pic 1 front kit corner cabinet frame, hot water tank on floor with space for trash can
pic 2 shows closet next to refer with fresh water tank, water pump, and sink drain (black pipe) going threw floor to tank below and to rear to go up threw refer cabinet to roof for tank vent
pic 3 looking forward at kit cab, refer, closet, and lower storage road side
pic 4 rear over head cabinets all the way around, dinette with storage underneath it
pic 5 dinette with top plywood installed
pic 6 overhead cabinet doors installed, the roof air conditioner hole cut out, looks offset but is centered in roof, refer cabinet is deeper than closet on door side
pic 7 laminate flooring installed
pic 8 and 9 kitchen cabinet top with
microwave mounted underneath, tv is set up to sit behind sink, can be seen from dinette
pic 10 toilet, stainless steel shower pan with sewer tank built into pan under toilet(13 gal), shower walls are
fiberglass panels (frp from lowes) glued to wall framing, the faucet is low enough to keep pipes under kit cabinet top on other side
