adding a window to Scamp 16 - Fiberglass RV
Old 04-04-2019, 08:51 AM   #1
Name: Jane and John
Trailer: 2017 Casita 17 SD
New Hampshire
Question adding a window to Scamp 16
Greetings we are thinking about adding a small window to the front side(opposite the door) of the Scamp we have a small dinette in front and it gets a little stuffy in hot weather, has anyone had experience with this?
NH-Boomers is offline   Reply With Quote
Old 04-04-2019, 12:01 PM   #2
IllAnnoy
A good Hehr window would be no challenge. Its just a matter of measure twice, cut accurately. Also be sure the area is flat and free of obstacles ( like wiring)
If you use a tool such as a Roto-Zip be sure and set the blade shallow to avoid twisting the ratfur all up with the blade.
Go slow and use a dust mask when cutting the fiberglass.
Old 04-05-2019, 08:03 AM   #3
Name: Jane and John
New Hampshire
adding a window to a Scamp
Thank you for that advice we have a 2006 and have completely gutted it and replaced almost everything but haven't quite dared to put in a new window, the other problem is the door doesn't quite fit and we even bought a new style door that we saw at the factory from Scamp but we can't seem to get it installed. Oh well another project for another day.
Old 04-05-2019, 01:44 PM   #4
Add the window
John,
You donít have to be concerned about putting a window in the side of the camper. I put one in on my 13í Scamp, photo below. It not only made the food prep area lighter, the rigid aluminum frame actually stiffened the side of the camper. The fiberglass above the belly band is not as thick as it is below the band. I think I have toilet paper thicker than the fiberglass in some of the areas.
I had to place the new window to the left because the smaller Scamp window was already on the right side, and the housing for the refrigerator venting had to be raised because of the larger frig I installed. You could easily center the window, or place it to the right if you like. Itís a really nice addition.
Jim
Scamper Jim is offline   Reply With Quote
replacement window glazing for rear window on 1975 scamp Josh Wink Problem Solving | Owners Helping Owners 6 07-15-2016 04:05 AM
Sacrilege? Adding a window Zennifer Modifications, Alterations and Updates 27 03-08-2016 10:22 PM
Scamp back window and maxxair window vent SharonM Problem Solving | Owners Helping Owners 3 04-19-2013 11:06 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Adding brakes to Scamp Quint Care and Feeding of Molded Fiberglass Trailers 27 01-26-2006 08:07 AM
