Amerigo Progress......Finally! - Page 5 - Fiberglass RV
Old 06-20-2017, 06:00 PM   #57
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
wall panel product?
Steve, what product did you use for the wall panels?
John in Michigan is online now   Reply With Quote
Old 06-20-2017, 06:29 PM   #58
SteveV's Avatar
Trailer: Amerigo FG-16
John, I used a 1/4" luan/flooring underlayment from Home Depot. I cut /fit the pieces, primed/painted the backside, primed the front side w/wallpaper primer (sizing) & applied a textured vinyl wallpaper before I installed them. Yes, it was a giant pain but figured I only have to do it once! I was able to reuse the original plastic trim pieces along the top & inside corners.
SteveV is offline   Reply With Quote
Old 06-21-2017, 08:56 AM   #59
Kai in Seattle's Avatar
Love the little guy--and the trailer!
You kept that flip-up countertop extension or added a new one, I see...handy!
Looks like you enlarged the door for the "Putin" (front closet we use to hold the porta-potty and so much more); we enlarged that opening, too, but use a beach towel/curtain instead of a door.
I remember you wrote about a dorm fridge, which I think is a super idea (we're still using an ice chest and probably will continue to do so)...
I love how yours is coming along and how it looks!
At 40F outside, yes, agree about the furnace!
So far we need electricity. We carry water though we don't scorn campground water, especially for my solar bucket bathing and the girls (we gave them a wading pool in Nimble's nighttime nest at Maryhill last month--it was over 80F and the girls were lethargic with heat ...--we use a plastic barrel liner (the shallow kind) for her bed underneath the back bed--works great for a wading pool ).
Enclosing some shots like yours for comparison--your photos seem much clearer but the trailer resemblance is uncanny !?
Final pic: Paul made me a fairly big, heavy key fob...if you'd like one, let me know. We keep it on a hook by the door nearest where Peanut lives most of the time for quick access-hard to lose, hard to forget. We would be delighted to send you one.
BEST
Kai
Semper ubi sub ubi.
Old 06-21-2017, 05:51 PM   #60
SteveV's Avatar
Thanks Kai!
I did reuse the original doors. The closet/toilet area had a sort of bi-fold door on the inside that opened/attached next to the stove top giving a little larger private area when using the "seat". Since I'm not carrying a porta pot I won't reuse the extra inside door. Also with the closet door hinged on the left side it is awkward to open from inside the camper....you have to litterally be standing outside of the camper, open the door then step in. Switching to a right side hinge is on the to do list.
That is a cool looking key fob! Is it from one of your old emblems?
I am working on making a mold from one of my good unbroken emblems so I can reproduce a few of them.
Old 06-22-2017, 11:36 AM   #61
Hi,
You had quite a different door to the front closet than we got--ours was about 20" wide, hinged on the right, and when open blocked the outside door entirely. There was a narrow wall in the opening making access fairly difficult. The door seemed to be quite heavy but it did have a mirror on the galley side.
The key fob is a new rub-on decal, rubbed onto a piece of acrylic and covered with another piece to enclose it. Your idea sounds very good.
Kai
Semper ubi sub ubi.
Old 06-22-2017, 01:08 PM   #62
CrazyTimmy's Avatar
MB
Originally Posted by SteveV View Post
I plan on using a small dorm fridge but I did run a new gas line to the fridge area to keep the propane option there.
Curious, what did you use for the propane line? flexible copper pipe? I looked at Home Depot but none of them say they are for gas. Any suggestions?
CrazyTimmy is offline   Reply With Quote
Old 06-22-2017, 01:32 PM   #63
rbryan's Avatar
Arkansas
Type K, Type L and sometimes type M copper pipe is used for interior gas lines. I used type L 3/8" to install a Dickinson cooktop in my Escape. I've found Home Depot often doesn't carry the stuff I'm looking for, and have had better success at Lowes - although that may vary by what region of the country you're in.
