Alternatives to painting Fiberglass - Fiberglass RV
Old 06-29-2013, 10:19 AM   #1
neauone's Avatar
My nephew and I had a conversation about painting my Scamp. Little did I know he did boat repairs and had fiberglass knowledge.
However my issue was with having the Scamp professionally painted to my liking.
But he offered an affordable alternative to painting and I must say I was thoroughly impressed.
The product is called Plasti Dip and for about 400.00 DIYer's will be blown away.
The material is not only a cheaper alternative to professionally painting, but is extremely durable.
There are YouTube videos on the use's colors and options.
The website is DipYourCar.com
Just thought someone facing the same future decisions I am will want to have some alternatives to having their fiberglass units painted.
Another benefit of this material is that it actually is sealing in the unit.
Now heres the greatest part of all, if you don't like it say at any time.
The material can be pulled off simply by getting under the skin.
Like a plastic balloon it just peels right off.
neauone is offline   Reply With Quote
Old 06-29-2013, 11:21 AM   #2
I would be afraid it may come loose while driving and the wind get under and that would make for some sight and damage.
RRJR is offline   Reply With Quote
Old 06-29-2013, 11:28 AM   #3
I've used Dip It on a couple of tools. I can't imagine using it for a surface material on a trailer. Wow, would a run really show!
Folks worry about road rash (AKA rock chips) to the front of their trailer. What happens if a rock punctures this stuff... will it start peeling off? Hummmm.
Old 06-29-2013, 11:50 AM   #4
willisworms's Avatar
Trailer: Beachcomber B15
Kelowna, B.C. Canada
I have used it on a few things. It is quite durable, and actually very easy to apply. Runs are not really a problem as you apply it in many thin coats, working your way around the project. A tear will not result in it flapping off in the wind. This is in no way a permanent product though. It is meant to be able to remove. "tuners" use it to mod their cars, without permanently harming the finish. You want a matte finish on your car? paint this stuff on, when you get sick of the look, pull it off.
Just working in the shop
willisworms is offline   Reply With Quote
Old 06-29-2013, 12:35 PM   #5
carlkeigley's Avatar
NE Oklahoma
That's a unique product and very interesting.
Pretty good videos on the site.
Old 06-29-2013, 12:38 PM   #6
neauone's Avatar
I think we would be well served to check out the Youtube videos on the product and in particular the durability of the product.
Thanks Donna
Old 06-29-2013, 01:59 PM   #7
From the FAQs:
How long does Plasti Dip® last? If properly applied, Plasti Dip® will last as long as 3 years without having to be retouched. It is very durable and will not lose it's bond. The spray distance when applying as well as the amount of coats applied will heavily determine the longevity of the product. After 3 years, or during the three years if desired, a new refresher coat can be easily applied.
Read more here: https://www.dipyourcar.com/pages.php?pageid=1
Old 05-23-2015, 06:42 PM   #8
Trailer: Ventura
Manitoba
Did you try it out? My hubby is tempted to do this to are camper like to know if it works
Cheyanna83 is offline   Reply With Quote
Old 05-23-2015, 08:42 PM   #9
Gotta say, using a coating designed to peel off if you don't like it, sounds like something they might come up with at a local amusement park (in Anaheim, CA) that is celebrating it's 60th anniversary this weekend..... LOL
For a lot less, about $250, you can do it right by using Interlux Topside Marine Coating, using the roll and tip application method, and you still don't need it applied by a shop.
I am sure that anyone in the fiberglass boat repair business is familiar with both the product and the technique.
Old 05-23-2015, 10:20 PM   #10
Trailer: Ventura
Manitoba
Good to know! I'll tell hubbers about that paint
Old 05-23-2015, 11:44 PM   #11
EllPea in CA's Avatar
CA
Another alternative I've been thinking of is the kind of "wrap" that businesses do on their vehicles to advertise. My son is a graphic designer and creates images and text to WRAP onto a vehicle. You could have any image, any color, any words you want. And it's removable, replaceable, upgradeable. This isn't something you could do yourself, they apply it in their shop; I think it's something like a shrink wrap. They can also carry the image onto windows, using a different material which is more like a screen. So from the outside you just see the continuous image; from the inside you can see out just fine. The screen does help block sun, however.
Son works for Signarama, and they do an amazing business here in Redding, CA, but I can't speak for the quality or customer service elsewhere.
LP
EllPea in CA is offline   Reply With Quote
Old 05-24-2015, 07:13 AM   #12
neauone's Avatar
Sorry for the late reply, I did use the product, but in a small area. Actually around the side windows of the Scamp for privacy. I also use the product around the window frame for added waterproofing. After using the product I found somethings that would lead me to think twice as far as an alternative to painting. The product is easily damaged either by a rock, tree limb, etc, also it is easily removed with W2 metal solvent. So any deranged individual could come by spray it on and it becomes like putty. I would not recommend using Plastic Dip, plastidip on the trailer.
Old 05-24-2015, 07:14 AM   #13
neauone's Avatar
WD 40
Old 05-24-2015, 07:19 AM   #14
Thanks for the real world experience Guy. That's what folks need to hear. Whether to paint or use lots of wax or floor polish or a wrap, it gets down to expectations and how much work someone wants to do.
I'm not thrilled at the lasting properties when reading about wraps. For the money, if a person is willing to do the prep, a paint job will last decades (with cleaning/wax maintenance) compared to wraps. But that's just my thoughts. YMMV
painting
Painting fiberglass Marjorie M. Care and Feeding of Molded Fiberglass Trailers 9 04-03-2017 11:11 AM
painting fiberglass saltcreek Care and Feeding of Molded Fiberglass Trailers 4 11-07-2012 03:52 PM
Painting interior fiberglass Cyndivg11 Care and Feeding of Molded Fiberglass Trailers 4 07-23-2009 10:59 AM
Painting interior fiberglass charlenep Problem Solving | Owners Helping Owners 2 08-09-2008 02:39 PM
Painting fiberglass John Vleck Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
