Adding Solar to Bigfoot Roof - Page 7 - Fiberglass RV
Old 07-19-2019, 09:32 AM   #85
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Originally Posted by ZachO View Post
The Renogy instructions say to always connect the charge controller to the battery before connecting the panels to the controller. Why? What happens if I need to disconnect the battery? Do I have to disconnect the panels first?
Attachment 130497
If you disconnect the batteries before the panels, the charge controller can fry. It is not designed to have power input with no output which is what happens when the battery is disconnected. Disconnect the panels first. Some people use a cutoff switch mounted in an easy to reach location so they don't have to remove a fuse or disconnect wires.
Old 07-19-2019, 09:44 AM   #86
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Great, thanks. Well, another quick project before these will be functional. An easy one, though.
Old 07-19-2019, 03:38 PM   #87
ZachO's Avatar
Montana
In anticipation of either someday adding more solar to the roof, or tying in a small portable panel, what can I do now to ensure less frustration when/if that happens? Aside from leaving some extra length in the wires from the panels to charge controller so I can more easily splice some connections, is there anything else I should do before everything is hooked up and wires are trimmed?
Old 07-19-2019, 05:05 PM   #88
Alex Adams's Avatar
New Hampshire
If you are going to join the roof panels and/or the portable inside the trailer then I would run the wires to a terminal block and then connect that to the charge controller. That would give you the most flexibility as far as hooking up more panels. If you add another roof panel, you can run the wire to the terminal block or if you get a portable, you can put an outlet connected to the terminal block for the panel to plug into on the outside. Of course I am assuming you will use your panels in parallel.
Old 07-19-2019, 09:27 PM   #89
John in Santa Cruz's Avatar
CA
vehicles always fuse the + side, since the - side is the chassis. a negative wire 'shorting' to the chassis will do nothing, no current as there's no potential. a positive wire shorting to the chassis will definitely let the 'magic smoke' escape...
Old 07-20-2019, 09:35 AM   #90
panels, fuses, switches....
yeah Zacho, my panels are just a half inch off the roof....probably not best for ventilation/cooling....but where I live I should be so lucky to generate too much heat
my "redundancy" was/is a couple of wire "safety straps" hooked to the air covers.....yeah, that was all "temporary" when I first put them up there...and four years later it's still all the same....funny how that happens....
I used a 12 fuse holder on an 8 wire close to the battery....(shortened the 12 leads to almost nothing)...as mentioned before the short length makes it ok
a switch between the panels and the controller is easy to do and a good idea really...it sure makes it quick to check the performance (VOC=voltage open circuit)...also if you're ever doing some work on your electrical system you don't have to scratch your head and wonder if EVERYTHING is off
I did same as you and got rid of the barrel fuse....all blades now
there's no problem adding fuses if you get worried...as I was building mine I added a couple behind my wooden "dashboard" ....just in case (vibration or something coming loose)....nobody wants blue smoke
Old 07-21-2019, 03:29 PM   #91
ZachO's Avatar
Montana
Thanks.
I feel like this should be easier...but I guess I still know less than I think.
I want to wire this switch. I would have just spliced it into the + wire. But this diagram is throwing me off...This is for the solar panel cutoff.
Old 07-21-2019, 03:47 PM   #92
CA
Thanks.
Attachment 130541
Attachment 130542
the diagram is the way it is, as its for using the switch to control an accessory load like a light, and that accessory is usually wired to ground, and you switch the power (+) side.
just wire the switch in series with the + output of the solar panel, you're good.
Old 07-21-2019, 03:50 PM   #93
the diagram....
the load is the appliance/light/motor... whatever....
there's a pos. and neg. wire going to the "load"
you install the switch anywhere on the positive wire.
Old 07-21-2019, 04:25 PM   #94
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
The diagram just switches the position of the switch & load. Switches are in series with the load, so either position will work, as will placement in either the + or - leg.
Old 07-21-2019, 05:07 PM   #95
If we were talking 120 AC wiring switching in the return lean is not allowed.
It is a good idea to follow the same convention in DC circuits as well.
Since now a days the negative is usually grounded (at least in the US) the switch should go in the positive lead.
If you placed a switch in the negative lead then the power supply is still hot and accidentally touching the wires or chassis could result in problems and loss of high pressure magic smoke from wires and parts.
Old 07-21-2019, 05:37 PM   #96
CA
otoh, on a lot of electronic circuits, the control signal causes the ground to be closed, via a bipolar transistor in an 'open collector' configuration.
so really, it all depends on the application.
Old 07-21-2019, 06:01 PM   #97
Within a circuit, but rarely as a standalone box.
In most cases the switch should not be installed in the return circuit.
In an AC circuit it is a violation of the NEC without a doubt.
Probably in a DC circuit as well
But, the NEC devotes an entire article (404) to switches. Article 100 provides six separate definitions for "switch," covering bypass isolation, general-use, general-use snap, isolating, motor-circuit, and transfer. Article 404 requirements apply to all switches, switching devices, and circuit breakers used as switches.
You wire a switch to make or break the supply conductor-also called the hot lead. The NEC specifically bars switching the grounded (neutral) conductor or the grounding conductor [404.2(] (Figure 404-2).
Old 07-21-2019, 06:59 PM   #98
widgetwizard's Avatar
Thanks.
Attachment 130541
Attachment 130542
That switch is on the positive lead.
What is the confusion?
Get 'er done.
Retired from Orbital Machine Works.
Where is Jim now?
widgetwizard is offline   Reply With Quote
solar, bigfoot
adding AC.. non roof units do they work in the 90s madduckdog Modifications, Alterations and Updates 24 08-20-2017 05:12 PM
Adding roof air to 16 ft Scamp LyleB Modifications, Alterations and Updates 2 10-24-2015 06:28 PM
Adding Solar Panels Bigfoot Mike Problem Solving | Owners Helping Owners 50 09-25-2009 08:59 PM
Solar Panel Connetion adding a controller too... jimtesla Electrical | Charging, Systems, Solar and Generators 16 09-22-2009 06:40 PM
Adding roof air to 86 scamp d_wildemann Problem Solving | Owners Helping Owners 4 07-30-2007 05:32 AM