Oh and by the way, avoid the crappy flare tool they sell at HD. It won't properly grip the pipe. The one at Lowes is much better.
https://www.lowes.com/pd/3-8-in-dia-...r-Pipe/3134487
Old 06-22-2017, 01:36 PM   #64
SteveV's Avatar
I ran 1/2" black iron pipe under the trailer & stubbed it up thru the floor. I have it capped off inside for the fridge use if needed but I did use copper line from the black pipe to the stove top. pretty sure it was 1/4". I did get it from Home Depot & it was rated for refrigeration (ac) use or gas (lp). It came in a 10' roll, I'll look for the box/part # in the garage. I did have to single flare the ends.
Old 09-18-2017, 09:55 AM   #65
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
You are showing the most detailed pictures of an Amerigo reno I've seen and I'm wondering what you're using for wall board? Very nice work. Fascinating job.
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Old 09-18-2017, 08:27 PM   #66
SteveV's Avatar
Thanks, I used 1/4" luan from Home Depot. I had to sort through their pile to find ones good enough & without defects to stain for the wood toned panels. The white panels were finished with a textured vinyl wallpaper.
Getting close to the finish line now!
Old 10-05-2017, 02:42 PM   #67
SteveV's Avatar
A little more progress on the Amerigo!
I got to spend some more time on the FG-16 in the last couple of weeks & got a few small things done.
The second dinette bench is built, installed & 'glassed into the wall now. Just like the other benches the only wood salvageable were the hatch covers.
The original refrigerator had a mirror on the door & I liked how it made the inside area feel bigger. I found a mirror almost the exact same size at a local Goodwill store that was fairly light weight w/a plastic frame so it became the new "door" for the cabinet.
A new filler board finished up the rear gaucho/bed area so now the only project left for the back half is cutting the radius window trim pieces. I hope to get the front wall panels done soon then it's on to finishing the electrical......hopefully!
Old 10-12-2017, 08:50 AM   #68
Kentucky
Excellent idea
Steve,
This idea should be at the top of any to-do list for these old trailer reno's to add the much needed ground clearance. Nice work and good pictures.
Bill
While the low ride height is good for ease of entry into the camper it was a little scary with the steep entrances to many gas stations & driveways around here. More than once on the trip home I heard the jack bottom scrape while slowly pulling out from a gas stop. While I had the Amerigo up on jack stands I felt it was a good time for my over sprung axle conversion.
From the factory the axle is mounted on top of the spring (first pic). That combined with the 4" dropped spindle makes this one low rider! Moving the axle under the spring is a good way to gain some ground clearance for my needs. This requires welding a new spring perch on the top side of the axle. Dexter does offer a kit to do this but I bought the new spring perches & U-bolts from the local Agri-Supply. I also replaced the shackles, shackle bolts and spring bushings while I was in there. I think all together I spent a little over $20 for the parts. The new spring perch should be welded on top of the axle parallel to the old mount.
Total lift from this conversion is 4 3/4" & the good part is you can easily change it back in under an hour since the old spring perches are still on the axle.
Old 10-12-2017, 09:07 AM   #69
I wish there was a like button you are fantastic!!
bob
Old 10-12-2017, 09:09 AM   #70
I use flex get it off amazon they carry some long lengths.
bob
amerigo
Seattle Area -- Tour of an Amerigo Trailer, in progress Kai in Seattle Problem Solving | Owners Helping Owners 0 11-11-2015 11:05 AM
Photos of Amerigo FG-16 remodel progress Campin_Idaho Modifications, Alterations and Updates 0 01-05-2015 10:21 PM
New Amerigo Owner - FINALLY.... Need Advice. cvc0922 Problem Solving | Owners Helping Owners 26 02-18-2014 01:01 PM
UT | New Amerigo Owner - FINALLY.... Need Advice. cvc0922 Classified Archives 0 02-11-2014 02:07 AM
Finally, Finally... Richard Hayes Hi, I am.... 11 06-16-2012 09:35 PM
