adding a third tail/brake light to my Scamp - Fiberglass RV
Old 02-03-2015, 08:41 AM   #1
John Linck's Avatar
Madison, Wisconsin
We plan to haul two bikes on our Scamp and I was concerned about the bikes obscuring the brake lights. So I added a third LED light on top of the trailer as shown. I bent some sheet aluminum for the mounting and attached it with 3m tape. Wiring was much harder then mounting. I ran the 3 wires thru the roof vent down to the left tail light and patched the wires together. Hopefully the increased visibility will warn folks when I brake.
Safe travels, john
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 02-03-2015, 09:29 AM   #2
Did something similar on our Casita. Added a high mount tail / turn / stop light bar above the rear window. Installed a junction box on the trailer tongue and made my connections there. On the rear bike rack that I use on our Uhaul camper I installed an extra set of tail lights. Now you've probably opened up a can of worms about rear bike racks !!
Old 02-06-2015, 09:04 AM   #3
Martins HeirCon's Avatar
Trailer: Trillium 1300
I've been kicking this idea around, too. I got stalled at the wiring for only a brake light...i guess I have to run stop/tail/turn, or at least stop/turn. With the shared bulb makes it goofy.
I suppose I could add a relay to reverse the polarity of one of the signals, and use that to ground the high mount? That way it would only light when green and yellow wires were both energized...i think...maybe
Martins HeirCon is offline   Reply With Quote
Old 02-06-2015, 04:20 PM   #4
Glenn; I used a strip light that has the 4 wires, and they are color coded the same as a standard flat 4 plug. It is LED, lights up to look like 3 marker lights when tail lights are on, has left and right turn, and is solid red with stop lights. Wired in just as you would normal tail light wiring.
Old 02-11-2015, 01:50 PM   #5
Trailer: Scamp 16 Standard (Coming May 1st!)
New Jersey
Added tail ights
When ordering my Scamp 16 I opted to add a set of tail lights above the mid seam. Scamp is charging me only $75.
CharleyWhiskey is offline   Reply With Quote
Old 02-11-2015, 02:57 PM   #6
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
You need one of these to make it work.
Pacer 20-702 Logic Module for LED Lighting Kits - Tail Light Circuit
Spanke
Trilliums Rock!
light, scamp
Third Brake Light Robert Johans Problem Solving | Owners Helping Owners 5 12-06-2011 08:24 AM
Removing The Third-Row Seat in an Odyssey Patrick M. Towing, Hitching, Axles and Running Gear 2 08-12-2009 06:08 PM
Third times a charm james kent Modifications, Alterations and Updates 3 08-18-2008 11:58 PM
Third Annual Myrtle Beach gathering - no reservations needed Terrance Rallies, Get-togethers, Molded Meets (Archive) 6 02-14-2008 08:23 PM
Can you pass the third grade? Benita Jokes, Stories & Tall Tales 22 03-31-2007 01:03 PM
