wearing a pair of groucho glasses like yours.
Old 03-11-2008, 09:55 AM   #12
Trailer: 13 ft Perris Pacer
While it might be a little cost prohibitive cannibalizing a split westy for its' pop up section, you might want to consider a Vanagon Country Homes model f/g pop section to retrofit. They're a lot easier to find in the scrapyards, and as long as the fiberglass and pop up mechanism are solid, the canvas and screen should be the easy part if they need repair/replacement. All things considered, it should be a relatively straightforward project.
http://www.countryhomescampers.com/graphic...d%20_Awning.jpg
Angelo F. is offline   Reply With Quote
Old 03-12-2008, 09:28 AM   #13
Mike Watters's Avatar
Trailer: TrailManor (Gone to the Darkside)
I can't take credit for that dome-top. It's a standard PlayPac feature.
Upsides: More light during the day and j-u-s-t enough added headroom that it let me stand up straight if I stood in just the right place.
Downsides: Requires extensive attention or else it leaks like crazy! Mine came with half a dozen layers of various gunk layered into the seam trying to stop it. It's also hard to fit a shade onto. To put it simply: I'm not a morning person. Having all that extra, unobstructed light streaming in in the morning wasn't all that welcome.
Similar domes are fairly easily available (here's a really big one):
The main problem you'd have is getting it to fit on the non-flat roof correctly. You'd presumably run it down the center of the trailer to give room in the aisle.
Another - much more intensive - solution would be to crack the trailer apart at the seam - add 6 inches or so into the gap - then put it back together again. Not something that could remotely be called a 'small upgrade', but gives you headroom everywhere. Course, it'll also screw up the side closet fit (not THAT hard to deal with) and the fit of the door (PITA problem).
I suppose a sort of combination of the two is possible too. slicing off the center bulge, adding a spacer and reattaching. Just as big a hassle as doing it at the seam - but you don't have the extra problems (closet & door).
Course - I don't personally think that having tons of headroom is all that important. 95%+ of the time in the trailer is spent either laying down or sitting. I don't cook in the trailer (prefer doing that outside) and we're not dancing in the trailer either.
The ceiling height on the cargo conversion I'm supposed to be working on is REALLY low (something like 4.5 - 5 feet inside). I briefly toyed with the idea of adding a dome onto the top for standing room then decided not to bother. My little fiberglass cargo trailer has a flat roof too - so it would be relatively simple. I just decided that when all was said and done, it wasn't that important to me. It's tall enough (barely) that I can move around on my feet (beats a teardrop in that regard) and the extra height wouldn't be used that much.
The biggest appeal of the pop-tops IMHO is not so much the headroom - but the idea that you could replace the fabric sides with nylon window screen material for the ultimate roof vent. That would be my primary reason for considering such a thing.
Mike
Watters
Mike Watters is offline   Reply With Quote
Old 03-12-2008, 09:40 AM   #14
Trailer: 75 Boler
You need to think ERIBA PUCK!
These sites should inspire you!
http://groups.msn.com/EribaOwnersPho...ictures?Page=6
http://www.eriba-amiga.co.uk/index.html
Cheers
Mike
Mike Montville is offline   Reply With Quote
Old 03-12-2008, 11:27 AM   #15
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
Check out VW Westie rags and websites.
Wonder what parts is listed in JC Whitney for Westies hmmmm?
Coach George Jessup is offline   Reply With Quote
Old 03-12-2008, 12:38 PM   #16
Bobbie Mayer's Avatar
That one has basically the same poptop as the Campster, just bigger. I don't think it would be terribly hard to duplicate a Campster poptop. The hardest part is making the two pieces fit water tight when closed, I think.
Bobbie
Old 04-21-2008, 03:56 PM   #17
Trailer: Scamp 13 ft
I am in the process of converting a Ford e350 into a camper and I added a poptop. I experimented with different designs and always found myself going back to the hinged pop for simplicity and stability for making it yourself in your garage.
I cut the fiberglass roof of the van and added a raised wood trim around the hole for mounting purposes and keeping water out. Then I ordered some high tech cloth like sunbrella that breaths but is water proof. I build the roof portion and hinged it from a piano hinge on the end. the top stays up with a piece of ply that folds up when the top is popped and keeps it upright. Hardest part was sewing the fabric and fitting it to the opening, but it turned out on the first shot. Must have been beginners luck. Everything is epoxied and I haven't had any leaks since I did it a year ago. The only advantage I had was steel supports welded across the roof for safety. Those gave me a fixed structure to mount to.
I recently purchased a 13' scamp so unfortunately my progress on this project has slowed, but it should be a pretty sweet "Poor Man's" Sportsmobile if I ever get it done. The bonus of going low tech as well is that you can repair it with anything at a hardware store vs machined parts from a company. You could always think about something like this. The scariest part is cutting the roof. I stared at it for days before I grew a pair and had at it. Seems like a bad idea at first, but I'm really glad it's there now.
http://www.mnkiting.com/images/ambulance2.JPG
A.
Aaron Saude is offline   Reply With Quote
scamp
I'm adding air conditioning to my Scamp. Bryan L. Modifications, Alterations and Updates 24 07-17-2022 10:49 AM
I'm going to try this for adding AC to my Scamp Bryan L. Problem Solving | Owners Helping Owners 6 06-06-2009 12:00 PM
Adding roof air to 86 scamp d_wildemann Problem Solving | Owners Helping Owners 4 07-30-2007 05:32 AM
Adding a microwave to my Scamp John Blair Modifications, Alterations and Updates 5 04-12-2007 09:11 AM
Adding a Fan to a Scamp JeanJack Problem Solving | Owners Helping Owners 4 06-14-2006 05:47 AM
» Trailer Showcase
Dreamer
Douglas P
Betty
KentH
