and last but not least... - Fiberglass RV
Old 08-13-2006, 08:51 PM   #1
jaye580's Avatar
Maine
I wanted to take the Scamp to a glass place to get the windows put in BUT after looking over my budget and not seeing any extra money in it and the fact that summer is coming to an end and I haven't been able to use the Scamp yet, I decided to do them myself....
I had tried the "right" way of doing it and gave up, so I improvised. This is what I came up with...
I cut out frames for the front and back, inside and out and sandwiched the plexi in between. I bolted the frames to the camper, put the plexi in place with construction adhesive, a few rivets for good measure and some mirror clips, then put the inside frame on attaching it to the same bolts as the outside frame (this was quite difficult and frustrating!) I painted the outside and did alot of caulking and so far so good- I plan to fiberglass the frames in and then sand them and paint them better, but I ran out of time!
Also, by doing it this way, I decided to cut out a section in the back window for an air conditioner. I intend to build a shelf under the cutout, and run poles from the shelf to the bumper to support the A/C. I don't need it mounted permanently, so I also saved the piece I cut out (thinking about putting it on hinges or something, haven't decided yet) and also am making a screen that will just velcro around the cutout.
I also saved what I cut out from the insides of the frames and will use them for covers over the windows on the outside. I have the back one partially done and attached it with the little hardware things you lock your house windows with- worked quite well (will come up with something else for actually travelling!)
OK- thats it for my projects and pictures for now!
Owner of 1978 Scamp named the KRAKEN
Owner of 1987 Scamp named ANBOLINN
https://www.facebook.com/Jayes-87-L-...0486405460995/
jaye580 is offline   Reply With Quote
Old 08-13-2006, 11:54 PM   #2
Trailer: 84 16 ft Scamp
I was just wondering what material you used for the frames. I can't quite tell from the photos and I don't think you mentioned it in your post.
Old 08-14-2006, 02:31 PM   #3
jaye580's Avatar
Maine
Guess I forgot that part! I used 1/2" plywood.
