Adding baggage hatches - Fiberglass RV
Old 09-11-2009, 09:25 PM   #1
Rick kl's Avatar
Trailer: 2000 24 ft Shasta Ultra Flite
On my boler 1700 there are small access doors to the corner storage compartments, storing long items like axes or even a broom has always been trouble, I solved this by adding some small access hatches to use these otherwise hard to get at storage space. It was a simple job, inexpensive hatches are available on Ebay.
Rick kl is offline   Reply With Quote
Old 09-12-2009, 08:12 AM   #2
Send a message via MSN to christineb
Great idea. I'd love to do this with our Scamp. Was is difficult to cut the fiberglass?
Christine
christineb is offline   Reply With Quote
Old 09-12-2009, 10:24 AM   #3
Rick kl's Avatar
Christine
The fiberglass cut very easy with a jig saw, watch for power wires and plumbing, after the install I moved the pex pipe in the picture out of the opening. as a added bonus I can see the level in my black water tank as well.
Old 09-12-2009, 10:53 AM   #4
April Wilcox's Avatar
Trailer: 13 ft Scamp 1983
How do you give your jigsaw blade a place to start the cut?
April Wilcox is offline   Reply With Quote
Old 09-12-2009, 11:23 AM   #5
Trailer: Boler 13 ft 1971
Drill a hole near the corner that is bigger than your jigsaw blade. Put the hole in the area which you will be throwing away. (A wood worker's trick)
Chris de Haan is offline   Reply With Quote
Old 09-12-2009, 11:29 AM   #6
Rick kl's Avatar
Correct! wear a long sleeve shirt and a dust mask the fibers can be irriatating
Old 09-12-2009, 12:21 PM   #7
Old 09-13-2009, 08:01 AM   #8
james kent's Avatar
Trailer: Boler 1984
Use the outer ring as a template and mark and drill the corner holes from the INSIDE. That way you don't accidentally run into a cross member. Re-mark outside, using the outer ring again, and mask the area with painters tape so as not to scratch anything you want left looking good. If you can't find a fiberglass cutting blade for your jigsaw, a metal cutting one works well. Don't forget to place a layer of butyl tape when attaching the door to keep it waterproof.
Old 09-13-2009, 01:46 PM   #9
peterh's Avatar
I wrote some fiberglass cutting tips in some of my posts. Look at the three posts starting here, where I talk about doing my U-shaped dinette conversion, and another two posts here, at ther top of my adding a hatch topic, then one more important cautionary note in the same add-a-hatch thread here.
Adding second battery breid19 Electrical | Charging, Systems, Solar and Generators 19 07-24-2009 10:09 AM
Replacing external access hatches Tim Ryce Problem Solving | Owners Helping Owners 8 08-25-2008 01:18 PM
Adding brakes? Dorothy Rissel Towing, Hitching, Axles and Running Gear 14 10-24-2007 05:59 PM
adding a pop-top? Doug Herr Problem Solving | Owners Helping Owners 3 07-16-2007 10:04 PM
Exterior Hatches/compartment doors Bob Maddox Problem Solving | Owners Helping Owners 8 04-12-2006 12:41 PM
