05-26-2012, 07:50 PM
Trailer: 13ft Scamp
Air Conditioning a 13 ft Scamp
After lots of soul searching, I finally settled on putting a 5000 BTU Fridgidare window air unit in the back window of my Scamp. Other options would have made too major modifications. Here are some photos of current status, first cut a hole in the back plexiglass window, then make a mount. More as I progress.[IMG]  [/IMG]
[IMG]  [/IMG]
[IMG]  [/IMG]
05-27-2012, 07:37 PM
Trailer: 13ft Scamp
And finally mounted. It was a hot day, the camper was roasting. That 5000 btu has the capability to cool it far below comfort level.
[IMG]  [/IMG]
05-27-2012, 07:46 PM
Nice job, how about inside pics?
05-28-2012, 01:33 PM
Trailer: 2001 Scamp 13'
Seems like the last place I'd want weight on my Scamp when towing. High and on the back. The only time I've felt any unplanned, unwanted trailer movement while towing was when I had too much cargo in the back of the trailer? Do you have an ample tow vehicle or do you move the AC unit inside the trailer or TV while towing?
05-28-2012, 02:51 PM
I'm guessing you don't know that the A/C in question weighs only 35#, which is less than one of his two full propane tanks, or less than 5gal of fresh water.
05-28-2012, 03:19 PM
Nope, I'm well aware what AC units weigh. The 5000BTU unit I'm considering is 36lbs. For reference, I do not plan on towing with water in my tank or in my hot water heater and they are closer to the axle and much lower. I believe my hot water heater is 35lbs empty, not that much, but I'm glad it's right behind a wheel and not hanging off the back of my trailer.
But that's me, I have a tiny tow vehicle, that's why I'm asking if it's towed with the AC in place of it it's moved while towing. With a heavy TV it may not be an issue at all. If it works in this instance, great. I'm just wondering if that would work for me or not.
I'm thinking the closet, above the wheel, but that's not a trivial install.
05-28-2012, 03:25 PM
Trailer: 13ft Scamp
I too think the weight addition is a negligible factor, towing will tell. Weight is far less than the roof air people hang on all the time. I am prepared to make redistribution if necessary. I still have to finish it up, but here is the inside photo someone requested.
There is NO movement up and down, very solid mount, but there is some forward/backward action that may be a problem. I am considering a reinforcement board on the inside to spread the loads from the current narrow load point. It sure cools it down in a hurry (92 and sunny today here) and is definitely more AC than is actually needed, but I don't think they make a 2500 btu job this cheap ($90 at Lowes with my military discount)
[IMG]  [/IMG]
05-28-2012, 03:34 PM
Trailer: 13ft Scamp
I leave the ac alone, permanent mount. I have plenty of tow vehicle, a Honda Fit with trailer tow package installed
[IMG]  [/IMG]
05-28-2012, 03:43 PM
Trailer: 13ft Scamp
The closet above the wheel was my definite first choice. Then it got delivered and I found that if you have the full size bed, no AC can be put in the closet on these little 13 footers. If you have the small bed however, I would recommend highly that you install it there.
I made a few laps around town with it on the Honda Fit, I can tell NO difference in handling. Water tank is full too, as is the propane tank. They were all empty in previous test runs. It sure will get up to 80 mph in a hurry and handles swell there..
05-28-2012, 03:54 PM
Indeed the roof units are heavier. But I'm not planning on towing a Scamp with a roof unit either. Again, this is more trying to be safe with a small TV, not a concern for most people.
Interesting you say a smaller BTU rating would be enough I've found a tiny 3000 BTU unit, but it's made for industrial cooling and while I have not found any published prices I expect it to be many times the price of a cheap household unit. I was planning to post a thread about that anyway, so I've gone and posted that and I'll link to it here:
Tiny 3000btu AC unit?!
05-28-2012, 03:57 PM
!!!! A fit!!! That's awesome, I have some cousins with a fit who'll be very excited to see that. I told them I doubted a fit would have the power and brakes to tow well. They seemed a bit disappointed. Have you weighed your rig? At the wheels and the tongue? Do you have brakes?
05-28-2012, 04:08 PM
Also, do you have a link to your tow package? Is it more than just a well reinforced receiver? Does it have a stabilizer etc?
Sorry if this is off topic, perhaps I should have PMed?
05-28-2012, 04:19 PM
Trailer: 13ft Scamp
Pretty pricey at $1782.00 at this place: http://www.enclosurehub.com/productcart/pc/viewPrd.asp?
The Honda Fit uses the same engine that is used in Formula F racing, and on the outboard engine, I also am using on in my airplane, look at it here: MyKitLog
I have a Tekonsha prodigy brake unit, the "tow package" was a tongue in cheek comment, nothing except brakes and a trailer hitch.
In reality, I will probably tow it more with a Kia Optima, little more hp and weight.
user=DonFromTX&project=1903idproduct=8270
05-28-2012, 04:20 PM
Trailer: 1982 13 foot Scamp
Wisconsin
I put a window mount a/c under the closet of my 82 Scamp.Not permanent...only as a test.It fit like a glove.All I would have to do is cut an opening for a vent,and figure out a way to get the condensation out (a drip tube running out behind the wheel well)But since I'm up in the Northwoods,I figured ,how often will I need this,and how often when I do will I have electric hookup?Plus...putting it on the passenger side puts it on what's called the low side of the highway
| Thread Tools |
| Display Modes |
No events scheduled in the next 365 days.
